Author Topic: Dave Ticehurst  (Read 34671 times)
Dave Ticehurst
« on: May 03, 2022, 03:55:34 PM »
I've been enjoying Dave Ticehurst's shop videos (except for the sound levels!). I found one tip here about countersinking that I will definitely use. I'd given up on doing that cleanly or without horrible chatter. Tried many different countersinks, lots of different drill speeds, yet always flummoxed by the little boogers.
Kleenex you say?
Offline jiihoo
  • Finland - Northern Europe
Re: Dave Ticehurst
« Reply #1 on: May 08, 2022, 07:02:11 AM »
I liked his T-slot fence plates starting at 9:32. Simple and elegant.
Tnx for posting the link to his video!
Re: Dave Ticehurst
« Reply #2 on: May 08, 2022, 10:34:05 AM »
Welcome jiihoo, he has lots of other videos with short tips, some familiar, many not. He's a kindly gent just trying to share what he knows, no hype.
Offline Rubes
Re: Dave Ticehurst
« Reply #3 on: May 08, 2022, 12:29:26 PM »
hey yeah...didnt know that one and have had the same problem countersinking.
I guess it is similar to useing a piece of cloth under the bit when drilling thru sheetmetal to get a round hole rather than a triangle, and it also stops the piece from being dragged up the bit.
FF to 6:00 in this vid:
https://www.youtube.com/watch?v=cAGiuXOKKi8
ps...you are right about the sound quality.
Re: Dave Ticehurst
« Reply #4 on: May 08, 2022, 09:20:46 PM »
Rubes, also a good one there drilling sheet metal with cloth, which I'll use.  :beer:
That video sent me down a (good) rabbit hole, because I noticed that he (Marc Presling) also had installed the same bluetooth DRO on his mill as I did, using TouchDRO software -- then I found more videos about TouchDRO, including those by Yuriy -- who originated the hardware/software.
Of course I didn't get much work done in the shop today....  :coffee:
Re: Dave Ticehurst
« Reply #5 on: May 08, 2022, 09:31:21 PM »
I wonder what people feel about Dave Ticehurst's suggestion to use a 2 flute end mill (slot mill) in cutting slots and cutouts by chain drilling with it, (offsetting the vertical plunges by a little less than half the mill diameter) in preference to plunging and side milling the slot end to end using numerous shallow passes.
It does seem to complete the job faster (on reasonably thick stock) and I think I can see that it uses the mill more efficiently, and allows easier re-sharpening. I might try it!  :dremel:
