Author Topic: What's inside of a Harbor Freight 220V Spot Welder?  (Read 32427 times)
« on: June 12, 2025, 02:31:21 PM »
What's inside a Harbor Freight 240 volt spot welder? Well the switch on mine was starting to act flakey, so I decided to find out.....
End cap left, fixed handle lying on top of main body with switch wires and switch, moveable handle above that. Handle pin partly removed at front.
Re: What's inside of a Harbor Freight 220V Spot Welder?
« Reply #1 on: June 12, 2025, 02:51:46 PM »
End cap removed:
The cap and back end of transformer windings
The fixed handle and trigger wire running down channel to the switch:
Switch with ring of paper insulator
Switch wiring
Switch construction
Switch contacts
« Reply #2 on: June 12, 2025, 03:05:35 PM »
The front arms. Upper moveable arm removed. Sits in cast aluminum retainer, attaches to brass contact shell:
The handle pivot showing straight knurl for "press" fit (doesn't work well)
Upper arm contact (brass right) lower arm contact (copper center) and pivot
Upper and lower arm contacts (front view)
Lower contact, showing insulation at bottom
