Author Topic: Animated GIFs not animating ?  (Read 47810 times)
« on: March 19, 2021, 06:13:08 AM »
Policy or cock-up?
Re: Animated GIFs not animating ?
« Reply #1 on: March 21, 2021, 11:12:08 PM »
I will look into it...
Do you mean links or attachments?
« Reply #2 on: March 22, 2021, 08:33:43 AM »
Attachments .
They upload ok, but are displayed as static
Example here:
https://www.madmodder.net/index.php/topic,13343.msg160512.html#msg160512
« Reply #3 on: March 22, 2021, 09:16:29 AM »
Ok... So as attachments, animated GIFs will not work. That is a security function of the forum and I believe, there is now way around it.
Easiest method is to upload it to an image hosting site and use the HTML code to insert it into your post. There is a button, second from the left bottom row, that will insert the code. You just need to paste the link. Will look something like this:
Code: [Select]
[img]Your Image hosting link here[/img]
