Author Topic: Phase converters  (Read 10249 times)
Offline smiffy
Phase converters
« on: October 13, 2016, 02:44:45 PM »
I have a 80amp supply into my workshop .What would be the largest 3 phase motor I could run allowing for start up loads and which type of  phase converter is best, digital rotary or static . At present I have both static and digital but largest motor is 5 horse.
Just fancy a Dean Smith and Grace lathe but before I start looking need a good idea of what is practical  or suggestion on any lathe with a 50 mm or bigger headstock bore and about 6 foot between centers . Mike
Offline Jo
Re: Phase converters
« Reply #1 on: October 13, 2016, 03:32:08 PM »
If you look to fit a rotary transformer converter it would happily run a 15hp motor on a 80A supply  :ddb:
Jo
Offline PK
« Reply #2 on: October 13, 2016, 06:38:29 PM »
You can work it out:
      Volts x Amps x Converter Efficiency = 2 x Motor rating
The 2 x motor rating is to allow for startup loads. You can reduce this factor if you have slower rated circuit breakers http://www.diynot.com/wiki/Electrics:MCB2
Not sure about rotary converters, but their solid state brethren run at about 80% (as a budgetary figure).
So you have 220 x 80 x 0.8 /2= 7KW = 9.4HP
PK
« Reply #3 on: October 14, 2016, 02:54:15 AM »
I did blow the 80 amp company fuse with my 15 kW Transwave converter but it wasn't the only thing running. The nice man who came out on the emergency call out uprated me to a 100 amp fuse when I showed him my workshop.
Offline smiffy
« Reply #4 on: October 14, 2016, 08:07:46 AM »
Thanks for the replies. Just need to crack open the piggy bank and think I will go down the rotary converter route  Mike
Offline graham
« Reply #5 on: October 22, 2016, 03:05:21 PM »
Give this firm a bell,got mine off them brill.http://www.drivesdirect.co.uk/
