MadModder
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to MadModder!
Home
Help
Search
Login
Register
MadModder
The Shop
Tools
Carbide tip code??
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Carbide tip code?? (Read 11444 times)
Gerhard Olivier
Sr. Member
Carbide tip code??
on:
September 24, 2009, 12:23:04 PM »
Does anybody know where I can get + code for a big carbide cutting tip. Would prefer a triangle about 3/4".
Logged
Guernsey
Channel Islands
jim
Sr. Member
Re: Carbide tip code??
Reply #1 on:
September 24, 2009, 12:45:06 PM »
whats it for?
if you've got the tool its for, you can work out the code for the tip from the code on the tool
if you know the size you need, ie, length, widith, tip rad, hole in middle or not, someone is sure to have the answer
Logged
Gerhard Olivier
Sr. Member
Reply #2 on:
September 24, 2009, 12:52:52 PM »
Hi sorry should have said
I want to make a ball turner for woodwork lathe and will make the holder so detail not important. Just needs to be big enough to have a cutting edge of at least 1/2 inch. Triangle / diamond shape would be good. Possibly only need one as wood is not going to blunt it anytime soon.
Gerhard
Logged
Guernsey
Channel Islands
NorthOf40
Jr. Member
Reply #3 on:
September 24, 2009, 01:02:10 PM »
Hi Gerhard,
These links may help
http://www.finelinehair.com/home/TNMG_nomenclature.pdf
http://www.carbidedepot.com/resources.htm
http://www.carbidedepot.com/formulas-insert-d.htm
Logged
Jim
Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.
– Mark Twain
Guest
Reply #4 on:
September 24, 2009, 01:05:05 PM »
Gerhard,
PM me your adress and I will pop a couple in the post for you.
Logged
Gerhard Olivier
Sr. Member
Reply #5 on:
September 28, 2009, 03:14:31 PM »
Bogs Thanks a bunch the tips you sent got here. They are spot on.
Just need a few more bits that the scrap bin can't help with and then to get started.
Gerhard
Logged
Guernsey
Channel Islands
Guest
Reply #6 on:
September 28, 2009, 03:41:15 PM »
Glad I could help with your project Gerhard.
I have a few more of the big dumpy ones if you go that way.
Logged
Print
Pages: [
1
Go Up
« previous
next »
MadModder
The Shop
Tools
Carbide tip code??
