Author Topic: KBIC 240 controler problem  (Read 19284 times)
Offline jaker
« on: January 15, 2017, 09:55:11 AM »
Hi All,
I'm not a electrical genius that's why i hope You can point me in the wright direction. I do have a mini mill with a KBIC 240 controler, the mini mill is the XJ12-300 from Amadeal. The mill is in low RPM's  intermittent and some times loses torque in the middle of a milling cut. Any idea what can be wrong. I have checked the brushes and these are ok.
Any idea is appreciated.
Regards,
Jan from the Netherlands,
Re: KBIC 240 controler problem
« Reply #1 on: January 15, 2017, 10:25:03 AM »
Jan,
The kb controller isnt too compliicated, but fault finding without any test equipment and not having it in front of you doesnt help.....
Is the mill under warranty? If so a call to Hugh at Amadeal might help...
So, options,buy another controller or else have yours repaired....
Offline jaker
« Reply #2 on: January 15, 2017, 12:02:20 PM »
Hi John,
Thanks for Your reply. I do have a multimeter. The mill is out of warranty but i opened the site of the mill and found the controlboard and i have seen the potmeter. I think there is something wrong with the potmeter, i saw black sud under one connector, so i wil check that tomorrow. Maybe a new connector could be a problem solver. Otherwise i order a new potmeter from Amadeal.
Regards,
Jan,
« Reply #3 on: January 15, 2017, 12:16:51 PM »
Jan,
The speed pot is connected to P1,P2 and P3 on the pcb.....you could check the connections, making sure they are secure.  :zap:
The speed pots are known to fail, I've changed mine twice during the life of my machine.... :scratch:
Keep us posted on your progress.... :thumbup:
Offline jaker
« Reply #4 on: January 16, 2017, 09:29:53 AM »
Hi John,
I took a closer look at the potmeter and turned it verry slowly up, seems like there is something wrong with the wiper, i suspect not good contact. So i looked at the WD40 can i have and found out it is usable as a contact spray. So i gave it a try and sprayed some in the potmeter. It looks like the problem is solved. I'm a happy man.  :) :)
Thanks for your advise,
Regards,
Jan,
« Reply #5 on: January 16, 2017, 10:16:24 AM »
Great news.....! :)
You can now show us some photos of your work, now the mill is repaired.... :dremel:
