Author Topic: I should have known better  (Read 43260 times)
« on: March 20, 2016, 03:58:34 AM »
In the dark old days when I went to work:- it was drummed into us the importance of knowing that the material you used was of the correct grade and quality, so you had to keep a detailed build records the material Certificates of Conformity for every part that you made so that things could be traced back if anything went wrong, particularly with a safety critical part.
Wind forward to a happily retired Stew beavering away in is shed making the regulator for his loco, the drawing states that the cone and rod should be made from stainless steel, the material for the rod was ordered and stainless steel material was delivered as ordered, for the cone I found a piece of what I thought was stainless steel salvaged from a printer, it looked and tasted like stainless so certain was I that I didn't bother to test it with a magnet, the cone was made and silver soldered to the Rod and the whole lot fitted to the loco, when it came to running the loco last year all worked fine.
Last week after the winter lay off and after a bit of maintenance work on it I took the loco out for a pre season steam up just to test everything out. With a good pressure showing on the gauge I put it in gear and she started to move off with the regulator still closed:- panic panic, quickly put her back mid gear and she stopped phew  :scratch: checked every thing out regulator closed put her in gear and off she set again, obviously there was something wrong with the regulator, nothing for it but to drop the fire and take her home for an investigation.
Stripped the regulator down and it was immediately obvious what was wrong the cone was heavily corroded it was made from mild steel:- it must have been a piece of ground mild steel that I salvaged from the printer making it look like stainless   :doh:
http://i431.photobucket.com/albums/qq32/sbwhart/Simplex/DSC02652_zpsfmin1pok.jpgI should have known better
I was lucky it could have resulted in a nasty accident but I got away with it this time.
I've now made a new cone and recut the seat and its now fitted:- I'm absolutely certain that it is made from stainless steel this time.
http://i431.photobucket.com/albums/qq32/sbwhart/Simplex/DSC02656_zpszwbxhcwb.jpgI should have known better
Re: I should have known better
« Reply #1 on: March 20, 2016, 04:16:41 AM »
I know how you feel I rebuilt a Minx fitted the crosshead pump using the balls , I thought were stainles and after a year the pump droped pressure ,  to get it out had to remove crank axle con rods and most of the valve gear , our first track day is Easter Sunday checking everything is the plan for today .
Offline Eugene
« Reply #2 on: March 20, 2016, 05:41:00 AM »
Stew ... not much comfort I know, but the finish on printer rod isn't merely ground mild steel, its electroless nickel plated too. This gives good corrosion and wear resistance as well as looking a lot like stainless. There was an outfit in Telford some years ago named Marusawa that produced zillions of printer rods per annum, and they had one of the biggest electroless set ups in UK.
The biggest of all was Seagate the disk drive people, in Limavady, Norn Iron. They made the hard disks from an aluminium substrate that was electroless nickel plated.
Eug
