Author Topic: Uses for Bronze Powder?  (Read 17325 times)
Offline Fergus OMore
« on: April 11, 2018, 12:26:53 PM »
I have several pounds of bronze powder  which has not been used since before WW2.
Are there any uses for it other than gilding picture frames etc?  I thought of mixing it with epoxy resin as a filler to take up wear.
Comments welcome
Norm
Re: Uses for Bronze Powder?
« Reply #1 on: April 11, 2018, 12:51:59 PM »
Spray metal coating using a special oxy-acetylene torch that entrains the powder into the flame. (I have the torch)
Offline one_rod
  • Chesterfield, Derbyshire.
« Reply #2 on: April 11, 2018, 05:16:37 PM »
Mix it with a little dry-powder flux, and use it as brazing spelter.
Most bronze alloys have a fairly low melting point, so ideal for sweated joints on brass, where you don't want to get things too hot and risk sagging the job.
"A season ticket for the one way ride..."
« Reply #3 on: April 11, 2018, 06:26:42 PM »
Thank you but this powder was definitely not for melting or spraying. The owner( died 1939 before WW2) was a master in glazing, sign writing and employed 50 staff. I still have some of his coloured bronzes as well as some gold leaf left.
Oddly, he was a sort of relative to the real Alice in Wonderland and John Dobson, the Newcastle architect.
Dobson designed Newcastle Central Railway Station  as well.
But thanks
Norm
« Reply #4 on: April 12, 2018, 04:52:34 AM »
Hi Norm
That makes me feel better about some of the stuff I have lying around that hasn't been used for years.
I'd guess you could mix it with varnish to make metallic paint.  If it's been lying around that long without a use you could always weigh it in.
« Reply #5 on: April 12, 2018, 09:02:50 AM »
I think that I should go for the original uses and get some rabbits' tails and do up a few 'Old Masters'.
If you know what I mean :lol:
Norm
My late wife recycled the gold fillings from rotten teeth which she had extracted. Of course, she made little ingots but they wouldn't assay. I suppose it was the platinum :dremel:
Norm
« Reply #6 on: April 12, 2018, 09:32:15 AM »
Clearing out my Portakabin this morning prior to it's re-roofing I came across the Rototec metalising gun that would lay your powder down a treat for shaft or bearing recovery.
(Those prices were at least 12 years ago!)
Offline russ57
« Reply #7 on: April 14, 2018, 06:13:17 AM »
If you know what I mean [emoji38]
Norm
Norm
I did see a warning somewhere that dental gold would test at 24k using the common acid tests.
Russ
« Reply #8 on: April 14, 2018, 09:45:21 AM »
The gold alloy was recast many years ago- by my late wife who was a FRCS(Edin) and a Dip.Orth. RCS(Eng)-- amongst a lot of other things like a BA, a Dip.Mus-- and sort of knew an odd thing or two- like playing a Bari sax and a classical clarinet and piano. Not necessarily together , of course.
It was mainly trying to tidy up bits and bobs that she never found time to do---like housework and cooking :coffee:
Yes?
Norm
« Reply #9 on: April 14, 2018, 12:26:54 PM »
New hobby?
« Reply #10 on: April 14, 2018, 12:43:12 PM »
Norm, DON’T sneeze in the box again.
« Reply #11 on: April 14, 2018, 12:52:36 PM »
Thanks,  :lol:
Only them that knows their own nose, knows.
or would you have "everything that glisters is not gold'?
Joules, you're a 'Jewel'
I'll get me coat
Norm
