Author Topic: Help ID the thingies?????  (Read 9490 times)
Offline Gerhard Olivier
« on: September 26, 2009, 05:05:37 PM »
As usual these day when something breaks and is going to be binned I ask for it take it apart and see what i can save.
This is what I found in the last one would like to know what it al is.
http://i608.photobucket.com/albums/tt161/geroli/DSC_0006-3.jpgHelp ID the thingies?????
Gerhard
Guernsey
Channel Islands
Offline No1_sonuk
Re: Help ID the thingies?????
« Reply #1 on: September 26, 2009, 05:18:09 PM »
The two things with red-oxide-coloured parts look like AC electric motors.
Offline PTsideshow
« Reply #2 on: September 26, 2009, 07:06:57 PM »
two motors Ac 230v 50hz. from what I can read upside down, circuit control board, with surfacemount powertrans former(blue box) Larger one on the right looks to have gear reduction mechanism on the end of the motor. the red handle thing looks to be a screw driver.
the on  off button the green box with the spring on the button looks to be a latching button. and then you have a gear drive mounting plate.
Wouls have been a help if you would have mentioned what it came out of. If you still have the make model and brand you can look up on the web for parts lists or manuals and find out more on the motors if they have names or other identifiers. :ddb:
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
« Reply #3 on: September 26, 2009, 07:10:56 PM »
They might be solenoids...?
Offline No1_sonuk
« Reply #4 on: September 26, 2009, 07:30:55 PM »
Google the visible number on the smaller one - EM2513-125
http://www.ebmpapst.com/media/content/products/downloads/motors/Motors_AC_EN.pdf
« Reply #5 on: September 26, 2009, 07:31:19 PM »
They might be, they do seem to have an output shaft though.  Still, they could be rotary solenoids, we used to call them 'Ledex' motors,  usually had some sort of solenoid actuated ratchet and would rotate the output shaft one step for every input pulse.  I guess their function has been taken over in a lot of applications by steppers, but steppers require more control circuitry.
« Reply #6 on: September 26, 2009, 08:23:06 PM »
Perhaps  :scratch: the blue box is a relay. And there's definitely a screwdriver in there  ::)
« Reply #7 on: September 27, 2009, 02:08:25 AM »
PT seems bang on
Looks like two shaded pole motors, rh one with a reduction gearbox.
These things often normally run hot BTW, don't like 'em much.
Blue box thing is almost certainly an encapsulated transformer, it's near two black electrolytic capacitors, and the little square thing in front of the caps. could be a sil bridge rectifier, these bits are usually fairly close together as a PSU. A better pic. of the inscription will probably tell what the ac output is.
Usually load volts and VA rating.
What the black thing is with a gear on it is anyones guess from the pic. May just have a pancake motor on it. Speculation ..  ::)
Dave BC
« Last Edit: September 27, 2009, 02:18:32 AM by Bluechip »
« Reply #8 on: September 27, 2009, 02:40:29 AM »
Should have explained a bit more
This is(WAS) a silicone putty mixer only outer casing broken
The small AC motor turned a small gear that turner the thing with the big gear ( big gear has a big magnet inbedded) and then i opened some bits to allow you to see in side.
http://i608.photobucket.com/albums/tt161/geroli/DSC_0018.jpgHelp ID the thingies?????
http://i608.photobucket.com/albums/tt161/geroli/DSC_0019.jpgHelp ID the thingies?????
Blue bit looks like a PSU 24v ????? both motors sais 230V
http://i608.photobucket.com/albums/tt161/geroli/DSC_0016.jpgHelp ID the thingies?????
The bigger motor just spun the mixer
http://i608.photobucket.com/albums/tt161/geroli/DSC_0017.jpgHelp ID the thingies?????
The smaller of the motors pushed the putty out slowly with a chain drive from that thing in first pic.
Is any of this usefull (remember im eletronically dislecsic!!!)
Gerhard
Guernsey
Channel Islands
« Reply #9 on: September 27, 2009, 03:36:53 AM »
Geroli
PSU is 24V @ 1.25A .. tranny will be higher volts output with no load.
It may well be the shaded pole motors are not rated for continuous use. Often, if they are a stock motor, this will be stated on motor. But, if they are made for the device specifically, it probably wont. Look for 'duty cycle' 'duty ratio' or similar.
Magnetic clutch looks handy, I would guess that probably works off the 24V ish DC ..
Dave BC
« Last Edit: September 27, 2009, 04:01:50 AM by Bluechip »
