Author Topic: Metal Lathe Centering Roller Tool for chucked item  (Read 15433 times)
Offline Jim Dobson
« on: June 24, 2024, 02:42:20 AM »
A simple idea how I quickly center up small pieces of offcuts. Not saying this is how anyone else should do it, but it works accurately for most of the work that I do. It doesn't replace your Mitutoyo dial indicator for super accurate work, but as I say in the video its quick and easy.
Hope it helps someone out.
Offline efrench
Re: Metal Lathe Centering Roller Tool for chucked item
« Reply #1 on: June 25, 2024, 12:31:42 AM »
Have you tried using it as a burnisher?
Offline Jim Dobson
« Reply #2 on: June 25, 2024, 12:35:47 AM »
No I haven't but I can see after thinking about it that you could.
« Reply #3 on: June 25, 2024, 12:25:09 PM »
I thought of trying mine to burnish items. I'd angle it by a degree or two. I may try it later!
I've seen designs for a burnishing tool using a ball race and a ball bearing but burnishing couldn't get anywhere near a corner.
My version of the Centering Roller has two bearings so that I can nudge things in X & Y without removing it from the toolholder.
Offline Jim Dobson
« Reply #4 on: June 25, 2024, 07:02:28 PM »
Be interesting Phil to see how it works for you if you try it.
« Reply #5 on: June 26, 2024, 08:46:03 AM »
Jim,
I did try it but only on a piece of stock Al alloy. (As extruded).
I ended up with a nice round piece with a smooth surface and it only seemed to make about 0.01mm difference to the diameter. (Not that the original was perfectly round.)
I'll repeat and take some photos.
Offline Jim Dobson
« Reply #6 on: June 26, 2024, 04:31:26 PM »
Thanks Phil, appreciated.
