Author Topic: DDCSV Parameter list  (Read 24108 times)
Offline picclock
« on: February 11, 2020, 10:48:17 AM »
I am using DDCSV 2.1, Ver:2019-06-06-111NOR firmware and I occasionally get stuck with an empty parameter file which is very annoying and timewasting. Last time was with a mains failure during list alteration.
The parameters can be set using a text file on the usb stick with the name of 'userVar.set'.  I was unable to find a version of this online so I thought I'd attach a copy for other users who suffer from this issue.
You will need to unzip the attached file as the forum will not allow post of a 'set' file (or even a txt file :-( ).
Best Regards
picclock
« Last Edit: February 11, 2020, 11:35:03 AM by picclock »
