Author Topic: What is this...  (Read 22879 times)
Offline russ57
What is this...
« on: June 16, 2020, 03:23:47 AM »
On the off chance this might be British, does anyone recognise this logo?
« Last Edit: June 16, 2020, 05:15:29 AM by russ57 »
Offline Sea.dog
  • Up Spirits!
Re: What is this...
« Reply #1 on: June 16, 2020, 03:30:11 AM »
What is the piece of tooling? That may help the search.
Offline russ57
Re: What is this...
« Reply #2 on: June 16, 2020, 05:14:44 AM »
Unfortunately this is all I have...
Trying to work out what it may have been part of.
The logo looks quite distinctive, but Google image search can't find it...
Offline mc
Re: What is this...
« Reply #3 on: June 16, 2020, 05:27:48 PM »
Looks like some kind of automatic bead roller/swager.
For some reason that logo makes me think of firearms. It's not something to do with bullet making?
Offline russ57
Re: What is this...
« Reply #4 on: June 16, 2020, 06:50:23 PM »
Being in Australia, bullet related is possible but unlikely I would have thought.
Some sort of bead /groove roller is likely, but it's a fairly light alloy casting.
The knob seems to offer very fine adjustment of the angle of the roller. A very fine rack and pinion drives a cone into a sleeve which controls the angle.
I guess I'll have to leave it in the cool mystery box.
Have vague idea of using it for a grinding jig.
-russ
Offline GordonL
Re: What is this...
« Reply #5 on: June 17, 2020, 08:06:04 AM »
Assuming that the 922924 was a patent number brings up a patent in Finland for a rotary actuator for slide switch. No other information that I found. I have no idea how that would work.
Offline russ57
Re: What is this...
« Reply #6 on: June 17, 2020, 08:41:01 AM »
Thanks Gordon. Didn't think of a patent number, but that would make it a very precise and complicated switch.... [emoji23]
-russ
Offline mc
Re: What is this...
« Reply #7 on: June 17, 2020, 01:43:22 PM »
If that is the british patent number, then it's a patent for "Process and machine for the continuous manufacture of reinforced sheet material"
Possible patents with that number can be found at https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=922924&AP=&PR=&PD=&PA=&IN=&CPC=&IC=&Submit=Search
Offline mcostello
  • Lancaster, Ohio
Re: What is this...
« Reply #8 on: June 17, 2020, 06:22:10 PM »
Could try a post over at Model Engineer website and see what develops.
Offline russ57
Re: What is this...
« Reply #9 on: June 20, 2020, 05:33:54 AM »
Simon at metalwork forum came up trumps.
https://vintage-radio.net/forum/showthread.php?p=387926
It's out of an Aumann coil winder.
-russ
Offline Sea.dog
  • Up Spirits!
Re: What is this...
« Reply #10 on: June 20, 2020, 08:29:37 AM »
It's a pity I didn't post that on the Migwelding forum. Colin is member of that.
