Author Topic: home made mill  (Read 72868 times)
Re: home made mill
« Reply #25 on: October 01, 2016, 03:49:03 PM »
DavidA  hi hear is sum pics of the mill Colom I can move the Colom all the way from left to right   and there is a pic of watt john has to cut in to the extension right pics
Re: home made mill
« Reply #26 on: October 22, 2016, 03:38:44 PM »
hi all john milled in the two cut outs for the two nuts that will hold the extension to the Colum  and a brill job he did thanks john
set the extension up today to find out haw much of the extension needs cutting dawn by the length of the extension will be 130MM long by the time I mashie the end right pics
Re: home made mill
« Reply #27 on: October 22, 2016, 04:54:32 PM »
It was a pleasure Mate
There is a bit video on my you tube of the machining
Re: home made mill
« Reply #28 on: October 22, 2016, 05:28:43 PM »
Its coming along verry nicely good job!
Re: home made mill
« Reply #29 on: October 29, 2016, 04:47:44 PM »
hi all on the final stretch was at work today so I finish off the mill head extension set it up in the 4 jaw chuck then clocked it in  then took the end dawn to size then to length then put the grove in for the clamping brackets will put sum more pics up tomorrow of the hole thing coming together right sum pics of watt was dun today and thanks for all the comments
Re: home made mill
« Reply #30 on: October 29, 2016, 04:50:06 PM »
Looking good Bob
Re: home made mill
« Reply #31 on: October 29, 2016, 04:51:07 PM »
thanks john will get it all together tomorrow
Re: home made mill
« Reply #32 on: October 29, 2016, 04:58:34 PM »
I cant wait to see this finished.....
I've watched the vids John posted on Youtube, machining the parts 'n' all....quite entertaining too  :lol:
Bob,
I hope you get a lot of enjoyment out of using the machine as much as you have had putting it together...
Re: home made mill
« Reply #33 on: October 29, 2016, 05:13:20 PM »
I hope to
Re: home made mill
« Reply #34 on: October 30, 2016, 06:27:28 PM »
hi all well the extension fits but im going to have to make it lighter so this will involve cutting it in have then boring etch have out then welding them back together that ant a problem all that needs doing gnaw is make a stand for it sort out the electric's on that point dus any one no the type of capacitor needed for the motor the one that's running it at the minute is my sper one of my lathe any way pics as promist
Re: home made mill
« Reply #35 on: October 30, 2016, 06:50:25 PM »
Bob,
For the capacitor,
Do you have any details on the motor you could post up please
Re: home made mill
« Reply #36 on: October 30, 2016, 06:53:35 PM »
Looks good Bob , why do you need to make it lighter?  Is it not raised a d lowered by screw mechanism so would lift ok and be more rigid ?
  Keep up the good work Bob , it's almost done  :thumbup:
 Cheers Mick
Re: home made mill
« Reply #37 on: October 30, 2016, 06:59:44 PM »
yep its raised by a screw but its jamming on the Colom not a problem going up  but jams on the downward move support the mill head not a problem I don't think I will loos out in boring out the middle  will still have a wall thickness of 30mm carnet go bigger as it will go in to the slots that john made
Re: home made mill
« Reply #38 on: October 31, 2016, 11:18:55 AM »
That's some extra reach you have there.
I think I may settle for half as much.
Sorry can't help with the capacitor details, my EMCO is three phase.
Offline millwright
  • Leeds West Yorshire
Re: home made mill
« Reply #39 on: October 31, 2016, 02:39:05 PM »
Thats looking very good now Bob, a nice handy machine for you. I bet Your pleased now its nearly done soon be making swarf.
Re: home made mill
« Reply #40 on: October 31, 2016, 05:43:39 PM »
hi I will get the in fo off the motor tomorrow the length of the extension is 6 inches mad it that long so the mill head will cover the with of the table from front to back  im going to clock the head in tomorrow night so their will be sum pics of that on tomorrow    thanks all for the comments
Re: home made mill
« Reply #41 on: November 01, 2016, 06:05:01 PM »
hi all just a bit more clocked the head in tonight I had to put sum 0.25 mm shim in the top you will see them in a pic to tilt the colam over to clock it in put the vice on and clocked that in to I need to make sum t nuts up right the in fo  on the motor is sa follows TYPE AOR-63-4
D/M 0.18 volt 440 amps 0.55    55Hz U/min 1380 KW 0.24   N.R 617103 and the make of the motor is wiener starhstrom  werke right pics
Re: home made mill
« Reply #42 on: November 01, 2016, 06:49:27 PM »
Bob,
For your motor capacitor, you most use an Steinmetz connection, the capacitor value could be calculated by the following:
C = 36*P* [(220/U) Squared] * 50/f where: C is microFarads, P is motor power output in kW, U is the single phase voltage and f is frequency in Hertz.
Re: home made mill
« Reply #43 on: November 01, 2016, 07:10:42 PM »
er ok  electrics  baffle me thanks for the help
Re: home made mill
« Reply #44 on: November 01, 2016, 07:23:56 PM »
Bob,
Doesn't the cap you robbed of your other machine have a value marked on it?
Is the motor definitely three phase?
I'll do the calc and tell you the value of the capacitor you need....
Re: home made mill
« Reply #45 on: November 01, 2016, 07:29:43 PM »
Ok,
Rule of thumb is 70 mfd per 1kw ......
If the kw rating of the motor is 0.25 kw, then a 22mfd capacitor is what you need...but it must be rated for 250v AC....
Re: home made mill
« Reply #46 on: November 02, 2016, 07:08:52 AM »
The info I have on my EMCO indicates that they come in two versions (electrically).
The single phase 0.16 Kw (0.25 HP)
and the three phase 0.25 Kw (0.34 HP)
I have the parts list and exploded drawings for the machine if you need any parts info.
Re: home made mill
« Reply #47 on: November 03, 2016, 12:57:49 PM »
hi all thanks for the help on the cap the one that's on that's off me lathe can not tell watts printed on it cos its all bin rubbed off lol but the lathe motor is bigger    there was a chap on the bay selling the two of them I.E the one for the lathe motor and the one for the mill motor I sent him a email asking if he wood sell me the one for the mill or give me the info of the one for the mill  but got no answer back er  don't think its 3 phase as its running on 240 volt
Offline seadog
  • NE London
Re: home made mill
« Reply #48 on: November 03, 2016, 01:13:02 PM »
If it's 440v it must be 3 phase Bob
Re: home made mill
« Reply #49 on: November 03, 2016, 01:26:37 PM »
o well will have to look in to it will probably have to by one of them inverter things
