Author Topic: 1/16 scale Terramac RT7R  (Read 108555 times)
Offline ddmckee54
« on: July 22, 2025, 08:21:42 PM »
About 3-4 months ago, my Project Muse turned into a real slave driver.  The muse decided that I wasn't busy enough, what with yard work, looking for a new daily driver to replace the one that got totaled in late April, and all the other projects the Muse already had me working on, I NEEDED another project.
I really have no one but myself to blame.  While watching the Designs In Orbit video series documenting the rebuilding of 40+ miles of the CSX railroad's track that were destroyed during the Hurricane Helene flooding, the rotating tracked dumpers were bright and shiny enough to catch the Muse's eye.  Can't really blame the Muse, they're cute little things as far as construction equipment goes.  We watched enough of the videos that we determined the rotating tracked dumpers were Terramac's RT14R.
A 3-view was found on their website and, with a little computer tom-foolery later, I had a JPG file that I could import into Alibre and start 3D modelling the beast.  I was making pretty good progress, right up to the point where Murphy threw his monkey-wrench into the works.  You see, to save myself a lot of headaches I'd been planning on using Bruder excavator replacement tracks for the dumper.  The monkey-wrench delivery was triggered by the fact that at scale, the RT14R's tracks are over 60mm wide - the Bruder tracks are 40mm wide.  The RT14R wasn't gonna happen, this was the cause of MUCH whining and complaining from the Muse.   After about a week of the Muse's complaining, and being told that there was an RT7R on Terramac's website, AND that the Muse was positive that 7R's were also used on the jobsite...  I gave up, got the 3-views and promptly checked the track width.  Humphh... 43mm, that's close enuf for Gub-mint work.  I guess we're gonna do this thing.  In case you're wondering, this is what a Terramac RT7Rlooks like.
Like I said, cute little thing.
Design work started with the important stuff, the tracks and lower frame.  The following images show the progress of the Alibre RT7R assembly drawing as the various bits and pieces were added.
Then design work started on the dump bed.  I had noticed that I didn't have anything to keep the tracks from rubbing on the top of the track frame, so I added a guide strip.  I also added a sample track plate so I could check for future clearance issues.
The dump bed was completed , and work on the upper frame and rotating assembly was started.
The bed lift mechanism was then designed.
It took many attempts, and visiting several DIY scissor lift websites, before I had a version that could fold itself into the 21-22mm space I had available.
The working lift was then added to the 7R's assembly drawing.
By this point the back half of the model was basically done so it was time to start on the front.
TO BE CONTINUED....
Re: 1/16 scale Terramac RT7R
« Reply #1 on: July 22, 2025, 09:19:08 PM »
Interesting tailgate on that thing.
I can imagine a boulder hitting it when the dump body is halfway up. A virtue of a conventional tailgate is that it can be hinged at the top or bottom, or dropped completely. If hinged at the top and chained partially open at the bottom, a controlled dump can feed material over a longer distance as the truck moves forward. Blacktop, gravel, crushed stone. etc.
Offline ddmckee54
« Reply #2 on: July 22, 2025, 10:40:03 PM »
I started work on the engine/cab/tanks platform at the front of the machine.  This is the platform and the engine bay.
This shows the platform, the engine bay, the hydraulic oil/fuel tanks and the cab walls.
It was about this time the operator demanded that I print out his new :office chair", so he could see how well it fit his butt.
There were some complaints, the seat back needed to be tilted back, the headrest needed to be tilted forward, the top third of the headrest needed to be lopped off cause it looked STOOPID, and the joystick was located under his wrist - not in the center of his grip where it belongs.  SOOOO... the fixes were put in.
The mechanic was so pissed that he had to sit in the REJECT he said he was gonna hold his breath until he turned blue.  So far he's only managed to turn his clothes blue, but ya gotta give him an E for effort.
It was about this time that the Muse wanted to know what an opening door would look like.  I was done with the bed design so I started printing the bed parts.  This is about 9-10 hours into 14 hour print, things weren't looking good, there was a LOT of stringing.
The stringing was bad, but that wasn't the worst part.  The nominal dump bed width was 135mm, the rear section printed at 134mm, the center section printed at 139mm and the front wall printed at 136mm.  I spent 2 days trying, and failing, to correct this using the slicer's scaling.  I finally said screw the scaling, and used brute force.  I went back to the method I used to get my 1st 3D printer to actually print ROUND holes instead of ellipses.  I use the M92 command in the g-code start-up script to modify the printer's X, Y, and Z steps/mm settings.  To find out what the factory settings were, I hooked the slicer up to the printer and sent the M503 command to the printer.  That tells the printer to print the settings it has in memory back to the slicer's screen.  Next I needed a quick and easy way of calibrating a large object.  What I came up with is my calibration square, a square with 100mm outside dimensions, 2mm thick walls, and a Z height of less than 1mm.  Best of all it only takes about 2 minutes to print.  The first time I printed the square it measured about 98mm, with X being over-sized, and Y under-sized.  I made some adjustments and tried it again, this time it measured in at about 99.5mm.  One final tweak and it measured 100.1mm, +/-0.05mm in both X and Y.  Close enuf for Gub-mint work.  Once I finally gave up on the slicer's scaling, it took less than 2 hours to do what I failed to do in 2 days using the slicer's scaling.  This is the completed dump bed parts.
It was about this time that the Muse decided I needed a "side project", a working hidden hinge for the engine bay door.  After about 3 days and many failed attempts, I finally had a design that worked.
So I printed out the last of the yellow parts.  Here's a family photo.
The operator was so excited he decided to jump in and take his new ride for a spin.  When it wouldn't start he called the mechanic over to check out the problem.  When the mechanic popped open the engine bay door he started yelling, "We've been robbed, we've been robbed!  They took everything."
I'd have liked to get a little more of an opening, but there's only so much that you can get folded into a 10mm thickness.
That's it for the yellow parts, on to the grey.
TO BE CONTINUED....
Offline ddmckee54
« Reply #3 on: July 22, 2025, 10:44:09 PM »
vtsteam:
The tailgate is optional, I decided to delete that option on mine.  They don't usually put them on the "rock: beds.
Offline ddmckee54
« Reply #4 on: July 23, 2025, 12:30:14 AM »
The grey parts, there's so many of them, where to start... the cab, THE CAB.  The  operator has been complaining about the cheap-skate boss who won't even put a roof over his head.  That'll put him in his place - literally.  I ran the calibration square using the grey filament and made the required changes.
Now, not only has he got a roof over his head, he's got 4 walls, a floor and a control panel - with buttons and knobs to play with.  Unlike Les Nessman's office, the walls do not involve masking tape on the floor.  I guess that masking tape is sort of involved, since that's what's keeping the floor from dropping out from under his feet.
Onto the BIG grey pieces.
What we have here are the major parts of the lower rotating assembly.  Clockwise from the right they are: the main frame, the slew gear - with the slew bearing installed, the slew gear spacer. and the upper slew bearing clamp.  The upper slew bearing clamp, slew gear, and slew gear spacer will get bolted to the main frame, the pockets for the M3 heat set inserts are visible in the main frame.  The big hole in the main frame is where the slip-ring that feeds the track drive gearmotors will live.  The upper slew bearing clamp keeps the slew bearing from pulling out of the slew gear and firmly attached to the main frame.  A lower slew bearing clamp will live in the large hole in the slew gear spacer.  That clamp will keep the upper half of the rotating assembly firmly attached to the slew bearing, and all will remain right with the world.  The key-hole shaped notch in the slip-ring hole gives me access to install the M3 screws that will bolt the lower slew bearing clamp to the upper center frame.  Since that picture was taken another couple of piles of grey parts have been added, 17 bogie side plates, and 10 bogie wheels.  I meant to print 2 extras of each, but I only printed 1 extra side plate.  The printer is currently 6 hours into an 8 hour print on the engine bay base and the tanks bay base.
This will give you some idea of what's under the hood in the engine bay and tank areas.
Side project #(??? - I don't know, I lost count.)
This was a test to see if you can easily replicate an open grid using an FDM printer, and yes Virginia, you can.  This would normally be a solid object 2mm thick with a grid infill pattern.  However, when you tell the slicer to use 0 bottom layers and 0 top layers, you get the above.  Then I got to wondering if I could use a variation on that to print something like this.
Turns out yes you can.
These two used almost the same STL file as the 1st experiment, only the thickness was reduced from 2mm to 0.6mm.  They were both printed with 0.2mm layers, 2 bottom layers, and 0 top layers - which left 1 infill layer.  The guy on the left was printed at 30% infill while the guy on the right was printed at 75% infill.  With my 0.4mm nozzle that's way too small, 60% might be about as small as I'd go.
I've still got a lot of grey parts to print, the idler assemblies with the track tensioners included, the bed lift assembly, plus God only knows what else.  Then there's the black doo-dads to print, the fuel fill cap, the hydraulic tank vent, the exhaust stack, the front guard rail, the headlight covers, the work platforms...
But that is the current state of affairs with this project.
« Reply #5 on: July 23, 2025, 09:38:07 AM »
That's very impressive work, to say the least!!  :clap:  :bow:  :beer:
« Reply #6 on: July 23, 2025, 09:40:59 AM »
I like the fact that you added a backhoe to the engine bay in black. Must make the vehicle very versatile!
Offline ddmckee54
« Reply #7 on: July 23, 2025, 12:08:53 PM »
I probably should have explained what the objects in the cross section view through the engine bay and tank areas, actually were.
If you haven't already figured it out, the yellow object in the background is the bottom of the dump bed.  The green object in front of it is the bed lift mechanism.  The cyan colored object is the 10 channel receiver, I'll only be using 7 channels though.  The red objects, below and to the right of the receiver, are a pair of 6V, 2400mAH, NiMH battery packs that will be wired in parallel.  (Should give me plenty of run time.)
The black object in the engine bay, below and to the left of the receiver, is the cooling fan.  It will suck air through the hole in the engine bay door.  The cooling air will be directed, by various bulkheads and baffles, first over the track drive ESC's, then over the ESC's for the bed lift motor and the slew motor, then over the batteries, before exiting through openings in the cab side of the engine bay.  The track drive ESC's aren't visible in this picture, but they will live on the left side of the grey baffle in the tanks.  That baffle is visible over the upper edge of the cross section in front.  The other ESC's are BARELY visible, they are the orange bits that are just peaking over the cross section edge on the right side of the tank baffle.
That takes care of the upper part of the rotating assembly, now we'll drop down to the lower part.  The dark blue object is the LH track drive gearmotor.  The grey object in front of the gearmotor is the LH track frame assembly.  The four bogie assemblies are below the frame, and the track tensioner/idler roller is on the far left,  The bogie rollers and the idler roller will a run on a pair of 5mm ID x 9mm OD ball-bearings.  The black objects below the bogies are a section of the track plates, so I could verify clearances.  The purple object on top of the track frame is the guide strip that keeps the track from rubbing on the frame.  The black bit on top of that is a track plate, this allowed me to check clearances between the upper rotating assembly and the lower rotating assembly.  I've got about 2mm of clearance now but if I need more, I'll print a new slew gear spacer that's a couple mm thicker - Eazee-Peazee.
I thought that I had a better, more recent cross section view that ACTUALLY shows what's under the hood, but apparently I didn't save that image. If you want to see it, I can upload that newer view along with the cross section that shows what's buried inside the actual rotating assembly.
Offline ddmckee54
« Reply #8 on: July 24, 2025, 11:16:44 PM »
OK, OK... so I made a door for the cab. I told the Muse I wasn't going to make a WORKING door, and I DIDN'T. Instead I made a door skin, and some fake hinges that got glued on to the side of the cab.
It looks better in real life. The flash washes out all the shadow lines, but it does let you see the operator much better. I may still take my plastic scriber and scribe around the door, now that I've got a good solid edge to guide the scriber. Or I may not, depends on how ambitious/lazy I feel.
« Reply #9 on: July 25, 2025, 07:24:02 AM »
Looking good... :clap: :thumbup:
Offline ddmckee54
« Reply #10 on: July 28, 2025, 03:50:51 AM »
In the last couple of days I've been busy figuring out how I could modify a 13 rpm 3D pen's extruder drive, with a worm gear output for the final drive, into my slew motor.  Also figuring out just how much other stuff I'd need to modify, because SOMEBODY didn't bother to figure this out BEFORE he slapped everything together in the assembly drawings.
Fortunately, none of the modifications were extensive.  The 3D pen extruder has a worm output gear, and a straight cut gear, both are pressed onto what looks to be about a 1.5mm shaft.  What I am starting with looks very similar to this.
I had to order a small gear puller set that will allow me to pull the gears off the shaft, and press everything back together when I'd done with the modifications.  I'll need to make a new output shaft, one that's nearly 20mm longer than the existing shaft.  I've no doubt that I'll need to order some stock to make that shaft.  I also need to go from the 1.5mm shaft to a 4mm shaft, for the 14T GT2 pulley that I'm using for my slew gear pinion gear.  I've got some 5mm stock I'll use for that.
I discovered that some how, somewhere along the line I had changed my mind about exactly where I was going to put the slew motor.  I started out with the planned location being on top of the platform.  I think it probably changed about the time I decided to put a seat, and an operator, and a control panel in the cab.  Because some Doofus didn't 3D model this change at that time, when I got around to it - I was in trouble.  By that time I had received the 14T pulley, which was also about 12mm longer than I was expecting - I can only get rid of about 4mm of that 12.
BUT... I've still got to bury the slew motor gear box, which is 10mm thick, into the upper frame - which is 12.7mm thick.  AND, has 5mm deep wiring tunnels dug right where the slew motor needs to go.  I can sink it about 5mm into the upper frame. but I need to gain at least another 5mm somewhere - maybe more.  I added another 5mm to the height of the spacer ring that positions the slew bearing, modeled the 14T pulley as short as I could get it, and checked the 3D model for interference.  I still had interference between the tracks and the bottom of the slew pinion - so I added another 2mm to the spacer ring.  I now have 1.7mm clearance between the tracks and the slew pinion as the pinion rotates over the tracks.  (That's good enuf for Gub-mint work!)
Between the slew motor debacle, and the GT2 pulley being 12mm longer than expected, I had to add over 9mm to the space between the upper and lower frames.  It's starting to look a little ODD.  I think I can lose some of that extra height by eliminating the upper and lower slew bearing clamp rings, which are both 3-4mm thick.  The upper clamp ring holds the inner race of the slew bearing to the upper frame, while the lower ring holds the outer race to the lower frame.  The rings are each held on by six M3 button head screws.  If I eliminate the rings, and use the just button head screws - and flat washers - to hold the races in place, I can probably lose about 6-7mm of the extra 9 that I added.  Which should help to eliminate the too tall look.  But doing that means I need to change the positions of the pockets for the heat set inserts in the lower frame - which is already printed.  (Nope not changing that one, maybe just the upper clamp ring?  We'll see.)
« Last Edit: July 28, 2025, 04:57:43 AM by ddmckee54 »
Offline jiihoo
  • Finland - Northern Europe
« Reply #11 on: July 29, 2025, 05:40:56 AM »
You do fine modeling work. Enjoying following this!
Offline ddmckee54
« Reply #12 on: July 30, 2025, 08:28:14 AM »
After looking at this problem, the adding of 9mm of extra height between the upper frame and the lower frame, I've come to the conclusion that I'm going to have to live with it.  I worked on the rotating assembly for the last couple of days and didn't accomplish much.  Let's look at my version of an 800 pound gorilla.
What you're looking at is the heart of this machine, it's what I call the rotating assembly.  The major players in the rotating assembly are the following:
1) The upper center frame, that's the dark grey piece in the upper center. The dark brown piece is one of the upper frame rails, these rails are bolted to the upper center frame and support everything on the top half of the machine.  Inside this part is where the slip-rings that feed power to the main drive motors live.
2) The slew gearmotor, that's the olive drab object.  It's a repurposed 3D pen extruder drive.
3) The slew motor clamp, it's the dark purple bit.  This keeps the slew motor in place, and allows about 1mm of motor adjustment for pinion mesh.
4) The slew gear pinion is the light purple object in the center.  The slew gear pinion is a modified 14T GT2 timing belt pulley.  Numbers 1-4 make up the top half of the rotating assembly.
5) The slew gear is the cyan colored object behind the slew gear pinion.  Not shown is the slew bearing, it lives inside the slew gear, the inner race of the bearing is clamped to the upper center frame.  The outer race is a press fit in the slew gear.
6) The pinkish object is the slew gear spacer.  The clamp that holds the inner race of the slew bearing to the upper center frame lives in a space inside this spacer.  Six M3 bolts will keep the clamp attached to the upper center frame.
7) The dark green object above the slew gear is the slew gear clamp.  Six M3 bolts will go through the slew gear clamp, the slew gear, and the slew gear spacer, to keep these parts firmly attached to the main frame. (That' the light grey object at the bottom.)
In real life, what you are looking at is MAYBE 100mm wide by 50mm tall.  The slew gear pinion is a modified 14T GT2 timing belt pulley.  I initially thought that I could eliminate the flanges on this pulley and gain about 11mm of space.  Not so much, there are still 2 problem areas.
Problem area #1 - There is about a 1mm gap between the dark purple slew motor clamp, and the dark green slew gear clamp.  No matter where it is in its' rotation, about 2-3mm of the slew motor clamp overhangs the slew gear clamp.  No extra room here to eliminate.
Problem area #2 - The black object directly below the slew gear pinion is a track plate.  Twice in its' rotation the slew gear pinion will swing over the track plates.  Only about 1-2mm of the pinion will swing over the plate, but it does swing over it.  There's currently about 2mm of clearance, again nothing extra to eliminate.
Like I said, I spent a couple of days working on this and other than making some pretty pictures I didn't get much done.
Sooooo.... PICTURE TIME!
Ignore the dark blue in the dump bed, I didn't realize I had a surface selected when I exported this image.
This is another, and better, view of what's under the hood in the engine bay an tank areas.  It's a cross-section view with all but about the lower 20mm of the engine bay and tank walls removed.
I just now noticed that the work platform in the foreground is not correct.  The angled part of the platform should be to the front.  This is a 2 piece assembly, and I'm going to have to remember to build them as mirror images, not duplicates like they are now.
Offline ddmckee54
« Reply #13 on: August 16, 2025, 11:05:34 AM »
I've had a couple of set-backs in this project, and MOST of them are related to the M3 heat-set inserts that are SUPPOSED to hold things together.
Set-back #1 -
I recently installed the inserts into the upper and lower frame parts, I was trying to make the go roundy-roundy bits do exactly that.  As I was installing them I noticed that they were going in rather easily.  After I got all 2 dozen of them installed and started bolting things together, and MOST of the inserts failed when I tightened the bolts, I went looking for the culprit.  Turned out I was the guilty party.
The frame parts were the first one designed, before I found and fixed the X-Y dimensional accuracy problem.  Prior to fixing that problem my heat-set insert pockets would print under-sized, my solution was just to make them over-sized in the CAD model.  Soooo... after I fixed the X-Y problem, my over-sized heat-insert pockets ALL printed over-sized.
Set-back #2 -
I Could try gluing the inserts in, but MOST of them are going to be under enough stress from the rotating upper frame that I'm not comfortable doing that.  I don't think I've got enough filament left on the spool to re-print all the grey parts, and I couldn't find a manufacturer's label on the spool, so I just had to order some and hope for the best.  The colors DON'T match.  So I'm going to have to re-print most, if not ALL, of the visible grey parts.
Set-back #3 -
The grey filament that I was using was several years old, this made it stiff and brittle.  If the printer sat unused for several days the stresses caused by just unwinding it would eventually cause it to break.  I was working on the filler block that I need to install in the main drive gearmotors, before I clip the front corners off the gearmotor cases.  When I tried to print them out, I got a print failure.  Because the printer had been sitting unused for several days, the filament had snapped in the feed tube and I didn't catch it.  The extruder was running empty for several minutes before I caught the problem.  This running empty over-cooked the filament that was left in the extruder which caused a nozzle jam.  No problem, fixed that easily.  However, it also damaged the PTFE heat break liner, my LAST liner.  I ordered some new spare liners, and some more 0.4mm nozzles - just to be on the safe side.  They arrived, and rather than waste the remaining grey filament, I'm using it to print brackets to hold the OXA tool-holders for my Sherline lathe.  Those brackets, and the gearmotor case filler blocks, finished printing last night.  Now I'll pitch the remainder of the old roll of grey filament, switch to the new roll, and start re-printing the grey parts.
Offline ddmckee54
« Reply #14 on: August 28, 2025, 06:36:29 PM »
I'm pretty sure that I'm done reprinting grey parts now.  There was enough of a color difference between the 2 rolls of grey filament that I wound up reprinting almost all of the grey parts. I think that I reprinted 58 parts, there were 7 parts that wouldn't be visible so I didn't reprint them.  I wound up with 5 sets of parts that were overnight prints, and several sets that were several hour prints.  The plastic pooping robot was putting in some overtime hours.
I did a test assembly of the heart of the beast, that would be the rotating assembly.  It went fairly well, but initially there was one spot where it would start to bind up. However that has mostly gone away with me exercising it.  I suspect that there were a couple of printer boogers that I missed when cleaning up the parts.  There's only 0.5mm of clearance between the slew bearing outer race clamp and the center post of upper frame.  I kept that clearance small to minimize dirt getting into the slew bearing, that's the only bearing on this thing that isn't either shielded or sealed.  This is what the mostly assembled rotating assembly looks like.
It's only mostly assembled because it still needs to have the slip ring assembly installed right smack in the middle of this thing.  I still need to install the connectors on the slip ring wires.  The only things connected to the slip ring will be the main drive motors and their ESC's.  I'll need to tear everything apart to install the slip ring, and let me tell you that installing the slew bearing inner race clamp is a royal PAIN IN THE BUTT.  There are six M3 x 35mm button head cap screws that hold it in place, and I'm working in a 27mm diameter hole that's 25mm deep. I can see all the bolt holes, but the only one I can actually work on is the one that's directly under a 7mm notch cut in one side of the 27mm hole.  My 20/20 hindsight tells me I SHOULD have made at least 2 notches, oh well...  When I tear it apart to install the slip ring assembly I'll see if I can find, and fix, what was causing the binding.
Next on the agenda is removing all the remaining support material from the rollers, the drive sprockets, and the idler yokes.  The easiest way to do that for the rollers and sprockets will be on the lathe.  I 3D printed several jigs that will simplify the work holding, but I still expect the clean up to take a couple of days.
Offline ddmckee54
« Reply #15 on: November 19, 2025, 12:21:34 AM »
The outdoor projects are almost wrapped up, at least on the exterior.  The porch roof has been replaced, and that project is weather-tight.  With the exception of the overhead door the exterior of the garage is complete, and the door should be installed by the end of the week.  Completing the interior of both the garage and porch will be my winter projects.
I got a little work done on the RT7R, mainly cleaning leftover support material from the drive sprockets, idlers, and all the track rollers.  I 3D printed three split collets, one for the 2 drive sprockets, one for the 2 idlers, and one for the 16 track rollers.  The split collets allowed me to chuck the parts in the 3 jaw on my Sherline and clean off all the external support remains.
I still have to clean out the supports in the bearing bores on all the track rollers, idlers, and sprockets.  That procedure will require a different set-up, but will re-use the split collets.  The current plan is to chuck an end-mill in the tailstock and use the end-mill to clean the bearing bore to the proper depth.
I've been having issues with my 3D printer, my spool of grey filament was poorly wound, and it measures undersize.  I finally got through the area of the spool that was badly wound, that caused several failed prints.  Two of those were failed prints damaged the teflon liner in the hot end.  I thought I caught it early enough the last time, but I was mistaken.  When I took the hot-end apart the liner was sticky and starting to turn black.  Maybe it's time to switch to an all metal hot end?
Offline rleete
« Reply #16 on: November 19, 2025, 05:06:47 PM »
This is just the prototype for the full-sized one, right?
Offline ddmckee54
« Reply #17 on: November 20, 2025, 07:39:06 PM »
Hopefully it will have all the functions of the full sized version.
I wound printing the lift parts twice.  August was the last time I used the printer and I forgot that I didn't need to scale the parts before slicing anymore - so all the parts were too big the first time.   After a Homer Simpson moment. I took out the 103% scaling, re-sliced, and reprinted the parts.  I then discovered that I had an interference problem between the inner link and the outer link.  The inner link was hitting the edge of the outer link and not allowing the lift to fold completely shut.  After a minor re-design and re-print for the outer link I have what will eventually be the scissor hoist for the dump bed.  Below is the lift in its' folded configuration.
That's a AAA battery in front for a size reference.
This is what the lift will look like when opened up.
That's a roll of 1" painter's tape that the lift is propped up against.  If my calculations are correct, this should give me almost 60 degrees of bed tilt.  That's an M4 x 55mm screw coming out of the gearbox, and my measurements show I only need about 12-15mm of travel from the lead-nut.  With the gear reduction I've got, that should mean about 30 seconds to lift or lower the bed.  I've still got to build the lead-nut assembly, but it's just going to be an M4 nut, some steel brake line, and a piece of brass for the pivot.
Offline ddmckee54
« Reply #18 on: December 31, 2025, 01:55:18 AM »
Santa brought me a garage door for an early Christmas present, he's also bringing me a P1S/AMS combo as a late Christmas present.  The gaping hole in the front of my garage is now filled and the building is weather-tight.  Insulating it, or any other work on the inside, is going to have to wait for warmer weather.
I tried printing some larger than 200mm stuff  on the MP10 and it crapped out again, that's why Santa's bringing me the late present.
I also decided it was time to install the Micro Swiss all-metal hot end on the D6.  In the process I discovered the root cause of the jamming issue I'd been having on it.  The D6 uses an aluminum block with a series of slots milled in it as a heatsink for the heat break.  This block is bolted to the bottom of the extruder drive, which caps off the open top of the slots.  The cooling fan blows air through the slots to cool the heat break.  The Micro Swiss all metal hot end replaces this heatsink with one of their own design.  I found 2 things that were issues with the original heatsink.  First, at least 75% of the cooling slots were blocked off with dust,  This would cause heat creep, and eventually the filament would be melting in the heat break, not the nozzle, causing a jam.  I'm going to have to blow these slots out once in a while or the same thing will happen to the Micro Swiss heatsink.  (When I found that issue I almost regretted ordering the P1S, until I remembered that to get a quality print out of the D6 I have to print at 60mm/sec, while they recommend 200mm/sec on the P1S.)  The second issue I found was that the slots that were right next to where the heat break went through the heatsink had no exit, they were dead-headed so about 25% of the heatsink NEVER worked properly.  The cooling fan could pressurize the slots, but that air would be static so it wouldn't help cool the heatsink.  Those slots didn't have any dust in them which shows no air was circulating through them.  The Micro Swiss heatsink has an exit milled in for these slots.
I finally found some 1/4"x1/2" aluminum flat bar for the RT7's upper frame rails, so I'm going back to Plan A and using the aluminum frame rails.  They'll be a little easier to machine on the equipment I've got.
Offline ddmckee54
« Reply #19 on: January 11, 2026, 12:05:01 AM »
Well folks, bad news and really bad news - l got my P1S a couple days ago and the front enclosure door was smashed, that's the bad news.
The really bad news is that I just printed my first part with it... Lordy, Lordy, Lordy!  I'm SERIOUSLY considering reprinting the entire model, it's THAT good.  With the P1S, reprinting will only take a small fraction of the time the D6 took.
« Reply #20 on: January 12, 2026, 12:47:01 PM »
Hope you can get the door replaced. The new quality sounds great!  :beer:
Offline ddmckee54
« Reply #21 on: January 25, 2026, 11:30:11 AM »
I got the new door and 2 spools of filament a few days ago, installing it was easy-peasee.  They were really serious about wanting the replacement door to arrive safely.  The door was shipped in a resilient foam sleeve, that was in a sturdy cardboard box, that was in a bubble-wrap shipping envelope, that was in yet another sturdy cardboard box along with the filament.  All of which was probably a good thing, since the Package Handling Gorillas had attacked the outside box.  It damaged one of the filament boxes, but no damage to the filament.
With the below 0 F daily "high" temps that we've been having lately, and my drafty old house, it's been too cold to do any printing,  We're supposed to be back up into the 20's in about a week.  Then I can resume the calibrating and fine tuning of the printer to the various filaments.
« Reply #22 on: January 30, 2026, 09:35:39 AM »
I know what you mean about the temps. My shop is too cold to work in right now. We haven't seen a high above freezing for a couple weeks. it's 1 degree F right now. Just doing CAD stuff and small wooden patterns in the house, presently.
