Author Topic: What to look for in a plasma cutter  (Read 10960 times)
« on: January 30, 2016, 07:54:21 AM »
Spring is a comming and the urge for new tools is on me!
Hope someone can clear up a few questions on plasmas:
How do PCs start cutting? Some models talk about High Frequency starts other about touching the work piece. Is this like TIG i.e. Scratch starting on the cheaper models? HF on the better end?
How do you tell if the machine is fitted with a low pressure safety cutout (Do Rtechs have this, what about the CUT nn range of machines.
What about the SIP range?
Any one bought from the German Stahlwerk on e-b?
Obviously need an air dryer and recomendations.
Offline mfletch
Re: What to look for in a plasma cutter
« Reply #1 on: January 30, 2016, 08:29:19 AM »
I have Retch 40amp plasma cutter it has low pressure cut of and its HF start I wouldn't get a scratch start, I've cut 15mm with mine but its pushing it so a easy 12mm cut and believe me it makes life a lot easier.
« Reply #2 on: January 30, 2016, 10:27:18 AM »
Bought a really cheap Chinese machine from local farm shop as it was just for one job cutting stainless steel.  It has HF start and to be honest has never let me down, had it about 5yrs now !!!   Must have been a lucky one.
 :D
Ha, guess I should have said farm supply shop.  Lot of iron in our soil so the plasma is ideal for slicing carrots.
« Last Edit: January 31, 2016, 04:18:21 AM by Joules »
« Reply #3 on: January 30, 2016, 10:50:42 AM »
Blimey Joules, what do the farms grow in your area ? Our local farm shops sell vegetables and suchlike, not plasma cutters  :lol:
Offline mcostello
  • Lancaster, Ohio
« Reply #4 on: January 30, 2016, 12:59:57 PM »
Maybe tougher vegetables :clap:!
Offline Auskart
« Reply #5 on: January 30, 2016, 02:18:54 PM »
Have one of the cheap Chinese Plasma, Tig & Stick combo's , has 40 amp Plasma and 150 amp Tig and Stick can't fault it works well.
« Reply #6 on: January 30, 2016, 04:34:50 PM »
This may help
You need a pilot ark
The more power the better (plenty in reserve)
