Author Topic: MINI EXCAVATOR BUCKET BUILD  (Read 26202 times)
Offline ieezitin
« on: May 29, 2016, 12:33:42 PM »
Hello lads
I had a job come into the shop and he wanted a bucket made for his Mini Excavator, he supplied me with a working bucket so i could make plans for the new one from that, the original bucket was 12 inches wide and he wanted one that was 36 inches wide, this enables him to scrape more earth at one time as he is primarily in the landscaping business. So here is the story in pictures...
The sketch..
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160515_114847_zpsd7gfgdqb.jpgMINI EXCAVATOR BUCKET BUILD
1/2'' thick side plates made first, i had to weld extra plate together as i did not have enough plate stock to make the side walls..
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160515_114924_zpsnwdbnlwb.jpgMINI EXCAVATOR BUCKET BUILD
A full size template made from cardboard so i could chalk the profile on the plate.
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160515_115608_zpsse46octv.jpgMINI EXCAVATOR BUCKET BUILD
With the skin cut in sheet form i was going to roll the profile through my roll-brake set up but the skin is 3/16'' thick and my rolls would not profile it so i had to come up with another idea for getting the plate rolled to the desired shape so brute force was chosen and the method of fabricating it.
 http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160515_141152_zps0plcozsk.jpgMINI EXCAVATOR BUCKET BUILD
1/2'' thick Side wall plates cut and prepped for welding..
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160515_141144_zpsxsdjn73s.jpgMINI EXCAVATOR BUCKET BUILD
Tacking the plates to the skin and getting square..
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160515_143150_zpslqljajdl.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160515_151438_zps3dumei24.jpgMINI EXCAVATOR BUCKET BUILD
Now the brute force bit..... i am using the table as a strong back and by tacking the plate to the table to hold it i used a flat bar to keep the bend moment close the the plate...
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160515_160553_zpsrmjavu16.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160515_160603_zpsntuhsmz8.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160515_160614_zpsrzvb5lly.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160515_164729_zpswjhnupzt.jpgMINI EXCAVATOR BUCKET BUILD
I ran out of leverage so i had to put a couple of dogs on the side and use all-thread and the applied force to bring this into shape..
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160515_185109_zpseufagipk.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160516_191757_zpsrq2lzc3s.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160515_173240_zpsoaogf74b.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160517_164153_zpszvy0r6pb.jpgMINI EXCAVATOR BUCKET BUILD
Now all i had to do was squeeze down the top profile, i had to score / slit the plate with a cutting wheel to make the brake as the steel plate was just to strong...
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160518_165126_zpsiowiiplf.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160518_165151_zpsjdehptyb.jpgMINI EXCAVATOR BUCKET BUILD
Time to make the cleats that acts as the receiver to the excavator arm, another cardboard template was made..
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160521_152107_zpsvca4iabd.jpgMINI EXCAVATOR BUCKET BUILD
Plates cut ready for boring on the mill... i made two cleats and tacked them together so they would be exactly alike..
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160522_093840_zpsi4sih2yi.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160522_093902_zpsbcsf5xzg.jpgMINI EXCAVATOR BUCKET BUILD
All marked up and ready for boring on the mill.....
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160522_095705_zpsxozyyj1u.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160522_093851_zpsd7kigzu4.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160522_105346_zpsiw34ymwj.jpgMINI EXCAVATOR BUCKET BUILD
I made a gage for the fit, the hole was .002 oversize because i am using two pins to align my fit and act as stay when i weld them and the bucket..
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160522_114729_zpskeege6re.jpgMINI EXCAVATOR BUCKET BUILD
Both holes bored and the pins installed..
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160522_131641_zpsurnpn86p.jpgMINI EXCAVATOR BUCKET BUILD
Now to install the cleats ... now you see the reason for the pins...
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160522_145950_zpsodlnzonv.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160522_150000_zpsxvmsudxs.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160522_150014_zpsf91det17.jpgMINI EXCAVATOR BUCKET BUILD
All done and dusted........ one bucket was created..
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160523_191902_zpsygxuucjf.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160523_191853_zpsstk6dete.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160523_191847_zpsmrfqjoph.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160523_191916_zpsmm6h3kbo.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160523_192010_zpsx7jdlhez.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160523_191818_zpsqmitkrtr.jpgMINI EXCAVATOR BUCKET BUILD
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160518_185316_zps91mfuqhy.jpgMINI EXCAVATOR BUCKET BUILD
it sorter kicked my arse but i beat the bastard in the end......  Now for the reward.... MILLER TIME! :beer:
http://i721.photobucket.com/albums/ww212/ieezitin/Workshop%20Projects/JERRY%20STRICKLAND%20BUCKET%20BUILD/IMG_20160514_184716_zpszmjq4uuf.jpgMINI EXCAVATOR BUCKET BUILD
Thanks for looking..
Anthony.
Re: MINI EXCAVATOR BUCKET BUILD
« Reply #1 on: May 29, 2016, 01:35:37 PM »
A very neat job  :thumbup:
Labour intensive though - would that plate not have rolled more easily with a tickle from the O/A torch ?
(posted from a very sunny Isle of Wight, with a dog snoring away on my lap after a 12 mile walk - please send Ibuprofen  (for me, not the dog  :bugeye: )
« Reply #2 on: May 29, 2016, 01:49:06 PM »
 :clap: :clap: Very nicely done Anthony a cracking bit of fab work  :thumbup:
« Reply #3 on: May 29, 2016, 03:47:01 PM »
Very well done "proper job"
« Reply #4 on: May 30, 2016, 10:08:32 PM »
Nice bit of work there. Job well done.
 :mmr:
« Reply #5 on: May 31, 2016, 04:54:32 PM »
Severalm Brilliant Mad Mods in there. Loved the way you rolled the sheet around the side cheeks - inspired modding
Offline nrml
« Reply #6 on: June 30, 2016, 04:51:09 PM »
That's one sturdy workbench you have there. Nice job :thumbup:.
