Author Topic: Lead screw size?  (Read 13008 times)
Offline websterz
Lead screw size?
« on: September 11, 2009, 05:55:37 PM »
I need to make a new set of half-nuts for my HF 7x12. Cheap folks that they are the Chinese had only installed the lower half of my half-nut but I got on with it because I wasn't too worried at the time. Well, the half that I got is wearing out...cheap Chinese iron you know, and my power feed is beginning to slip. I recently had 200+ pounds of century-old cast iron delivered by a friend of mine in the form of a junked out upright piano harp. The material is fantastic...cuts like butter! Anyway, I am going to take advantage of the bounty and make a proper SET of half-nuts for my lathe but I have no idea what the leadscrew size and pitch is. Anyone know off the top of their head? All I know is that it is an Imperial, not a metric screw.
 :proj:
 :med:
Re: Lead screw size?
« Reply #1 on: September 11, 2009, 06:35:50 PM »
Offline websterz
« Reply #2 on: September 11, 2009, 06:47:42 PM »
16tpi I believe http://www.littlemachineshop.com/Reference/change_gears.php
Metric is 1.5mm pitch
hmmm...I may be removing that and putting a 5/8-16 ACME on in it's place.
 :med:
« Reply #3 on: September 11, 2009, 07:09:20 PM »
websterz,
My 8 X 20 Grizzly has a 16tpi. I wondered why I couldn't cut a good Imperial thread.
The lathe is going to go through a total rebuild. I've already started  on the frame al Bogstandards fix of (i think it was ) Darren's lathe. Not going to put threading capabilities on it though. I have the Logan lathe for that.
I was also thinking of going for an ACME thread but maybe 1/2-20. Might even try to cut my own using the Logan.
Unfortunatly right now I'm to busy with "need to do stuff" that doesn't include playing in the shop.  :(
Offline No1_sonuk
« Reply #4 on: September 11, 2009, 07:13:43 PM »
If you're going to replace it, I would suggest making the right-hand end longer through the bearing if you can.
Doing that means you could more easily add a separate fine feed and/or CNC motor, handwheel, etc.  :thumbup:
« Reply #5 on: September 11, 2009, 07:28:35 PM »
Unless you have a bad case of  :proj:, it might be easier to buy some from LMS, considering what they cost:
http://littlemachineshop.com/products/product_view.php?ProductID=1373&category=5
The Yahoo 7x12 minilathe group seem to think that the thread is Acme-style, tho' perhaps not true Acme. If you need it, in their "Files" there's one called "Half nuts +threading". It includes details of switching from an inch to a metric leadscrew, with instructions on how to fit/adjust the half-nuts. The procedure will apply to either version.
