Author Topic: Chamfering/rounding edges  (Read 8106 times)
Offline rleete
« on: July 22, 2009, 02:40:39 PM »
Other than the fairly expensive chamfering or edge rounding mills (more than double what I paid for my whole set of 6 regular mills), is there an alternative?  Granted, with the amount of use they'd get, they would probably last me nearly forever.  But hobby funds are tight, and I need a less expensive way.
Relatively long straight edges I can do on the mill with the proper setup.  Heck, if I want to spend the time, I can use a file.  How about on a radius?  Can I cut a piece of drill rod and harden it to produce a decent edge?  If so, can anyone post some pictures or C-o-C sketches for me?
Re: Chamfering/rounding edges
« Reply #1 on: July 22, 2009, 02:45:37 PM »
This may be wrong, but this what I do when I need a chamfered edge... I can't afford an expensive tool either.
I use a center drill... carefully. I got mine for cheap!
Hope it helps
« Reply #2 on: July 22, 2009, 03:39:04 PM »
Also for aluminum... Read THIS POST by Bogs...
