Author Topic: Experiences, thoughts and rants about using Linux as a newbie after Windows  (Read 167502 times)
Offline sorveltaja
I've installed Mint Mate on my pc, so for a change, hopefully less terminal usage. It has its own software- and driver manager, making installing of software like Nvidia driver and Wine rather simple and straightforward.
Downsides of using software manager in Mint Mate:
- it has a limited selection of 'curated' list of apps
- when selecting "show installed applications", it shows only the ones the user has installed.
When rebooting/shutting down, there is 10 seconds or longer delay - like some app or process was hanging on the background. It's not just my system; some other Mint users have this issue as well. One solution works in some cases, another works, again in some other cases and so on.
Quick and dirty (although not necessarily convenient) way to circumvent that is to add 'custom application launcher' button to panel, having command 'reboot'. It doesn't hesitate, it reboots immediately.  Same procedure can be used to add also a  shutdown button, if needed.
I've just fired up win11 for the first time in months . It feels so slow compared to the Kubuntu I normally use on the same machine.  I just wanted to print a booklet usng acrobat ,but it had just started an update . after many many minutes , I was able to open acrobat only to be faced with pop-ups for AI slop and automated crap. It's unuseable!
I rebooted to linux.
Offline sorveltaja
Yes, Win11 is about everything that Windows should not be. Youtubers who show how to strip out the AI crap and other bloat, to make it more usable, get strikes to their channels.
These are strange times; large companies like Microsoft - they seem to be doing their best to force-feed features that are restrictive and whatnot, perhaps to show that they still have final say, of what the consumers 'want'.
Such a powerful entity - one doesn't have to be a fortune-teller to see that it continues using same tactics over and over. By blindly doing that, it has managed to create resistance against itself.
That's probably the most positive thing it has successfully achieved.
For Windows users looking for alternatives, be it downgrading to Win10 to support their not so latest hardware, which Win11 makes obsolete anyway - or looking out to test Linux - it's such a jungle out there.
What comes to Linux, there isn't such thing as "best Linux distro for new users", as many Linux users (on Youtube) seem to presume. If this or that distro works for them, that's fine, but why assume that new users see it like they do.
Besides that, there are Linux users (some pretty advanced), who have made tutorials in more understandable, plain language.  I wish I could put out some examples with links, but it's so vast subject to cover every aspect.
« Last Edit: February 04, 2026, 10:03:58 AM by sorveltaja »
Offline sorveltaja
Re: Experiences, thoughts and rants about using Linux as a newbie after Windows
« Reply #28 on: February 03, 2026, 01:10:13 PM »
And when considering installing other 'system' apps, they may well drag whole DE with them, so it's worth looking at what kind of dependencies they may have
So that seems to be happening especially with Gnome-based apps. If one prefers to use other desktop environment (DE) like KDE, Cinnamon or XFCE, and wants to install a simple text editor, and reboots the system - boom - then Gnome may well be the new default DE, without informing about it.
Again, better versed Lunduke's take on getting "Gnomed" (~10 min):  _https://www.youtube.com/watch?v=suxMvUuFDMw
Not exactly same or only Gnome-related, but similar thing happens, for example, when installing a file manager. It pulls Bluetooth support/components with it as well.
I understand that it might be needed for devices like BT printers, but for those of us that doesn't have/use Bluetooth, it's totally unnecessary bloat.
If the user then wants to remove those Bluetooth components, that file manager gets removed with it also.
From Windows user's perspective, what I don't quite understand about Linux world is forced dependencies (if that's the correct term).
In the end, a thing that I hadn't noticed until recently - it's worth checking, if the firewall is installed and enabled. I guess on most popular desktop distros it is, but at least on Debian it doesn't seem to be installed out of the box. One option is to use ufw (Uncomplicated Firewall). In that case, to see if it's installed, enter command using terminal:
Code: [Select]
sudo ufw status
If the result is:
Code: [Select]
sudo: ufw: command not found
then to install and enable it in one go:
Code: [Select]
sudo apt install ufw
sudo ufw enable
Resulting message verifies it's up and running:
Code: [Select]
Firewall is active and enabled on system startup
« Reply #29 on: February 04, 2026, 08:17:51 PM »
"a text editor" "a file manager" "Linux world is forced dependencies"
Lot of generalizations there. There are plenty of text editors that don't force Gnome to become the default DE, etc. etc. and there is no one "Linux world.
Most everything in any flavor of a linux OS, and most every program usable by the hundreds of different linux systems is compiled, with the compiling persons' personal preferences for options, and dependencies.
So somebody thought that the file manager you tried out as a binary (and did not compile yourself) should be built with a capability of using bluetooth for file transfers. Why is that a problem with the "Linux World?"
Naturally nothing out there is going to exactly suit what you want personally down to the last detail. If you don't like what options were included by somebody else as a program, just compile it without them.
The person or persons whose binary you tried were volunteers doing the work and offering it to the public without charge. Hey, likewise you can invest time and effort to change a program whose features you don't like into whatever you want. That's one basic reason for open source code.
I would also like to suggest that the big Linuxes you are generally referring to do try to add as many features and options as possible into complex "user friendly" DEs, and it's not surprising that they are heavily weighted, or that when a program is added, it pulls in massive loads of components for the DE that program was designed for, if you are trying to load it into a different DE.
The flip side of that coin is that a stripped down minimal non-big-time linux system will require some building up to whatever it is you desire in a fledged out OS, and that takes technical understanding which is not as "linux beginner" oriented.
This is just reality -- either people make lots of choices for you and give you a big one-size fits-all system, or you make choices for yourself, which at a minimum requires knowledge of how to do that, and will inevitably require learning and effort.
Offline sorveltaja
« Reply #30 on: February 08, 2026, 01:50:57 PM »
Good points. But no, I'm not saying that "Linux world" has problems. I'm rather attempting to understand and tell about things that I have experienced with Linux, and how differently it works when compared to Windows, the way I see it at this point.
I'm not blaming this or that Linux component of having whatever dependencies. Again, it's more about finding out how that stuff works, and writing down my take on it, for possible readers, who might want to start experimenting with their Linux system.  As should be obvious by now, I'm not pretending to be all-knowing, or too well versed on these subjects; if any reader is more experienced, and knows a better way to verbalize these things, it's more than welcome to explain/clarify things in this thread.
But strong emotional response(s) to seemingly stupid ways, that potential new Linux users tell about issues they don't fully understand - why is that so common phenomenon all around the net? If this thread gets any visibility on the net, what a better way to express things than to get to bare-bones - of how I, as a newish Linux user doing all kinds of mistakes, and attempting to look for solutions and write about them?
Well, whatever the case is, I'm tired of repeating myself here, especially what I wrote before:
Again, as many of us know, Linux discussions can and probably will get pretty heated. I certainly hope that it doesn't have to happen here, on this forum.
« Reply #31 on: February 14, 2026, 03:33:01 PM »
Well, Sorveltaja, a good way to avoid that kind of thing, though I don't agree that it is occurring so far, is not to frame one's own comments as "rants" per the thread title, since it sets up that expectation.
Maybe also express difficulties in the thread as requests for explanations from others (if you want them) rather than enlarging to  characteristics of a Linux world.
"From Windows user's perspective, what I don't quite understand about Linux world is forced dependencies ... "
Offline sorveltaja
« Reply #32 on: February 15, 2026, 06:57:44 AM »
I agree that word 'rant' may not be a proper term to use in this context - at least now I know better.
« Reply #33 on: February 15, 2026, 09:49:49 AM »
Great, and I appreciate what you are doing, and have a better understanding of what you are trying to say.  :beer:
Linux is used as such a broad term these days (for all of us) that it's hard to talk about it as a thing. Originally, and technically it was an open source adaptation of Unix in the form of a kernel for the operating system.
Nowadays, what most people mean by Linux is the operating system plus accessories, languages, desktop environments and application programs rolled into named operating systems, like Debian, Ubuntu, Mint, Red Hat, among  the best known. And many others, Arch, Slackware, Puppy, among a myriad of others, and the one I now use, EasyOS.
About the only thing one can say they have in common is the Linux kernel, which is not even a desktop environment, but a set of primitives usable in terminal. Because Linux is based on Unix, it is a multi-user system oriented towards institutional infrastructure use with many lower privileged users and groups with an extensive permissions structure, and a separate class of administrators who we would normally associate with an IT department.
What has developed since then are many different ideas about what graphical personal computer operating systems should look like, how they should behave, what applications should be included with them out-of-the-box, and what optional programs they should be capable of adding (ie what program repositories they should be able to access).
The way all of the myriad programs and code developed to support this vast set of systems and possibilities was through individuals and groups of people volunteering their time to A.) reverse engineer computers and hardware to develop drivers for them (since almost no hardware mfrs. provided drivers for linux systems). and B.) create systems where blocks of code could be re-used and re-combined into more and more sophisticated applications. To enable this kind of re-use, the concept of dependencies and open-source software was essential.
Offline sorveltaja
« Reply #34 on: February 16, 2026, 06:11:51 PM »
Thanks for clarifying these subjects :beer:.
To get back to testing, I've been using Mint Mate for several weeks, and one thing I've been trying to track/trace is, what causes second long freezes every few minutes or so, when watching Youtube videos using Brave.
I know this is nitpicking, but it's kind of an annoyance. I don't remember that happening in Pop OS (which uses Gnome as a default DE), so perhaps it's more like distro or DE (desktop environment) -related component thing.
So I assume, that there are some background service(s), which can't be handled through Mate's control center --> startup applications. They simply aren't shown there. But it feels like there's timer-related or intermittent service(s) using certain resources with high priority,  causing the hiccups.
To get a list of services, that use timer, can be seen by entering command:
systemctl list-timers --all
In my current system, there's 12 of them:
motd-news.timer                         motd-news.service
fwupd-refresh.timer                    fwupd-refresh.service
anacron.timer                             anacron.service
apt-daily.timer                            apt-daily.service
dpkg-db-backup.timer                dpkg-db-backup.service
logrotate.timer                           logrotate.service
an-db.timer                                man-db.service
plocate-updatedb.timer              plocate-updatedb.service
apt-daily-upgrade.timer             apt-daily-upgrade.service
systemd-tmpfiles-clean.timer    systemd-tmpfiles-clean.service
e2scrub_all.timer                      e2scrub_all.service
strim.timer                                fstrim.service
To get started, one on the top, 'motd-news.timer', is described as "'MOTD ? Message of the Day. "motd-news" is a package that makes a call periodically to Canonical servers to get updated news for support and informational purposes."
Source: https://canonical.com/legal/motd
On that page is also instruction of how to disable that service, so I assume it's safe to do so.
...But the file mentioned in that page doesn't exist in my current system at all, so I created it, adding entry 'ENABLED=0 to it, and rebooted, but that service was still there. Not sure why it doesn't work in this distro/DE. Maybe it does with 'bigger' Ubuntu based distros?
Anyway, alternative way to disable it (and service related to it), is to enter commands:
sudo systemctl disable motd-news.service
sudo systemctl disable motd-news.timer
And to make sure that they don't get automatically triggered/started again, is by masking them:
sudo systemctl mask motd-news.service
sudo systemctl mask motd-news.timer
Reboot to apply the changes.
We'll see how that goes.
« Reply #35 on: February 16, 2026, 06:43:35 PM »
So the strengths of operating systems based around a Linux core are that basically anyone who wants to can come out with their "Linux" and the same for their applications. But it also has a negative effect of creating a Babel of "Linuxs" and it is difficult to know which one will suit a person best -- especially without trying a bunch of them. But to do that, they may be different enough that each requires relearning .
The other problem is that many of these operating systems want to be installed onto hard drive in order to experience them at their full speed and capabilities. While some have so called "liveCDs" or live versions which are run-able without installation, they don't give an adequate impression of the installed version.
One alternative to full installation is to try to run a particular Linux OS in a virtual machine on another system -- a Windows version, for instance. But this often leads to other problems in speed, and usability, particularly if access to ports or other protected primary OS facilities are required. Also it's often tedious to set up and/or run a VM, and they can take up a LOT of space on HD.
A third possibility are some of the very few OSs that can be dual booted beside an existing Windows installation, and are compact enough not to seriously diminish HD space. Puppy Linux (which also comes in a variety of named OS's -- adding even more confusion) is designed to take up minimal space for the entire OS, plus applications (generally a gigabyte or less, total).
Other than the bare OS, all storage for additional applications and data can fit into a single folder within the Windows partition. Puppy linuxs typically are small enough to be loaded entirely into RAM at boot time, including applications. This allows the OS to run extremely fast, since there are greatly reduced disk accesses.
The fourth possibility is an offshoot of Puppy linux called EasyOS -- which is what I use. This OS is also extremely compact, and can be installed like Puppy Linux, beside an existing Windows installation. But the alternative that it is actually designed to work very well with is to run entirely off of a thumbdrive, without even needing the system's HD.
This makes it portable between computers. Everything is on the thumbdrive (unless you choose to store something on the HD). In effect the thumbdrive is the computer, and the actual computer is just transparent hardware that runs it.
Naturally, the faster higher quality thumbdrive will run this OS faster, but remember that the OS is generally loaded entirely into RAM during a session, so it runs at RAM speeds. The only noticeable reduction in its speed for a slower thumbdrive is while booting, or saving back to the drive at the end of the session, or as commanded during the session.
Now, yes it IS possible to install this OS on an HD, and that's what I have because that's all I use, and I want absolute top speed booting or leaving.  And it is truly fast in every aspect on this recent laptop of mine.
Okay so enough about that. Back to Linux based OSs in general.
Applications. Most Linux applications were until a few years ago compiled by the developers of each separate OS to suit their OS (and their taste). Thus applications for one variety of Linux OS probably wouldn't work in a different variety. However things began to consolidate back then when Ubuntu, which had for a long time compiled it's own programs and maintained repositories of custom compiled apps, switched over to using Debian applications and package management. This saved a huge amount of similar but separate effort.
Likewise some of the OSs I'm familiar with in the Puppy Linux family switched over from using first only homebrewed programs to later some Slackware compatibility, and then Ubuntu, and finally Debian apps. But there are still many Puppy-relates OSs that use other OS's repositories and apps. EasyOS presently uses Devuan apps -- Devuan is a fork of Debian.
Anyway, again, Linux is a huge subject if talking about desktop operating systems, and it is almost impossible to quantify. But it is possible to talk about as a history, and that provides some explanation of what it means. It's very different than Windows or MacOS or Android because each of those is a single entity main tained by a single company
« Reply #36 on: February 16, 2026, 06:54:42 PM »
Sorry Sorveltaja, I cross posted the above without seeing yours first -- I was just continuing talking about Linux based operating systems -- not ignoring your questions.
I really don't know why Brave is not working properly in Mint OS. The only place that can help is probably a Mint OS forum, where people can test out using their similar OS and Brave. The variables are 1.) your hardware with MintOS 2,) Mint OS with Brave or 3.) a bug in Brave. Usually takes others to help figure that kind of thing out.
EDIT: I originally mistakenly wrote PopOS above instead of MintOS -- now corrected.
Also, wow, that's a LOT of timers. But not totally surprising. Mint is (or was) based on Ubuntu, and promoted as an even more user-friendly OS. So my old and possibly wrong impression of it is, that it might be even "bigger" then Ubuntu, in terms of stuff running and user stuff added on. But I'm really not familiar with it enough to really say.
Offline sorveltaja
« Reply #37 on: February 17, 2026, 09:40:34 PM »
No problem. Expanding these subjects to provide a wider perspective and background information, it's always welcomed.
Anyway, musings about Brave hiccups:
It appears that motd-news.service, or other Linux services aren't necessarily causing the hiccups in Brave; maybe it's the browser itself, or the way it works in this distro.
I turned off Brave's AI features, Wallet, Rewards and Brave newsfeed as well, but still the issue persists.
I've watched some Youtube videos with Waterfox, and so far haven't experienced such an issue. But this is by no means a definite or final analysis.
In the end, I think I'm moving from Mint Mate back to Debian or another distro which has an option to select Mate as a DE, as I'm getting relatively familiar with the way it looks and works.
Offline sorveltaja
« Reply #38 on: February 19, 2026, 11:11:44 AM »
Yesterday something happened, that messed up my Linux system (it's still Mint Mate).
My main web browsers, Waterfox and Brave don't launch anymore (they are both flatpaks). Even their taskbar launch icons have changed. Those app related files, and actual executables are still there in the folders, and can be launched from there, but all the settings and bookmarks are gone. Like a sort of "zeroing" or reset.
I have a separate Win7 disk connected, which I was able to access before from Linux, but now I get an error:
"Error mounting /dev/sda2 at /media/<username>/xxxxx: Filesystem type ntfs not configured in kernel"
Updating the system through control center or terminal keeps on failing, throwing errors.
I can't verify it, but there's a possibility, that my Linux system has been compromized.
"I'll test this distro only shortly", using rather weak password. But that "short" testing has already expanded to several weeks. To add to that, I haven't made any system backups either. I have just felt it to be a boring task. But reinstalling the system, redoing all the settings to preferred state, and installing preferred software, is outright tedious.
My important personal files are not lost, though. They are about the only ones I've almost regurarly copied to either usb stick or separate disk.
So this is an example and warning of how not to manage an operating system.
Also, It's always a good thing to have another working, or fallback system, when this kind of thing happens. Whatever OS or device it is, as long as one is able use it to pay the bills, read email, and browse the net, among other basic things.
« Last Edit: February 19, 2026, 11:48:18 AM by sorveltaja »
« Reply #39 on: February 19, 2026, 11:50:54 AM »
That's terrible, sorveltaja!  :scratch:
I've never had that happen or anything like it.
I would like to help, but I don't know the details of your installed system. I do suspect it is possible to fix it, but I'd need a lot more information to work with.
If I remember correctly you are running Mint in a virtual machine in a Windows system?
Okay, just as a start at recovery, would you be adverse in creating an EasyOS thumbdrive, and then booting from that so we can look at what's happening on your HD? I'm really most familiar with EasyOS and its tools for that.
To create an EasyOS thumbdrive, if you are able to get the following files into Mint (or any other Linux):
easydd makes bootable thumbdrives and installs an OS image to it:
https://bkhome.org/files/easydd.gz
And the latest version of EasyOS (7.2):
https://distro.ibiblio.org/easyos/amd64/releases/excalibur/2026/7.2/
Usage:
Just insert a USB thumbdrive of 4 or more Gb and start easydd. It will ask you for the location of the image file (the EasyOS 7.2 version you downloaded), and the thumbdrive name. The rest is automatic.
When done, you can re-boot with the USB thumbdrive inserted, and if your computer BIOS is set to be able to legacy boot from USB (before the HD) EasyOS will start up. Answer the first boot questions about country and keyboard, etc. and you'll be good to go.
Let me know if you do any of this, and we can go further.....
ps.
If you can't use Mint (or other Linux OS) to download or run the above files, but you can still run Windows, you can use a program called USB-Image-Tool to write the EasyOS image to a USB thumbdrive. (It is not recommended that you use any other Win USB image writers ...like "Etcher").
USB-Image-Tool is available here:
https://www.alexpage.de/usb-image-tool/download/
« Last Edit: February 20, 2026, 04:42:51 PM by vtsteam »
« Reply #40 on: February 20, 2026, 04:10:04 PM »
May not be related to your problems , but windows has a bad habit of flagging disks as mounted and locked and not releasing them .
I have this problem if I launch Win11 and it sees my backup disk (which is ntfs ) . when i swap back to linux, the disk will be locked out until I run chkdsk in windows on it a couple of times.
Win 11 is just a PITA.
Offline sorveltaja
« Reply #41 on: February 21, 2026, 04:52:46 PM »
Vtsteam:
Thanks for the offer, good to know.
I should have been clearer about the subject. It (Linux system) isn't VM instance, but actual install on my pc. That Mint Mate installation is still accessible. It boots just fine, but some parts of it are apparently broken.
For example, when trying to uninstall Gimp, it gives following errors:
Code: [Select]
(Reading database ... 571681 files and directories currently installed.)
Removing gimp (2.10.36-3ubuntu0.24.04.1) ...
Setting up linux-image-6.17.0-14-generic (6.17.0-14.14~24.04.1) ...
Setting up linux-headers-6.17.0-14-generic (6.17.0-14.14~24.04.1) ...
/etc/kernel/header_postinst.d/dkms:
 * dkms: running auto installation service for kernel 6.17.0-14-generic
Sign command: /usr/bin/kmodsign
Signing key: /var/lib/shim-signed/mok/MOK.priv
Public certificate (MOK): /var/lib/shim-signed/mok/MOK.der
Building module:
Cleaning build area...
make -j6 KERNELRELEASE=6.17.0-14-generic -C /lib/modules/6.17.0-14-generic/build M=/var/lib/dkms/virtualbox/7.0.16/build...(bad exit status: 2)
Error! Bad return status for module build on kernel: 6.17.0-14-generic (x86_64)
Consult /var/lib/dkms/virtualbox/7.0.16/build/make.log for more information.
dkms autoinstall on 6.17.0-14-generic/x86_64 succeeded for nvidia
dkms autoinstall on 6.17.0-14-generic/x86_64 failed for virtualbox(10)
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
 * dkms: autoinstall for kernel 6.17.0-14-generic
   ...fail!
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 11
dpkg: error processing package linux-headers-6.17.0-14-generic (--configure):
 installed linux-headers-6.17.0-14-generic package post-installation script subprocess returned error exit status 11
dpkg: dependency problems prevent configuration of linux-headers-generic-hwe-24.04:
 linux-headers-generic-hwe-24.04 depends on linux-headers-6.17.0-14-generic; however:
  Package linux-headers-6.17.0-14-generic is not configured yet.
dpkg: error processing package linux-headers-generic-hwe-24.04 (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic-hwe-24.04:
 linux-generic-hwe-24.04 depends on linux-headers-generic-hwe-24.04 (= 6.17.0-14.14~24.04.1); however:
  Package linux-headers-generic-hwe-24.04 is not configured yet.
dpkg: error processing package linux-generic-hwe-24.04 (--configure):
Processing triggers for desktop-file-utils (0.27-2build1) ...
Processing triggers for mate-menus (1.26.1+mint1) ...
Processing triggers for man-db (2.12.0-4build2) ...
Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
A package failed to install.  Trying to recover:
Building module:
   ...fail!
Processing triggers for linux-image-6.17.0-14-generic (6.17.0-14.14~24.04.1) ...
/etc/kernel/postinst.d/dkms:
Building module:
   ...fail!
run-parts: /etc/kernel/postinst.d/dkms exited with return code 11
dpkg: error processing package linux-image-6.17.0-14-generic (--configure):
 installed linux-image-6.17.0-14-generic package post-installation script subprocess returned error exit status 11
After all, it's not a critical system for me, and as mentioned earlier, I've been planning to replace it with another distro anyway.
BillTodd:
It seems you aren't the only one having things like that happen. Rob Braxman has a video where he describes how Win11 and TPM made his dual boot Linux installation inaccessible, without asking or informing about it (~21min):
 _https://www.youtube.com/watch?v=t1eX_vvAlUc
« Reply #42 on: February 21, 2026, 07:08:50 PM »
Hi Sorveltaja, sounds like there are linux kernel problems. I wonder if the flatpaks might have had a hand in  that. Generally it is thought on the boards I am on that flatpaks are problematic, while appimages are much preferred. Explanation to others unfamiliar with the terms.... these are a relatively recent form of "generic" application packages. Each uses a different method but they basically have all needed dependencies built in, and are supposedly OS agnostic. They are supposed to be able to be installed and work in any Linux.
As I said though, it seems flatpaks are not viewed favorably, at least in the Puppy Linux/EasyOS world. Appimages seem to work very well.
Offline sorveltaja
« Reply #43 on: February 22, 2026, 03:07:29 PM »
Yeah, I pretty much like the idea of appimage. I went and searched Waterfox one, and thought that 'appimagehub' was a legit source.
Anyway, when launching the expected browser app downloaded from that site, it showed only a text file, which begins like that:
Code: [Select]
!!!DON'T USE APPIMAGEHUB!!!
        .--.         _
       |o_o |       | |
       |:_/ |       | |
      //   \ \      |_|
     (|     | )      _
    /'\_   _/`\     (_)
    \___)=(___/
**Many AppImages on the platform come from unknown or suspicious users.**
I have no idea of what's going on that website, or is it a scam or prank or whatever. So obviously one has to be careful where to download appimages.
On a positive note, there is a site, where the actual Waterfox appimage (among many other apps) is available. I tested it, and it worked right away.
This is about a single app, but it seems that Github-related sites might be more thrustworthy  trustworthy source:
https://appimage.github.io/
« Last Edit: February 22, 2026, 07:13:28 PM by sorveltaja »
« Reply #44 on: February 22, 2026, 05:36:29 PM »
Yes I agree, all of the appimages I have used were from github, where everything is very transparent. That is where the source code is kept, and issues can be logged, and also the original authors are the ones who have posted and maintained the code there.
Also, a lot of large single application websites also now host appimages for their own applications on their own download page and those are trustworthy.
But third party websites aren't as trustworthy since who knows where the code they are hosting comes from?
Offline sorveltaja
« Reply #45 on: February 24, 2026, 02:15:25 PM »
So I replaced Mint Mate with Debian: https://cdimage.debian.org/debian-cd/current/amd64/iso-cd/debian-13.3.0-amd64-netinst.iso
It really doesn't appear to be that different from server-based one, that I tried earlier; about the same amount of basic apps installed out of the box.
What comes to appimages, although they include all dependency files, they may not work, if required version of fuse-related components aren't already installed.
On the other hand, another form of portable apps is to use either zipped or tarball (.tar.bz2) versions, if available. They don't seem to require mounting, or any extra system components to be installed, to be able to work.
An example in this case is Waterfox: https://cdn.waterfox.com/waterfox/releases/6.6.8/Linux_x86_64/waterfox-6.6.8.tar.bz2
To use it, first that file needs to be extracted. In file manager --> right-click --> extract here. Resulting folder is 'waterfox'.
In that folder is a file 'waterfox-bin', which is the actual executable. If it doesn't launch by double clicking, make sure that it has permission to do so, by right-clicking it --> permissions --> Allow executing file as program.
Another example is Mercury browser. which is a fork of Firefox: https://github.com/Alex313031/Mercury/releases
I've used it as a secondary web browser since I started using Linux almost a year ago. It has never required anything extra system components to be installed either; it just works. Unfortunately it's bit outdated, but nevertheless, it has worked well for me.
« Reply #46 on: February 24, 2026, 06:59:32 PM »
Yup I use Seamonkey, downloaded from Seamonkey/Mozilla as a tarball, and it is quite portable and self contained. It's a suite of browser, mail, and html authoring software -- actually the distant grandchild of Netscape.
I like it particularly because of the way all settings are granular and in the preferences menu -- old fashioned style. I pair that with NoScript and disallow scripts generally, allowing them only temporarily as needed on a particular webpage. You quickly learn which ones are needed and which ones are not.
Lately some sites have been making it difficult to use, (Cloudflare, for one) but I have workarounds for that, or just avoid those sites in general.
Offline sorveltaja
Yesterday, when I updated my Debian 13 installation, using commands 'sudo apt update' and 'sudo apt upgrade', it went well without errors.
But when I rebooted the system - it booted only to tty(no gui, command line mode).
It appears that the new kernel 6.12.74+deb13+1-amd64 might have  caused this issue.
But in the boot screen, when selecting advanced options, one can see what kernels are installed. In this case I chose the older one, 6.12.73+deb13-amd64, and it booted just fine, as it used to previously.
So, one option to get back to the OS, is to set the old kernel as a default, when booting, instead of new one.
I'm not quite sure, if this is the only way to do so, but anyway, I edited grub:
Code: [Select]
GRUB_DEFAULT=saved -- previously that value was 0
GRUB_SAVEDEFAULT=true -- this line is a new addition
Now, when selecting that old kernel when booting, it *should* stay that way. At least it seems to do so in my case.
It's bugger when things like that happen - of course there is an option to use the installation media to access recovery mode, but I find it to be cryptic, especially when I had no idea, that the issue wasn't necessarily about existing hardware drivers, but possibly about new kernel conflicting with some of them.
In the end, I tried several things from different sources to fix the failed, updated kernel, but meh, I rather keep on using the old one.
What kind of precautions there might be, just in case that this happens again, when trying to update the system? Make a backup every time before attempting such?
What you describe is one of several causes for my abandoning Ubuntu after finding Puppy linux. I had so many problems during upgrades and updates that I got discouraged by Linux in general. I wanted something that was more stable and wasn't pushing to constantly upgrade. Puppy Linux provided that for me, with an average usage period for any particular version of 3-4 years in my usage.
I think one thing to realize is that the only real need for updating and upgrading an OS generally (once you have a stable system with a full range of usable applications to your preferences) is the browser's and web facing app security requirements -- which are constantly changing with new threats, and language and data form changes.
I don't do a lot of application program updating, since most programs I use, even complex ones like CAD, CAM, and video editors, suit me fine as-is. and sometimes upgrades produce a version I like less than the older one they replace.
A possible alternative scenario for dealing with the continual changes needed by web facing apps is to isolate or even containerize them within the operating system. This is an approach taken by EasyOS. If you are then satisfied with the performance of your other apps and the version you have of the OS, continual OS and application updates are not necessary -- unless you are interested in the relatively experimental side of the operating system. But it is possible to, and many have in both Puppy and EasyOS, work continually with a single operating system version for years, without upgrades.
Offline sorveltaja
I'll admit that I keep ignoring the saying 'if it ain't broken, dont fix it'. There really wasn't any reason to do system update - it was rather a test of how it goes.
Web browser that I use for banking is about the only app, that actually needs regular updating.
Anyway, to update Brave browser:
Code: [Select]
sudo apt-get install --only-upgrade brave-browser
And for Waterfox: Settings --> General --> Waterfox updates --> Check for updates.
So yeah, I have no problem using old versions of apps - have done that in the past, and still do it in Win7.
As I probably have mentioned earlier, Paint shop pro 8 from 2003 is my main graphics app, be it Windows or Linux, using Wine.
Another one is Office 97, that I've used in Windows. Its installer doesn't work anymore, but it doesn't actually need to be installed; Excel and Word work simply by going to folder that includes Office programs, and clicking whatever executable/app is desired.
But lately, I've started also to use Libreoffice, just because its spreadsheet app (Calc) allows more data to be inserted, than '97 Excel, which has a limit of 65535 rows.
