Author Topic: Fixing the how NOT to make an engine  (Read 64785 times)
« on: June 25, 2009, 02:24:29 PM »
This is a follow on post from this article,
http://madmodder.net/index.php?topic=1361.0
I thought I would show the members how I go about rescuing an engine that should really have been consigned to the recycle box.
After finding out that the machined port faces were square to the base bottom, I made up a quickie ali plate, with two parallel faces so that is could be remounted accurately into the vice after a little work was carried out on the casting.
Once the ali plate was tapped down onto a parallel, I levelled the port faces and tightened it to the plate when I had it running 0-0 along the parallel I was measuring against.
I was very surprised to find out that the casting is in fact brass, rather than the normal bronze. It must be that ST are cutting back on quality even further. They can't get much worse than the crap undersized cast iron castings that they are knocking out nowadays.
Anyway, getting away from my personal gripe, I roughly centred a 1/8" (3.2mm) endmill over each port hole and cut down to a depth of 50 thou (1.25mm).
Once all eight ports were machined out, I made some slugs of brass to fit in each hole.
A bit of flux (I am trying a new one and don't know what it will turn out like, it is Tenacity#5, supposedly even better than my favoured 4A) down the hole, a plug inserted, and a small ring of easiflo 0.5mm wire around each one.
A bit of heat until the solder flows, then a quick quench followed by half an hour in a citric acid pickle bath. I did notice that the new flux was still very active while the job was heating up, also I noticed that there was a lot more copper plating from the pickle bath than I would normally find. It looks like the whole casting is made of copper, whereas normally, there would be just areas around the soldering that were copper plated.
After a good dose of surface grinding and a little bit of mill work, the casting is ready again to be machined, this time with the holes in the correct place.
I did remove a few thou of casting thickness, but there is still plenty of meat on it to take it. The new port holes won't be as deep as the originals, as I will only be penetrating the slugs and picking up on the oversized and out of place holes that were in there before.
I did no more work on the crankshaft, as I need to get the cylinders into their correct positions first. I will eventually mod the crank disc thickness to take into account the thickness I have removed off the casting, only then can the crank pin be fitted.
Re: Fixing the how NOT to make an engine
« Reply #1 on: June 25, 2009, 03:42:45 PM »
Holy cr@p that is a slick fix John. I am impressed.  :bow: The plugs, were they press fit or was there some clearance?
Nice job as always.  :clap:
« Reply #2 on: June 25, 2009, 05:05:23 PM »
Eric,
When silver soldering, there should always be a gap of around 0.002" (0.05mm). This is to allow the silver solder to flow under capilliary action into the gap and make a super strong joint. The mistake a lot of people make is to have the bits press fitted into the hole. Then when it is silver soldered, the solder only sits on the surface. When you come to do a bit of machining as I have done, the slugs would then not be fixed in position, and liable to be blown out when pressure is applied.
I have been rescuing these sorts of engines and castings for many years, so to me it is just another little job. you tend to remember how you have repaired bits in the past, so no learning curve to go through each time. Excluding the pickling stage, this was less than an hours work, so well worth doing, considering a new casting would be about 35 to 40 squid.
Very rarely do you come across a casting that can't be repaired and got back into a useable state. A coat of paint also helps in covering up a repair if it can't be blended in too well, as would happen with a silver solder repair on a cast iron casting.
Offline shoey51
« Reply #3 on: June 28, 2009, 01:26:47 AM »
 :bow: :bow: :bow: great work John I wish I had your skills.
back to square 1 with my loco project I was a bit slap dash with some of my measurements :(
« Reply #4 on: June 28, 2009, 04:14:30 AM »
Shoey,
All my 'skills' have been picked up and fine tuned over the years, so don't worry, you will get there in the end. Time is a great leveller.
I too still make mistakes, but I am now a dab hand at covering things up and doing quickie rescues. So even though it looks like I have everything spot on, sometimes it is just a good cover up and modify job.
We are not talking about life threatening things here, so if it can be made to work after making a mistake, then do it. The sky won't fall on your head if you make a slightly thicker rod to fit in an oversized hole.
« Reply #5 on: June 29, 2009, 07:23:26 PM »
This is a bit long after the original repair, but I am trying to juggle time in my shop and keeping a very inquisitive visitor happy.
Ralph's visit this afternoon (he disturbed me from my afternoon power nap), gave me the push I needed to carry on with this post. He wanted to see how I used a co-axial indicator. I don't think Ralph learned how to use it because it was such a short demonstration, but I think he went away with an understanding of how and why it is used, which is half the battle. Maybe another time Ralph.
So onwards and upwards as they say.
Using my coaxial indicator, I centred up the RT to the quill.
Having previously turned up a holding mandrel on the lathe, and without taking it out of the chuck, the chuck was unscrewed off the lathe, and screwed onto the matching thread on the RT. This put the mandrel on the centreline of the quill.
The RT was set to zero on it's angle scale, and the machine DRO was zeroed up all round. This is showing it in metric, just after this, I reset it to read imperial, as that is what the drawing calls for.
The X axis on the mill was locked up, as all movement for this operation will be done on the mill Y axis and the RT degree scale.
The casting was dropped onto the mandrel but it was not tightened down, yet.
This is the method I use to make sure that the holes are drilled perfectly in the correct position around the cylinder pivot, even though the pivot centre and the crank centre might be slightly out. This will automatically ensure that when the cylinder swings from side to side, even if the centres are slightly out, the holes will line up perfectly with the ports in the cylinder (assuming the holes in the cylinder are on the centre line, which on this engine, they are).
This shot is taken slightly from the side to show what is going on.
I mounted up a bit of rod, the same diameter as the crank hole into the chuck. By moving forwards on the Y axis only, disregarding what the readings were, I moved it forwards until the rod slipped nicely down the crank hole.
Then I tightened up the screw to lock the casting onto the mandrel. So now I had the two centres perfectly aligned down the Y axis. The rod was withdrawn, and the Y axis was wound back to the zero position.
This is what is required on the drawing. The PCD is 15/32", so that was halved, giving 15/64", and the Y axis moved forwards by that amount.
As shown on the DRO. The Y axis was then locked up. All work now is using the RT and the quill.
As can be seen from the drawing, there is a spread of 38 degs between the port hole centres. That means 19 degs either side of the centre line.
So a quick calculation gave me settings for the RT. 19, 161, 199 and 341 degs. 19 degrees either side of the 0/180 deg centre line. A quickie centre drill at those setings, followed by drilling down thru the silver soldered  plugs, until the correct sized drill hit the previously drilled ports.
Once one side was done, the same thing was done on the other cylinder pivot point by repeating the exercise.
I took this shot on an angle to show how the new holes join up with the previously drilled out of position holes. It doesn't matter that they are not quite in line, the steam will find its way thru. The main thing is that the holes on the surface bearing face are in the correct position now.
I think the next bit will be the rescue of the cylinder bottom plate/bearing and piston/rod, as they should all be made as a matched set.
When, I have no idea. A contract job is waiting in the wings and the delivery date is getting close. I have now got all the materials together, so that must take priority.
« Reply #6 on: June 29, 2009, 07:31:34 PM »
You just had to throw fractions in didn't you...... :doh:
Quick calculations.....umm....for some eh.... :lol:
« Reply #7 on: June 29, 2009, 08:06:57 PM »
I can't help it Darren, that is how the drawing comes from my favourite casting supplier, by using fractions, it shows just how good they really are, not.
Get yourself a ZEUS book, and that takes care of all your problem conversion calculations for you. But you do need to be able to read first  :lol:
Once you get to using your RT, you will totally understand what I was on about.
0/360+19=19, 180-19=161, 180+19=199, 0/360-19=341
« Reply #8 on: June 30, 2009, 04:18:01 AM »
I think I get the jist of what you are doing John....
Just to prove that I have been reading your last sum is wrong, but I know what you meant  :thumbup:
« Reply #9 on: June 30, 2009, 05:27:43 AM »
Darren,
When you use a RT, your zero point is actually 0 or 360, 360/0 being the start of the journey around the circumference, 0/360 being the end of the journey.
Because it was the end of my journey, I used 360. So 360-19= 341 degs.
That is just the start of it, wait until you get to the minutes/seconds vernier scale. That is why, when I have to start working it all out, I take the easy way out, and fit the dividing plates on and let them take care of all the calculations. Unfortunately, your RT doesn't have that facility, so you will need to do it the hard way.
« Reply #10 on: July 07, 2009, 05:24:46 AM »
Away we go again, little snapshots in time, when I have the chance to do a little more to this engine.
I left it last time with the main casting sorted, and the cylinders to be brought up to spec.
I will wait until I have finished the bottom bearings of the cylinder before deciding what to do with the pistons and rods. But just to make sure, I gathered the bits together to make sure I could make new of everything if required.
This is a lump of PB2, a little more difficult to machine than PB1, but it was the correct size for the job. So armed with a razor sharp HSS tool, I wacked off the metal until the bearing spigot was at the correct size.
Now this is where a benefactor comes onto the scene. Look what he dropped off. I have been contemplating buying one of these for a few years, but never got around to it.
WOW, it went thru that tough bronze as though it wasn't there. It works on the principle of deforming the chip as it comes off the cut, so stopping it jamming around the tool tip. You can see the swarf on the crosslide, it just curls it up in two dimensions, and throws it out. Unfortunately this tip holder can only go deep enough for a 7/8" bar, so I will look around for a longer nosed one that will cope with larger diameter bars, now I know what a wonderful system it is.
The first one ready for the next stage.
Soon followed by it's twin.
Now comes the stage where people make their main mistake. They do one component machining operation, then do the next component, then go back and drill and ream holes.
WRONG
You must finish off each component separately to it's conclusion, only then change over the component and carry out the same ops.
The first op is to machine the spigot for a wringing fit into the bore.
Then drill and ream, or bore for your finished sized hole. By doing it this way, it will ensure that the hole is truly concentric with the bore. Only then do you swap over and do the next piece. The outside shape has nothing to do with the well running of the engine, this spigot and concentric related hole is the bit that needs to be spot on.
Once the two bearings were done, it was found that the pistons and the rod ran perfectly in the bores, so I decided just to make new pistons which were a little small on diameter, and will be made at a future machining spell.
Getting away from the pistons and end caps now, notice how close the holes are to the port faces. I think that the cylinder covers were fitted first, then the port faces were machined down a little too much. To such an extent, that the brass screws that held the covers had almost half the heads machined away.
I can see another fix coming on.
Grab a bit of brass rod on nearly the right size for 7BA. Then a quick and dirty exercise to make a length of threaded rod. 30 seconds work to cut a length of thread about 3" (75mm) long using the die holder off the lathe and a rechargeable drill.
I wasn't too worried about the quality of the thread, as long as it screwed into the holes.
Like the repair to the main casting, bits of rod were screwed into the holes after first dipping them in flux. Then they were silver soldered into position, using the same method as use on the main casting.
A quickie machining job and the cylinder was back to square one, ready to be drilled in a better position.
The problem now was that I had steel cylinder covers with holes in the wrong place. So a bit of brass plate was cut to size and annealed, a mandrel turned up to bend the brass around to get to the basic shape, then a bit of bending in the vice soon had two new brass covers made. I will drill, tap and fix them in position after I have made the new pistons.
It is coming along rather well now, just a few more bits to make, and a couple of holes to straighten up and I will be into assembly time.
Offline shoey51
« Reply #11 on: July 07, 2009, 05:46:23 AM »
 :bow: :bow: as usual a great narrative with pictures top work :clap:
« Reply #12 on: July 07, 2009, 06:08:58 AM »
Shoey,
By the time I have finished, I don't think there will be an area on this engine that will not have had work done on it.
The reason I show everything is to make it clear, that nothing is really lost forever. Most things can be 'fixed', no matter how bad they were in the beginning.
You may ask, was it worth doing all this work on such a bad example as this?
Financially, NO. If I was to charge him a going rate for the job, this engine would cost many times more than the original cost of the kit.
But, to me YES. I am getting a great amount of enjoyment from rescuing and fixing this engine up, and the look on his face and his feeling of joy when he gets a running engine back will be more than enough reward for me.
Basically, all he will be paying for is the raw materials and consumables, plus postage costs, and all it has cost me is a little of my time, which for a fellow modeller, I just can't bring myself to charge for.
All on the understanding, he gets it back when I have finished, no time limits. If time limits come into it, then charges apply.
« Reply #13 on: July 07, 2009, 07:09:59 AM »
It's very inspirational to see that all my botched work can be saved later once more exp has been gained..... :ddb:
Offline rleete
« Reply #14 on: July 07, 2009, 07:29:24 AM »
I am getting a great amount of enjoyment from rescuing and fixing this engine up...
I know exactly what you mean.  I sometimes spend an inordinate amount of time and effort to refurbish something that could more easily be tossed out and replaced.
Any fool can spend money, it takes a bit of talent to fix things.
« Reply #15 on: July 10, 2009, 06:23:56 PM »
This was the ending sentence of my last post about saving this engine.
As can be seen from this pic, the holes were a lot more out of kilter than I first thought. It is no wonder that the port faces weren't sitting against each other.
This was just too much to try to straighten up, so there was nothing else to do other than go on one of my silver soldering binges.
The port holes were out of line and too large on a couple of them, so I went the whole hog and plugged up everything there was, even the port drillings, and start from scratch.
First off, make the bad holes even bigger. Stick a few bungs in there and get out the blowtorch.
This is how they ended up. Just like original, with no holes, but with an extra bit of meat here and there.
A little bit of machining soon had them looking a bit sweeter.
Faced off, and all holes in their right places, and square.
On the ST plans it showed the port drillings being done on an angle, from the port face to just inside the cylinder top and bottom.
This engine, as far as I can ascertain, is really for the beginner to model engineering, his first build maybe. To put angled ports on such an engine is absolutely stupid. A newbie will have trouble cutting things on the flat, never mind on an angle. Even I get it wrong sometimes, and I have done a few in my time.
So, I have made the port drillings how they should have been designed into an engine of this type.
Make a recess top and bottom to allow steam to enter the cylinder, drill the ports straight in from the port face, then drill straight down until the two parts are joined. Dead easy to do, and almost guarantees success for the newbie.
Because of all the hot work that has been done on these cylinders, I suspect that the bore has distorted slightly, plus any flux runoff may have eaten into the walls a little. So I will make a plastic cylinder hone, and grind the bore back into shape before I make the new pistons to fit, I am only talking about a couple of tenths, so it won't really make much difference to the spigots I have turned on the bottom cylinder bearings.
« Reply #16 on: July 10, 2009, 07:11:51 PM »
Blimey, that really was out of square wasn't it....
And I worry about some of my "not so squares"..... :D
Offline shoey51
« Reply #17 on: July 10, 2009, 08:09:05 PM »
nice work there Bogs  :bow: :bow:
this a thread worth watching :clap:
Offline rleete
« Reply #18 on: July 10, 2009, 10:07:53 PM »
Huh.  That's how I did the port on my wobbler, not having any angle plates yet.  I thought I was being so clever doing it that way, too.
« Reply #19 on: July 11, 2009, 01:33:07 AM »
The purists would go ballistic if you told them to make the ports this way, super efficiency, free flow of gases and all that crap.
In what we do and make and in the sort of sizes we are talking about, it makes not one iota of difference to the way the engines run, so why not design them as simple as possible to make?
This is one time the engine designer has really got too big for his boots. Turning a simple design into a horror to make.
« Reply #20 on: July 11, 2009, 06:06:13 PM »
I am trying to blast on with this engine to get it finished, so I spent a little time in the shop this evening, getting a little stress relief.
Last time I mentioned cleaning up the bores a little.
I grabbed a bit of PVC rod and turned it down to about 1 thou under bore size. Then using a couple of different grades of valve grinding paste, then finishing off with a chrome cleaning liquid, I got the bores nicely cleaned up. I am not after micro finishes and sizes on these bores, as long as they are smooth and within a thou or so they will be fine. Don't go chasing your tail trying for perfection. As stated before, for an IC, flame licker or Stirling, yes, then try for the best you can. With these small engines, near enough is usually good enough.
Nice semi matt bores, and both measure the same.
I am making new pistons, and here they are in rough size. They still need to be turned down to length and diameter (0.002" or 0.05mm smaller than the bore).
I have now marked each piece as part of an assembly, with either one or two tiny pop marks on each part. This will ensure that when I have finished, I will have two perfectly fitting assemblies, with all parts matched to each other.
I found in my little stash, two perfect matched o-rings to the crappy ones that were in there. So I did a quick check on the plans for groove dimensions. If I had made the grooves to the plans, the o-rings would have been sitting lower than the piston edges, and so performing nothing to sealing the pistons, just there for decoration. The great ST strikes again.
So armed with a bit of paper and a pencil, the CORRECT dimensions were worked out.
Pistons now to size, o-ring grooves and widths correct.
Now V-E-R-Y happy with the piston and ring fit. They should work perfectly.
So a bit of flange drilling, and the assemblies will be ready for fitting.
Next bit will be making new big ends.
« Reply #21 on: July 12, 2009, 06:33:50 PM »
Just to tidy things up on the cylinders, I knocked up a couple of end caps out of brass.
So now onto the big ends. I like the very hard wearing properties of ali bronze, so instead of phos bronze, I wacked some hex ali bronze down to the required size.
It was soon into the lathe for a bit of shaping, drilling and tapping.
The pair were then slipped onto the mill and cut and drilled to shape. Great I thought, everything had gone smooth as silk and I had the new big ends within 5/10ths of drawing, so basically, spot on.
Before I cleaned them up, I wanted to see how they fitted. Then the problem reared it's ugly head, they didn't, fit that was.
As you can see, they wouldn't fit onto the crankpin.
Then I thought, how come a great company like Stuart Turner could make something that was wrong, I must be me at fault, as they are so great, they would never make a mistake or ten.
So I double checked the parts to drawing, yes, I had made them correctly. So why didn't they fit?
Oh! Dear, someone in the world famous ST empire must have had a slip of the pen and marked up the plans incorrectly, Oh! and someone must have forgotten to proof read and test the drawings, FOR OVER 10 YEARS!!!.
I just wonder how many pairs of these big ends have been made over the years, and how many have had to be remade, just like I will have to do, and how many people must have complained about it, and how long would it have to be before ST put the plans right. Plus maybe reimburse the poor newbie for the wasted man hours and materials, not.
So if anyone wants a duff pair of big ends to not fit a Stuart Turner V-Twin engine, the send me the cost of postage, and you can have them.
It is my own fault, I know how bad Stuart Turner casting sets and plans can be, I should have checked and quadruple checked beforehand.
Bogs.
« Reply #22 on: July 13, 2009, 06:27:54 AM »
That's terrible for a company like them. I thought they'd be perfect but I won't be buying any of their castings!
I hate the design of that offset big end too.
Well done John, it's going to run superbly well when it's fettled.
« Reply #23 on: July 13, 2009, 08:14:44 AM »
Don't get me wrong Nick, Stuart Turner used to have a great reputation, and their collection of unique casting kits is second to none, but ever since going thru a few changes of hands, things have gone thru a few changes, in my mind for the worst. Quality of the castings have got worse and prices have jumped up beyond what they should have done. To me now, they are being made down to a price, and being sold for above market rate.
Maybe not too bad for the larger and more expensive in the range, purely because they will most probably be using old stockpiles of castings, but any of their usual high throughput stuff, I personally would worry about what I was buying.
I have had numerous people talk to me about rescuing ST castings, mainly because the castings were actually too small for the dimensions given on the plans. This suggests to me that rather than using proper oversized patterns that allow for the shrinkage of metals after being cast, they are using original castings as the patterns, so that when cast, the molten metal then shrinks away from the correct sized casting mould and they then come out say between 3% to 6% undersized, depending what metal is being used.
This doesn't usually cause a major problem to someone who has worked or is working from castings and has a lot of experience, as they can usually see what is needed and swap a few figures about and get things to fit. Stuart Turner expect everyone that makes their engines to do just that. Make it fit.
But it is a totally different thing when a newbie gets a set of undersized castings. He doesn't understand that the castings have to be measured up first, before doing anything else, and then cross referenced to the drawing dimensions (and as I have shown, the drawings aren't all that good either) just to double check that the part can be made out of the casting. Usually, after taking the initial cut, the engine is doomed to failure.
Stuart turner are not the only ones on the money making roundabout. Reeves, who have most probably the largest casting collection in the world, have started to go downhill on quality, to such an extent, I personally would only recommend some of their castings being used as high priced fishing weights.
You pays your money, you takes the chance.
« Reply #24 on: July 19, 2009, 06:32:38 PM »
I have managed to get rid of my overseas visitor (at last), and have got back into the shop again for a while, at hours to suit myself.
I got a new pair of big ends made, with the holes in the correct place this time. By the time I had finished working them, the ali bronze had gone rock hard, and I had trouble dressing the burrs off them. Just what is needed.
The next job to do was to get the tensioners made and sorted for the other side of the engine. New spring holders and knurled nuts were made up, these just need a set of acorn nuts making to lock everything up when the tensions have been correctly set.
This shows the throttle valve area.
No instructions for making the stop or setting it up came on the plans, so using my experience on what is required, I fitted a stop pin, and dressed the throttle stops. This is so that when in the fully one way position against the stops, the horse shoe cutouts in the valve face align perfectly with the port holes drilled in the main block, so depending which way the valve is swung, either fully fwds or reverse is obtained, and variable throttle and stop is obtained between the two.
Now that I had the port faces being pulled against each other, and putting the big ends in their running positions, I could dress the the face of the crank disc to give a little running clearance. I gave it 0.020" (0.5mm), which should be more than enough if ever the cylinders get blown off their faces at an angle because of excess steam pressure.
Now that I had all the bits set up for correct clearances etc, it now warranted setting up the RT to do a little offset drilling. Waiting until now meant I only had to set up the RT just the once and get all the bits done at the same time.
This is now the time to show that accidents do happen to the best of us, and this was because I broke one of my golden rules, NEVER RUSH TO GET THE JOB FINISHED.
The wife had stuck her head out of the door and shouted 'lunch in ten minutes'.
I was just making the knurled nuts that are shown above, and being a smart a**e, I thought I could get them finished in time.
So instead of taking the small drill out of the tailstock and putting it back in it's box, by rushing, I forgot to do it.
Swung away with the toolholder to change for the next one, and this fleshy and tender part of my anatomy dragged against the razor sharp edge of the drill still in the tailstock chuck. Ending up as a rather deep cut, any deeper and the sewing machine would have had to come out.
The dog learned a few new choice words, the cat did a runner because it knows what happens to my boot when I am in a bad mood, lunch was delayed, as the wife patched me up and patted me on the head as though I was a little kid, and I lost the rest of the day in the shop, while I waited for it to stop bleeding and heal up.
All because I acted stupidly in a dangerous environment.
Anyway, enough of my stupid antics, back to the job in hand.
The RT was centred up, offset in the Y axis for the drilling for the pin in the crank disc. Notice that it is sticking up from the chuck jaws a bit, this saves drilling into the chuck jaws as you break thru.
Next offset was for drilling the holes in the bottom cylinder bearings. Because I didn't want to drill into the chuck jaws, I put a couple of washers underneath as the jaws were tightened up, just to raise it away from the jaws slightly, so as the drill broke thru, no damage would be caused to the jaws. The washers are removed before starting to drill.
The same offset was used for the top caps, but thinner washers this time. I didn't have as much to hold onto with the chuck jaws. I was just a little more careful as the drill broke thru.
All bits drilled, and the washers lived to be used another day.
Now these bits have been finished, it allows me to progress a little further and get other parts that have been made previously, fitted onto other assemblies.
Not much to finish with this time, only, as and when I get some more done, I will post it up.
