Author Topic: DDCSV1.1 4 Axis controller  (Read 1750915 times)
Offline Merlin201314
  • London
« Reply #250 on: November 25, 2016, 05:17:44 PM »
Here is the painted panel guys
« Reply #251 on: November 25, 2016, 06:02:15 PM »
Looking good apart from the bottom right hand corner - what happened there  :scratch:
  • London
« Reply #252 on: November 25, 2016, 06:03:38 PM »
Nothing,  is just the light 💡  reflection
Sent by my tapatalk
  • London
« Reply #253 on: November 25, 2016, 06:05:45 PM »
Will post better pictures tomorrow  :thumbup: :thumbup:
  • London
« Reply #254 on: November 26, 2016, 05:51:09 PM »
Hi all,
here is the final result,
i'm not happy at all about how i positioned the spindle switch! :bang: It should be much lower.
Never mind, the next will be much better than this one......... :ddb:
« Reply #255 on: November 27, 2016, 06:25:37 AM »
Question:
Has anyone used and calibrated the Backlash parameters #437 to #445?
If so do they work?
  • London
« Reply #256 on: November 27, 2016, 08:12:00 AM »
Someone in another forum try, he said they works great for him, but honestly i do not use them as i do not have backlash in my axis.
« Reply #257 on: November 27, 2016, 09:12:58 AM »
You may not be able to measure it, but trust me you DO have backlash  :lol:
  • London
« Reply #258 on: November 27, 2016, 09:17:14 AM »
I do agree with you, but as i changed the ballscrew for the C0 grade, even if my backlash is 0.004 (and should be less as the ballscrews are pre-charged) i cannot measure it as my caliper do only 0,01..... so i do not have backlash
 :ddb:
Offline Simon0362
« Reply #259 on: November 27, 2016, 01:54:59 PM »
Hum.........
After all of the uploading, downloading and all the rest of the jazz, I seem to have lost the parameters that I setup the DDCSV1 with.....
I have at least one image of the firmware contents, does anyone know which file contains the actual settings (like steps per mm, etc) and how - if possible - I can use this to replace the default numbers.
Otherwise I will have to start again from zero which is *not* my Sunday evening plan.... :(
  • London
« Reply #260 on: November 27, 2016, 02:06:15 PM »
Hum.........
The file is called "settings"  and you have to reset all the parameters,  as is not a text file,  so.....  Take your time and input all parameters again,  and then, I strongly recommend you to make a copy of it...
Sent by my tapatalk
Offline BrokenEye
« Reply #261 on: November 27, 2016, 02:32:07 PM »
I think there is a textfile called UserVar that is supposed to be another way of entering parameters, how the hell it works or what the format is I have no Idea. this is from the information Sheet, such as it is.
3.4.1Parameter loading method
 "This file is a text file with an expanded-name of set. The users can modify all the parameter
and all the parameter can be modified in the parameter list. We will provide a demo of set file
and the client can only modify the corresponding item in this demo. Pay special attention that
each parameter item has the only corresponding parameter mark. This parameter mark can’t be
modified or deleted."
 hope this is of some use
Backup, then Backup the Backup then Backup again
Offline Benedikt
« Reply #262 on: November 27, 2016, 02:43:12 PM »
We never figured out how this was supposed to work. Unfortunately. I might think about writing a quick and ready program for altering the settings file on a PC. Might be worth it. Especially if it would give some contextual help and possibly some converters. I was just thinking, why not a PHP program so people could use it online  :scratch:
  • London
« Reply #263 on: November 27, 2016, 02:47:42 PM »
Why not?  A php would be better I think
Sent by my tapatalk
Offline Simon0362
« Reply #264 on: November 27, 2016, 04:24:50 PM »
A PHP program would be an excellent idea - massively less tedious than 'step, step, step, step, ' 'enter', 'up arrow', 'enter' for each yes/no choice!
Offline Benedikt
« Reply #265 on: November 29, 2016, 03:28:52 AM »
Great, so PHP it'll be.
I'll work on it when I find some spare time.
Offline old Zozo
« Reply #266 on: November 29, 2016, 02:55:16 PM »
Hi All and welcome,
I'm a​n old beginner from Hu​n​gary. ​ :)​
I just have this ​controller, version: 2016-06-10-80NOR
I would like use it with TB6560 3ax. stepper driver, but I can't find, where can I decrease
500KHz (200ns) pulse to 30KHz (33.333ns)  due to no this option anymore.
How could I solve this problem?
Thanks for your help.
  • London
« Reply #267 on: November 29, 2016, 03:24:19 PM »
Hi, and welcome,
First of everything have a look at this one, is very interesting about your driverr
http://www.glyn.de/data/glyn/media/doc/TB6560AHQ-E_en_090324.pdf
This can give you an idea of your stepper controller to start.
The only parameter you can adjust on the controller, version: 2016-06-10-80NOR is in the setting page, line 416 "delay between step and direction" "xxxxxxns"
Hope that can help a bit
Regards
Offline old Zozo
« Reply #268 on: November 29, 2016, 04:05:25 PM »
Hi, and welcome,
Regards
Thank you very much for your help. I will try some trick tomorrow...
  • London
« Reply #269 on: November 30, 2016, 04:36:59 AM »
Old Zozo,
a question for you, where did you get the 33.333 conversion of the 30KHz in ns(p) p=period?
Because my conversion is totally different, so maybe something is wrong? Or the decimal point is in the wrong place?
For the avoid of doubt, check this one:
https://www.unitjuggler.com/convert-frequency-from-kHz-to-ns(p).html?val=200
Anyway, the division is 1/Freq,   EXP: 1/8000000(8MHz)=125ns
so, 30 KHz are 33333.3333ns. am i wrong?
Regards
Offline old Zozo
« Reply #270 on: November 30, 2016, 06:28:49 AM »
Hi Merlin, you are right, of course.   I was wrong, I wrote microsec, no ns  :bang:
  • London
« Reply #271 on: November 30, 2016, 06:31:53 AM »
No worries, we are here to help if we can :beer:
Offline old Zozo
« Reply #272 on: November 30, 2016, 06:57:41 AM »
Thanks.  (Hungarians uses decimal point this way: 33.333,333   English uses 33333.333)
I looked at my TB6560 driver, the OSC capacitor a small SMD part, unfortunately I can't change it.
I'll try some parameter later yet.
Offline old Zozo
« Reply #273 on: November 30, 2016, 12:48:46 PM »
I'm not happier. I tried everything.
Stepper motors are very loud, they runs irregular, noisily, jarring.
You can hear.
https://drive.google.com/file/d/0B92KqmQ4Au7naVRnSEU0M1BQQnc/view?usp=sharing
After 10 minutes motors are hot, with half current setting.
When they are standby,  all vacillate.
What I tried:
TB6560: http://www.osservatoriobassano.org/TCS2015/3%20Axis%20TB6560%203.5A%20Stepper%20Motor%20Driver%20Board%20Manual.pdf
-half, 1/8, 1/16 step
-decay mode slow to fast
DDCSV1.1:
-time between DIR and Pulse  300 to 1500
-pulse signal LOW an HI
I have no more idea.
Perhaps software down-grade...
  • London
« Reply #274 on: November 30, 2016, 01:33:47 PM »
Hi,
I give you my opinion, but just take it as an advise, nothing more...
The controller board you are using is manifactured for a Mach3 use, as is using a parallel port, and is tuned for the latency and other problem that the parallel port connected to a PC have in real time running.
Your new controller is much much faster and have nothing to do with this board :palm:
You need to use separate stepper driver for each axis, and you can find them really cheap on ebay if you want to start with an entry model.
I would suggest you to buy a good one once and forever, so your system is then matched as it should be, quiet and running cool.
Then get rid of the parallel port once and forever, as this is the pourpouse to buy that kind of controller...
I will make a short video of mine running with digital stepper driver http://www.ebay.co.uk/itm/EU-Stock-4PCS-DM556D-Digital-Stepper-Motor-Driver-50VDC-5-6A-For-CNC-Router-/142190444856 (those are mine, but you dont need that much, you can find digital ones and much much cheaper.
Those one are perfect  http://www.ebay.co.uk/itm/CNC-2DM542-Microstep-Stepper-Motor-Driver-4-2A-Controller-24-48V-DC-Nema17-23-34/251117211299
i am happy with that and no missing steps or heating or noise, strong holding torque and auto-tuning firmware..... just have a look if you have time.
Once you have built the controller it will work even for future machines if you upgrade the chassis.
Any comment is fully apreciated as usual
Regards
