Author Topic: Chinese Digital readouts  (Read 11236 times)
Offline smiffy
« on: May 17, 2016, 04:43:40 PM »
 Looking on flea bay there are lots of cheap digital read outs , are they any good ?
 I want to fit a read out to my lathe , what would the collective recommend
        Thanks Mike
Re: Chinese Digital readouts
« Reply #1 on: May 17, 2016, 05:06:14 PM »
Mike,
I have a number of these on my milling machines....
http://www.arceurotrade.co.uk/Catalogue/Measurement/Digital-Readouts-with-Dedicated-Remote-Display/Digital-Readout-Bars-with-Dedicated-Remote-Display
My ultimate goal is to have the scales read out on this...
http://www.yuriystoys.com/2012/09/do-it-yourself-dro-with-arduino-and.html
I already have a number of Arduino micros and I bought an Android tab, just need to sort it all out...
Like this guy....
http://www.modelenginemaker.com/index.php/topic,2865.0.html
Offline PK
« Reply #2 on: May 17, 2016, 05:19:45 PM »
I have one on X for my lathe. It seems robust. The one on the mill quill chews batteries though..
« Reply #3 on: May 17, 2016, 05:30:00 PM »
Mike -- If they are good out of the box, they tend to stay good.  If they are bad out of the box, there is no salvation.  Therefore, as soon as you get one, set it up and take a number of known measurements (several times) as a quick check.  Be sure to run them off of a power supply when you install them as the batteries go bad quickly when they get cold.  With those caveats, I use them regularly.
I use the Harbor Freight digital calipers quite a bit.  I bring in a couple of the batteries and (say) four well "ranged" gage blocks to check them with before I purchase them.  The only bad ones were "gifts" from those who did not know the "secret."
Offline Ed ke6bnl
« Reply #4 on: May 17, 2016, 06:34:53 PM »
Mike,
Like this guy....
I put the accuremote scales (the blue ones) on my Burke Millrite and they worked great, got a good deal on a Bridgeport and sold the mill.  I made and used Yuiys bluetooth  read out for the accuremote gages that worked great and no longer use it would sell for $70. I chose to get some Chinese DROs  XYZ  for the new to me mill.  For a lathe they may be the best choice because of limited mounting areas. the mill has room for the larger glass scales, the good thing about the igaging mag scales they can easily be cut, I used my bandsaw.
1950 Ford F1 streetrod
1968 ecotec powered Baja Bug kink coil overs
1953 Chevy AD ready for 4 cyl. cummins and nv4500
Offline smiffy
« Reply #5 on: May 19, 2016, 04:13:13 AM »
 Thanks for your replies I will buy 2 and see how well they work on my Arborga mill   Thanks Mike
