Author Topic: topslide setting  (Read 29485 times)
Offline wheeltapper
  • Spixworth Norfolk
topslide setting
« on: September 28, 2016, 11:36:06 AM »
Chester Comet lathe.
The numbers on my angle graduation strip wore away years ago and setting angles has been a pain.
I just started making some pullys to convert my minimill to belt drive ( dont ask :doh:.
I came up with this quick way of doing it.
this is the plate the topslide mounts on to,
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/angle%20setting1_zpsb3zh80rc.jpgtopslide setting
I drilled two m4 holes on each side and at the front.
now I can quickly fix a steel strip on the side and use a perspex gauge to set the angle.
here's one for the pulley,
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/angle%20setting2_zpsyjt4mlrb.jpgtopslide setting
and one on the front for screwcutting.
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/model%20engineering%20stuff/angle%20setting3_zpso82q4sfx.jpgtopslide setting
I works a treat and it's quick.
the angles might not be accurate to 30 seconds but they are consistent.
hope this is of interest to someone.
Oh, in case you did ask, I trashed the low speed gear in the housing. :Doh: :Doh:
cheers Roy.
Re: topslide setting
« Reply #1 on: September 28, 2016, 02:37:26 PM »
Hi Roy  :thumbup:
Thats a canny solution to the graduation problem , at times I am squinting to see if things are at the angle I require when setting the Myford compound over   :palm:
Offline wheeltapper
  • Spixworth Norfolk
« Reply #2 on: September 29, 2016, 05:47:10 AM »
Cheers Rob.
It seems that you were the only one who thought it was interesting, ho hum. :bang:
Roy.
« Reply #3 on: September 29, 2016, 06:35:20 AM »
It's always interesting, we just don't always pipe up....   I know what you mean though, sometimes you wonder if people are interested.   Don't forget we get lots of lurker's.
 :thumbup:
Offline modeng200023
« Reply #4 on: September 29, 2016, 09:22:57 AM »
I'm one of those!
Offline Jonfb64
« Reply #5 on: September 29, 2016, 10:14:25 AM »
Me too :mmr:
« Reply #6 on: September 29, 2016, 10:24:38 AM »
 Wheeltapper,
 You first posted this on the 28th September. Since then 169 people have viewed it.
As today is the 29th September, I don't think you have done too badly for interest.
Don't get disheartened if people are slow responding.
« Reply #7 on: September 29, 2016, 11:19:29 AM »
Wheeltapper (and all),
OK, this has been a pretty busy month for me with 4 "concurrent" design projects on the table.  This is the first that this thread garnered my attention.  [The Tralfalmagorians have been holding me captive.]
I often have to make cuts that are within .001 runout to a given angle.  The attached PDF shows the approach I came up with many years ago.  Hopefully, this will give you some ideas to improve your set-up.
Offline mfletch
« Reply #8 on: September 29, 2016, 12:00:16 PM »
Good idea and works thanks for sharing
Offline wheeltapper
  • Spixworth Norfolk
« Reply #9 on: September 29, 2016, 12:52:25 PM »
Wheeltapper,
Don't get me wrong, I'm not going to sit in a corner and sulk  :lol:
I just thought it had died.
Roy.
Offline mexican jon
« Reply #10 on: September 29, 2016, 03:07:49 PM »
I've only just seen it  :scratch: and I like it  :thumbup: removes any error  :thumbup: well as long as the angle plates are made correctly  :lol:
« Reply #11 on: September 29, 2016, 06:12:39 PM »
a job well dun brill
« Reply #12 on: September 30, 2016, 01:56:35 AM »
And that Roy, is precisely the reason I too changed to belt drive - and love it. In my case it was a quill drop whilst beginning to fly-cut. You aint alone my friend. Plastic confetti gears don't drive the quill at all well do they?
Offline wheeltapper
  • Spixworth Norfolk
« Reply #13 on: September 30, 2016, 05:10:34 AM »
You're not wrong there  :bugeye:
It was flycutting that did mine as well, I was trying to clean up a chunk of angle iron that was apparently made from the core of a dwarf star.
Said chunk now resides at the bottom of the garden. :D
cheers
 Roy.
« Reply #14 on: September 30, 2016, 12:36:12 PM »
Cheers Rob.
Roy.
Hi Roy
I often feel like I am posting talking to myself   :lol:
On the subject of angle things Arceuro  do a few sets of angle blocks that may be just the ticket for setups like yours .
http://www.arceurotrade.co.uk/Catalogue/Measurement/Parallels-Angle-Blocks-Test-Bars/Precision-Angle-Block-Set-10pcs
I may have myself a set , a geeza can never have enough tools  :)
« Reply #15 on: September 30, 2016, 12:54:34 PM »
Well I document my rebuild projects so that I can refer back to them later on to confirm details - often years later. If others are joining me for the journey and enjoying it, then that's a bonus  :thumbup:
I think a lot of people read these threads but refrain from comment, but never the less benefit enormously in that they learn new 'tips and tricks', and the use of your angled pieces is a prime example of a good 'tip or trick'
Offline wheeltapper
  • Spixworth Norfolk
« Reply #16 on: September 30, 2016, 12:57:18 PM »
Hi Rob
That's not a bad price for those angle blocks, if I ever have £30 lying around .
If I went that accurate I'd have to make sure the side of the plate was truly at a right angle to the bed of the lathe.
cheers
Roy.
« Reply #17 on: September 30, 2016, 05:24:52 PM »
you right their rob we can never have to much tooling
Offline howsitwork?
« Reply #18 on: October 02, 2016, 04:31:39 PM »
Good ideas all round and with a birthday approaching......
I may let her treat me :D
Offline mechman48
« Reply #19 on: November 04, 2016, 03:00:29 PM »
ArcEuro ... Christmas is coming, the geese are getting fat... I think  :scratch: so maybe a subtle hint... or two  :headbang:
George.
George.
