Author Topic: Completely off topic. *bragging*  (Read 67942 times)
Offline NeoTech
    • Roughedge Hobbyworks
« on: September 15, 2016, 10:26:19 AM »
So after 4 weeks of cold and wet weather - and my pickup truck breaking down.. i decided.. **** it, i take the big boys car out of the garage.
It has a 489 bigblock and they are known to be a bit hesitant with my weather.. Especially on E85.. But in a glorious moment i installed a Holley EFI in it.. And.. well listen..
Re: Completely off topic. *bragging*
« Reply #1 on: September 15, 2016, 10:34:38 AM »
They built that wrong, the steering wheel's on the wrong side  :lol:
Offline NeoTech
« Reply #2 on: September 15, 2016, 10:43:19 AM »
Uhm.. what is there 3 countries left in the world still driving in the so called "suicide lane".. So i think its correct. ;D
« Reply #3 on: September 15, 2016, 10:46:22 AM »
You forgot Malta, where they drive on the side with least pot holes unless the sun is in their eyes  :clap:
« Reply #4 on: September 15, 2016, 12:21:57 PM »
Let's see under the hood  :poke:
Offline NormanV
  • United Kingdom
« Reply #5 on: September 15, 2016, 01:04:46 PM »
Ahem, Rob. I think you mean bonnet.
« Reply #6 on: September 15, 2016, 01:45:23 PM »
Surely 'under the Hood' is the North Atlantic seabed  :med:
....ok I'll get my coat
(for those the don't understand the reference: https://en.wikipedia.org/wiki/HMS_Hood  )
Offline NeoTech
« Reply #7 on: September 15, 2016, 05:43:59 PM »
I actually didn't have any pics taken after the install i guess i was busy driving it instead....
This was during the EFI install anyway..
I did make some custom bracket for the pressure regulator on the cnc machine tho.
And some other parts i was terribad at havent photographed it seems.
« Reply #8 on: September 15, 2016, 08:33:00 PM »
Verry nice!
« Reply #9 on: September 16, 2016, 10:31:57 AM »
Gotta love a big-block with a cross-plane crank!  :drool:
Offline NeoTech
« Reply #10 on: September 16, 2016, 10:45:46 AM »
Yeah it sure comes with a special sound profile, its a bit of  a tugging noise..  didnt wanna put in a balance tube in the exhaust because i like that the pulses differentiate between the pipes so noticeable.. but i would gain about 50hp if i did... The addiction to horsepower may overcome my love for the sound.
« Reply #11 on: September 16, 2016, 10:58:05 AM »
Sounds like a  :proj: madmodder project! A balance pipe with built-in butterfly valve & cabin control - so you can have the sound when you want it, OR the horsepower!  :poke:
Edit to add: You could hook it to the throttle.... so when you mash the loud pedal, the butterfly opens & gives you max HP; back it off & you've got that noise again  :smart:
Offline NeoTech
« Reply #12 on: September 20, 2016, 05:05:50 AM »
hehe i could actually even hook it into the Holley EFI system and control it on the RPM range or on the MAP range for timing when you actually would need the balanced tube to open in the power curve. ;D
