Author Topic: whats missing??  (Read 12552 times)
Offline chuck foster
whats missing??
« on: September 30, 2009, 08:00:30 PM »
i have had this wiggler for about 2 months and i used it for the first time today and noticed that there is something missing. :doh:
in the picture you can see a threaded stud sticking straight up in the middle of the yoke thing-a-ma-jig. what goes on there?????
http://i217.photobucket.com/albums/cc274/aermotor8/TOOLS/IMG_4948.jpgwhats missing??
it seamed to work just fine as it is but i would like to know what is missing.
here is a picture of the whole thing
http://i217.photobucket.com/albums/cc274/aermotor8/TOOLS/IMG_4946.jpgwhats missing??
thanks
          chuck  :wave:
skype:  aermotor8
former hmem member
Offline websterz
Re: whats missing??
« Reply #1 on: September 30, 2009, 08:46:40 PM »
A knurled nut that allows you to adjust tension on the wiggler, and to lock it down for storage.
 :med:
Offline Stefan Pynappels
Re: whats missing??
« Reply #2 on: October 01, 2009, 01:35:06 AM »
This might be a stupid question, but what does a wiggler do? (Apart from wiggle?)
Re: whats missing??
« Reply #3 on: October 01, 2009, 04:15:10 AM »
That`s got me puzzling too!
What`s it do, that we don`t already do with something else?  :scratch:
Re: whats missing??
« Reply #4 on: October 01, 2009, 04:19:32 AM »
Finds a centre :scratch: dunit.
Re: whats missing??
« Reply #5 on: October 01, 2009, 04:29:57 AM »
At the bottom of a well by the looks of it.
John S.
Re: whats missing??
« Reply #6 on: October 01, 2009, 04:38:40 AM »
That really is an elegant one Chuck. As previously mentioned, most probably just a tensioning nut.
Just to explain what they do and how they work.
Imagine you have a pop mark on a workpiece that requires setting up in the 4 jaw independent.
You put the part into the chuck, and stick the short pointy bit into the pop mark. Then turn the lathe on at a fairly low speed, and then move the cross slide until you get the lowest amount of wobble on the long sticky out bit.
Then it is a matter of adjusting the chuck jaws and cross slide until the long bit stops wobbling. You then have the pop mark on lathe centre.
The normal way of making one is say a 1/2" thick plate with a rod silicone sealed into a larger sized hole. Once the silicone is set, you have a wobbler.
Pic should explain a few things.
Re: whats missing??
« Reply #7 on: October 01, 2009, 04:46:28 AM »
Yep! Gottit!
Thanks!  :thumbup:
Re: whats missing??
« Reply #8 on: October 01, 2009, 02:12:20 PM »
thanks for the replies and im sorry i didn't explain what it did, but thanks to john we all know now  :D
the next time i use it i will take some pictures for all to see.
chuck  :wave:
skype:  aermotor8
former hmem member
