Author Topic: Cleaning drawn steel ...how?  (Read 11058 times)
Offline Eugene
« on: August 03, 2017, 04:45:37 AM »
For some time I've been marking out using copper sulphate solution with good results, except on newly purchased drawn steel.
The problem is getting the surface of the steel truly clean, that is, water break free. What can the amateur do to entirely remove the surface contamination? Degreasing in petrol doesn't work, the oils are removed but the surface still water breaks making the copper deposit very patchy and non adherent. Even following up with a detergent doesn't help much.
Thanks in advance.
Eugene
Re: Cleaning drawn steel ...how?
« Reply #1 on: August 03, 2017, 04:53:44 AM »
Petrol followed by IPA (Isopropyl Alcohol)? I believe IPA is a degreaser.
Offline Jasonb
« Reply #2 on: August 03, 2017, 01:34:41 PM »
Or use a solvent based marking fluid that won't mind a slightly oily surface.
« Reply #3 on: August 03, 2017, 03:31:58 PM »
Hi try thinners and cleaning product for preparing car body panels for repainting
Offline howsitwork?
« Reply #4 on: August 03, 2017, 04:18:16 PM »
Hammerite thinners works well as a cleaner. But panel thinners or panel wipe I think it's called also works.
Ian
Offline Groundhog
« Reply #5 on: August 03, 2017, 11:10:01 PM »
Not sure how this will work for your purposes, but I was told by a 3M engineer (when discussing specialty tape adhesion) that isopropyl alcohol is the best final cleaner for surfaces. He said that even things like acetone will leave a residue.
Racers say that horsepower is how fast you hit the wall and torque is how big of a hole you make.
Offline Eugene
« Reply #6 on: August 05, 2017, 03:16:23 PM »
 Thanks Lads,
I'll give your suggestions a trial..
Eug
« Reply #7 on: August 06, 2017, 01:31:24 AM »
Nail varnish remover from Pounland must be the cheepest option , get the stuff that smells of pear drops .
