Author Topic: My easy solution to No More Clogged Spray Paint Rattle Cans  (Read 40185 times)
Offline Jim Dobson
« on: March 29, 2021, 12:45:45 AM »
Re: My easy solution to No More Clogged Spray Paint Rattle Cans
« Reply #1 on: March 29, 2021, 02:23:04 PM »
ie. use some thinner and compressed air to clear a paint can nozzle after spraying.
btw turps or mineral spirits will not thin lacquer based spray paints (like Krylon). A lacquer solvent will clear those.
Offline Pete49
« Reply #2 on: March 29, 2021, 09:54:58 PM »
My problem is lack of air in the can. I have a couple nearly full cans but no propellant.  :doh:
Offline Jim Dobson
« Reply #3 on: March 29, 2021, 10:03:04 PM »
That's what I used to end up with from up ending the cans and spraying clear propellent out of the nozzle to clear them like it says on the can to do, because I use them a lot for small parts I always ended up with paint in the cans and no propellent to spray it!
Offline efrench
« Reply #4 on: March 30, 2021, 02:12:24 AM »
How effective would just using compressed air be?
Offline Jim Dobson
« Reply #5 on: March 30, 2021, 03:04:25 AM »
Probably work OK because in theory that's all that's happening when you invert the can and spray to clear the nozzle? I like the turps though because I know its internally now clear of paint and it also cleans the outside when its wiped with the paper towel that's wet with the turps. If you watch the vid closely you'll see the turps shoot out further each time the paint is cleared out of the nozzle.
« Reply #6 on: March 31, 2021, 01:33:53 AM »
Good, Simple, solution to the prevention of clogged nozzles.
Thanks.
Now we probably need a way to re-pressurize those that do lose pressure.
Like I just searched here,
 OR here
Not really sure how this would go with paint and I have had a few paint cans get tossed because of the lack of pressure. Paint cans would definitely require disposable gloves as well as the other protective gear.
Al worth filing in the memory bank for future reference.
Thanks for posting Jim!
Offline Jim Dobson
« Reply #7 on: March 31, 2021, 02:04:23 AM »
That's pretty cool John and something that I'm going to have to try out on a can of 'something' that loses propellent. I've thrown away heaps of cans in the past and will definitely try to re 'gas' a can  :beer:
