Author Topic: Adding lights to a circuit controlling a 997 dc motor  (Read 11 times)
Offline Dell
    • anniversary-clocks.co.uk
I am in the process of adding a motor to the spindle on my vertical slide on my Pultra lathe, have a 24 volt power supply,PWM, 2 heavy duty 24 volt relay?s,DPDT switch for forward/reverse but I also want to add lights to show motor direction, green for normal cutting direction, yellow for reverse but not sure where to wire them, I am using a wiring diagram originally posted by daGrouch any help would be much appreciated.
Dell
Old man but still learning
