Author Topic: The Sequel - Oh Blimey I bought a CNC Lathe (Beaver TC 20)  (Read 1233833 times)
Offline Spurry
  • Norfolk, UK
« Reply #1250 on: December 24, 2024, 12:26:43 PM »
It would be great to see you posting again, Andrew.
Hopefully 2025 brings good health and enthusiasm to all.
Offline Muzzerboy
    • The Mighty Shiz
« Reply #1251 on: December 24, 2024, 12:32:35 PM »
Oooh that sounds intriguing - I hope you will at least unpack it and show us what you got there!
I know what you mean about lurgies stealing motivation. Between us, my wife and I have been rendered mostly unfit for any serious house / workshop time for the best part of 6 months. Getting sick of sitting around and nothing happening but wife is better now and hopefully I'm not far behind. Obvs that hasn't prevented me from acquiring more tools in the meantime...
Hope you are soon back in the workshop and up to your old tricks again!
« Reply #1252 on: December 27, 2024, 07:35:14 AM »
So this is my first opportunity to unpack the pallet of bits, what with the Christmas festivities and various cottage guests coming and going.
First job, with the help of a friend, tug the rather heavy pallet of  bits across the inner yard from the unheated tractor shed into the warmth of the workshop. (My Forklift seems to have lost its foot brake so I don't trust it up and down slopes until fixed!)
First thing off was the servo crate that has all the drivers for all axis's and the turret itself :
Then came a spindle assembly for a Beaver Partmaster that he had scraped complete with tool gripper:
These can sit on the shelf hopefully never to be needed as my Partmaster CNC Mill is ok (another jinx !!)
Then a few interface electronics from the TC20 lathe that one hope I'll not need but better to have them than not:
Turret Logic:
Tailstock Logic:
Chuck Logic:
« Reply #1253 on: December 27, 2024, 07:48:59 AM »
Now for the important bit - the SMCC servo logic controller that I THINK is the source of my issues:
Also he has returned the Field Coil Drive Card that I let him have as an aid to his diagnosis.
Disappointingly the Tool Turret Assembly is missing it's servo motor and is a bit knocked about - I had had ideas to set it up as a test rig but not without the motor :(
Offline Sea.dog
  • Up Spirits!
« Reply #1254 on: December 31, 2024, 04:02:28 AM »
It's good to see you back with motivation, Andrew.
« Reply #1255 on: December 31, 2024, 07:29:19 AM »
Slowly cranking up the old engine Graham.
Yesterday I re-read the entire saga to try and refresh my memory of what I’d done and not done, I must say that it left my head spinning 👀
« Reply #1256 on: January 02, 2025, 11:40:09 AM »
So having cleared away all the massively heavy bits from that pallet, today I had the oppurtunity to actually make a start.
First objective before changing anything is to check all the internal sensors on the turret are actually working, these are :
A/ Turret Clamped
B/ Turret Unclamped
C/ Index Position
D/ 4 channels of 'Tool Number' in binary
A & B are relatively easy, the massive 'tool disk' is moved forwards hydraulically to unlock and backwards to lock. In the forward direction the 'drive' curvic coupling is engaged and the front locking curvic coupling is disengaged. The two sensors ride on a tapered part of the shaft and measure really small movements of a few thou. The co-axial hydraulic cylinder is driven by a spool valve that has handy DIN43650 electrical connections - as one is driven automatically operated at power up driving to 'locked' it is only a case of swapping the connectors to drive the turret 'unlocked'. Glad to say both sensors test as good as these have given issues before.
The system is servoing onto one position of the drive system, and this 'should' be the Index sensor finding a notch on the drive system, however monitoring the Index sensor and forcibly moving either side of where it is homing (with a spanner on a convenient drive dog) the sensor doesn't  change state. So this definitely needs investigation.
The Tool Disk happens to be set to 'tool #1' and reading the 4 tool number sensors indeed I am getting channel A=24v and channels B,C, & D all at 0v so that seems to be working.
So at least that's 3 of the 4 sensor systems given a god health check but the 4th one with need a bit of rigging up so that I can spin things by hand without fighting the servo but that's for tommorow.
However I did do a tentative MDI command to select tool#2 and amazingly not only did it work but I was able to re-select tool #1 and get back to square one.
Another issue I noticed is that the screen calls for a 'Turret Initialise' (code 6000) but after an initialise the demand remains. Almost certainly this is a program issue in the SMCC card but I don't yet want to risk trying the one I recently aquired as there are no more in the known universe correctly programmed for this lathe.
« Reply #1257 on: January 03, 2025, 05:16:15 AM »
Up and at it early today as two sets cottage guests going and arriving.
Having cogitated the best way of isolating the Turret Servo #motor drive it came to me in a flash - the analogue +10-0-1-10 drive signal is on it's own plug with a few associated control signals, so it can just be unplugged - simples :(
This then allowed me to turn the servo motor by hand without fighting the drive, and I was able to detect the 'Index Notch' by monitoring it's proximity sensor, getting a decent signal of 19.1 volts when off the notch and 0v when on it.
As I was monitoring on a terminal strip up behind the turret (gymnastics involved!) I thought it bast to prove it all the way through to the SMCC card as quite a bit of chassis wiring is involved to get it there. The SMCC card is isolated by an adjacent PCB holding opto-isolators and relays - terminal 34 being the Turret Zero Ref signal. Sure enough it's working.
So that's all the internal sensors on the turret proved good so no perhaps I can risk the new (second hand) SMCC card. But that's for later as other duties call.
« Reply #1258 on: January 04, 2025, 06:36:25 AM »
Loath to venture outside  this morning as it's  chilly -4 degC but I'd set the heating in the workshop yesterday to 15 so it shouldn't be too bad (?) It had managed to get up to 13C so tolerable.
Now I've long suspected that this problem basically is an erroneous slight offset on the analogue output of the SMCC servo computer card - very difficult to measure anything as it all happens a bit fast but the result (I think!) is a bias on the tool disk so when the front curvic coupling needs to mesh after a tool disk move it cannot lock into position as the fixed and moving teeth clash.
Certainly as a case in point this morning although I can hydraulically drive to tool disk forward to unlock, it would not return to locked until I disabled the servo drive (X111 plug out) and manually gave it a slight turn.
So heart in mouth I decided to install the replacement second hand SMCC card. It was complete with it's mounting bracket which is slightly rusty. If I fix this fault I'll swap the bracket.
The result is that I can move the tool disk to apparently any position and it will return to the locked position (so far!) every time. However the 6000 error message calling for a turret reset still won't clear so more investigations called for.
« Reply #1259 on: January 11, 2025, 11:58:27 AM »
Well that didn't go to plan.
All sorts of issues emerged reporting :
6006 Spindle Drive Fault
6022 Axis Drive Fault
6030 Lack of Hydraulic Pressure (there isn't!)
6019 Chuck Pressure Switch Fault
Argh !!! I decided that I need to be able to talk to the PLC to monitor the internal ladder logic to see what's going on. But firstly I want to be able to connect the lathe through it's RS232 link to prove communication.
That went well and I was able to dump parameters to my desktop PC and they seem to make sense so the RS232 link is proven.
Next I need to steam up Step5 Siemens software to talk to the internal PLC but that's a job for tomorrow.
However I did then try again using the turret (this is after a 24 hour head scratching period) and darn me it's working. So tomorrow a bit more softly softly probing about to see what's going on.
« Reply #1260 on: January 12, 2025, 07:04:27 AM »
So this (very cold!) morning I powered the beast up and confirmed that I could still initialise the turret, move all the axis and select tool positions but still with those same errors reported.
But objective today is to power up the old ToughBook lap top with Step5 (Siemens PLC support program) that runs under Windows XT.
A lot of faffing about and trawling through grey matter and eventually I got there - we are CONNECTED to the internal PLC that runs within the Siemens Sinumerik 820T control that controls this lathe.
A few screen shots just to prove it:
It reports the correct PLC type:
I can read internal parameters
I can see PLC Ladder Logic in real time
Now I need to go and warm up and refresh my memory of what is where in the PLC logic that's relevant to the current issue but my brain's a bit numb at the moment :)
« Reply #1261 on: January 12, 2025, 08:11:57 AM »
I am back again and watching with baited breath Andrew!!
« Reply #1262 on: January 12, 2025, 12:02:32 PM »
Glad to have you aboad Phil. As you know I too have been rather remiss in the attendance department.
I  tell you it will be a major fillip physcologically if I can get this beast back on its feet again !
Offline Kjelle
« Reply #1263 on: January 29, 2025, 05:58:50 AM »
Happy to see you back, and going at it!
Even though I can't realy understand what you are doing (I'm more of a nuts'n bolts guy), it is entertaining, and somewhere along the way, I pick up a scrap of knowledge.
Kjelle
« Reply #1264 on: January 29, 2025, 10:20:22 AM »
Thanks Kjelle,
Things seems to be conspiring against me getting on with this lathe, there was the blocked land drain, then another casualty of the cold snap was my air distribution sytem. I think the issue started when the non return valve on my little hydrovane froze blowing up a bit of it's internal plumbing. Time for a replacement.
I decided to bite the bullet and bought an 18 cfm belt driven Clarke unit which meant revising the layout of the internals of the Portakabin where the compressor lives and doing a rewiring exercise as this unit aparently needs a 40amp service. All that's now sorted - went on line yesterday - sold the dead hydrovane(s) (it's predecessor was still in the Portakabin!) - man coming over from Ireland to collect this evening.
In the mean time the high winds played havoc with my security cameras on the farm so I've revised cabling, pulling some through underground trunking where it's less exposed - awaiting some bracketry from Amazon tomorrow - so that's all on track.
So no more excuses, I need to knuckle down and get on with the lathe - my desk in the workshop still has the Panasonic Toughbook with the Step 5 software awaiting for me to dig into the depths of the PLC where I left it weeks ago.
Offline cnc-it
« Reply #1265 on: February 19, 2025, 03:13:31 AM »
Nice set of spares for the Beaver machines, I would be interested in the spindle assembly if you ever decide to sell it 👍
« Reply #1266 on: February 19, 2025, 11:50:07 AM »
I'm very unlikely to need to use the Partsmaster Spindle so you are in with a fighting chance !
Transport might be a challenge - it's ultra heavy and unless in a car boot will need a very stout crate.
Message me to open negotiations :)
« Reply #1267 on: July 10, 2025, 09:47:01 AM »
Perhaps the summer heat has got to my brain but I've decided to resume testing to try and get this CNC lathe back on it's feet.
A full re-load of known good software still gives me several very odd error reports from the PLC inbuilt to the Sinumerik CNC control so I decided to step back a bit and do some basic hardware testing:
The PLC has 96 inputs (24 v Active 0 V Inactive) and 32 outputs of 0v or 24v. Up until now actually testing these is a physical pain - they are presented at the top of a rack with five cables terminated in 37 pin Sub D connectors - all tightly lashed together.
However a nifty 37 way Sub D break out board turned up on eBay with male and female connectors and a terminal strip allowing me far better access.
« Reply #1268 on: July 10, 2025, 09:54:40 AM »
So over the last few days I have checked all 96 input lines by temporarily connecting them one by one to 24 volts and using the PLC inbuilt diagnostic tools to display them on the monitor.
Still a bit of a pain, and involves a lot of walking as the terminations are on one side of the machine with the control panel on the other - and yes it's a long way walking round it that gets 'old' very quickly. Still two days spent and I've convinced myself the ALL the input are working fine - now there are several unused inputs but I decided to test them all:
« Reply #1269 on: July 10, 2025, 10:06:00 AM »
So now I need to devise a way of testing the outputs. Presented as two cables again terminated in 37 pin D Sub connectors so compatible with the break out board. And again the PLC diagnostic allows me to see what it thinks that it's outputting (it's a Q word) :
However the way (I think) that the PLC works is that it maintains a table of these bits that is updated by the PLC program and every cycle of the program the table is copied to the Q outputs.
This means that if the PLC program is running anything I write to the outputs will be overwritten in milliseconds and if the PLC program is NOT running I can't access the diagnostic facilities so a bit of a catch 22 situation.
I can do a somewhat less stringent test by reading a particular Q word and checking what is actually set but I'm not convinced that that's good enough?
Off to scratch my head a bit !
« Reply #1270 on: July 10, 2025, 10:13:51 AM »
And in some cases the digital outputs will be quite dynamic. For instance the 8 bits shown as '1's ' on the above picture are the data bus that the PLC uses to talk to the SMCC card that is a slave PLC that controls the tool turret - wheels within wheels comes to mind!
« Reply #1271 on: July 10, 2025, 10:22:26 AM »
A cheapish logic analyser and big bunch of resistor arrays ?
« Reply #1272 on: July 10, 2025, 11:45:42 AM »
Good to see you working on this Andrew!  :beer:
« Reply #1273 on: July 11, 2025, 08:18:02 AM »
Thanks Steve - yes I'm a bit more able to get my head arround things now thank goodness.
This morning I went through all the digital outputs and proved that they were in the same state that the 'Q' words in the control were at - they were ! I suspect that the digital input output system is actually fine though it's not conclusive on the outputs as I can only observe rather than drive them.
However I HAVE found that the drive circuit for the main spindle drive is reporting an error - it also has a tell tale red LED that should be 'on' but it isn't. Fortunately I do have a spare so I'll install it when time permits - ATM waiting to meet and greet two sets of cottage guests whose arrival is imminent. (sounds of thumbs twiddling!)
« Reply #1274 on: July 12, 2025, 06:28:33 AM »
More positive progress this morning. Yesterday late on I found that the red 'I'm OK' LED on the main spindle drive for it's field windings was 'off'. Fully expecting to have to change the card - I have spares - I did a bit more research. That LED isn't going to glow when the card has no power  :ddb:
Tracing it through I ended up at manual contactor 'MBS' (a Telemecanique GV1-M07) which is as thermal trip. It wasn't latching on properly. With the power off a few cycles of exercising it got it to latch.
Ebay has provided a reasonably priced 'new' one so I've ordered it just in case.
This got things moving - well it did when I remembered that the console 'Keyswitch' needed to be vertical to allow input !
So now I'm back with a machine that basically works except for the tool turret. I can jog axis's about and control the main spindle. bit of a relief really as this latest excursion up an other alley has been a diversion from the main quest of mastering the turret.
