Author Topic: A generator for Elmer.  (Read 53921 times)
Online Joe d
Re: A generator for Elmer.
« Reply #25 on: January 10, 2016, 10:38:16 AM »
Abraham:
This is looking really good so far, I'm much enjoying following along.
Looking forward to the next installment!
Cheers, Joe
Offline PK
« Reply #26 on: January 10, 2016, 04:59:55 PM »
Wow...just wow... I'm so impressed with the thought and skill that's going into this project!
Offline modeldozer
  • Valencia, Spain
    • AJ´s Truckmodeling
« Reply #27 on: January 17, 2016, 12:44:24 PM »
Hi Joe, thank you for the kind comments.
Had to replace the bitumen felting of my shed’s roof so did not do a lot on the generator.
A parallel was used to set the post square while holding it in the lathe collet chuck clamped to the mill table.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00073.jpgA generator for Elmer.
A stepped slot was milled in each post.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image0074.jpgA generator for Elmer.
for locating the brush holders.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image0075.jpgA generator for Elmer.
The holders ready for soldering.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image0076.jpgA generator for Elmer.
Abraham
Offline modeldozer
  • Valencia, Spain
« Reply #28 on: January 31, 2016, 11:40:06 AM »
Hi all,
The shed roof is finally finished and will hopefully keep my machines dry.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00077.jpgA generator for Elmer.
Had to make an extension for the armature shaft to be able to fit a pulley, but try, as a may could not get it to run true once fitted to the armature.  For the fourth attempt ended up using an old wood router bit as a boring bar for he recess in the end of the shaft, witch seems to have done the trick.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00078.jpgA generator for Elmer.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00079.jpgA generator for Elmer.
Testing the run out with the armature fitted.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00080.jpgA generator for Elmer.
Armature with extension fitted.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00081.jpgA generator for Elmer.
Next up a fake bush end was turned from brass.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00082.jpgA generator for Elmer.
Fitted to the front bearing.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00083.jpgA generator for Elmer.
Made a form tool from a piece of mild steel to turn a small flat belt pulley.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00084.jpgA generator for Elmer.
Turned the pulley.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00085.jpgA generator for Elmer.
Faced the end after parting off.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00086.jpgA generator for Elmer.
Mounted the pulley in the mill vice with a few pieces of paper to electrically insulate it so I could use a multi meter and a piece of 3mm rod to locate the centre of the small hub.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00087.jpgA generator for Elmer.
A hole was drilled and taped for a grub screw.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00088.jpgA generator for Elmer.
The armature assembly.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00089.jpgA generator for Elmer.
The bearing posts were mounted on the lathe and the boss sections rounded over with a round over end mill.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00090.jpgA generator for Elmer.
The finished posts.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00091.jpgA generator for Elmer.
The generator was assembled.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00092.jpgA generator for Elmer.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00093.jpgA generator for Elmer.
My idea to use some small magnets to generate enough current to start excitation was not successful so for the moment it needs around 2.5A excitation current from an external source.  I have ordered some different magnets to experiment with and maybe have the field windings only as fakes.
Next up is a large pulley for the engine.  Does anyone know of a source for flat belts, have searched the web but could not find a supplier that would deliver to Spain?  Need one 700mm long 12mm wide.
Cheers.
Abraham
Offline Kjelle
« Reply #29 on: February 01, 2016, 12:20:34 AM »
WoW!!!
Check sewing machine spares, or automotive spares for the belt... The dimensions look like a poly-v should fit... Yuo don't need the grooves for it to work.
Kjelle
Offline modeldozer
  • Valencia, Spain
« Reply #30 on: February 07, 2016, 09:14:14 AM »
Kjelle,   thank you for the info, will look into it.
For the large pulley that goes on the engine I went for a fabricated design.  Got a lump of steel from a local engineering firm, seems to be part of a large taper lock bush.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00094.jpgA generator for Elmer.
After dialing it in on the 4 jaw, it was hack sawed to size.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00095.jpgA generator for Elmer.
It was faced close to size and the inside bored to size, leaving a shoulder to locate the spoke part for soldering.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00096.jpgA generator for Elmer.
Flipped around add gripped on the inside, it was carefully dialed in.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00097.jpgA generator for Elmer.
The outside and other face were then machined, leaving it a little over size for cleanup after soldering.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00098.jpgA generator for Elmer.
A piece of 3mm plate was centered in the 4 jaw to a centre punch mark.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00099.jpgA generator for Elmer.
A hole was drilled and bored to fit on the hub.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00100.jpgA generator for Elmer.
One side of the hub was turned with a register to locate in the plate.  It was temporarily drilled and tappet.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00101.jpgA generator for Elmer.
After cutting down the corners of the plate it was mounted on the hub.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00102.jpgA generator for Elmer.
The plate was turned down to a nice snug fit inside the rim.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00103.jpgA generator for Elmer.
The hub was then bored out for the shaft, parted off, turned around and the end faced. A second hub was also made.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00104.jpgA generator for Elmer.
The parts so far.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00105.jpgA generator for Elmer.
One of the hubs and the plate was mounted on the rotary table and centered under the spindle.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00106.jpgA generator for Elmer.
The cutouts to form the spokes were chain drilled.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00107.jpgA generator for Elmer.
After removing the cut out material all the sides were milled to size.  Done very slowly as the outer ends were unsupported.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00108.jpgA generator for Elmer.
All the parts.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00109.jpgA generator for Elmer.
All the bits were brazed together.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00110.jpgA generator for Elmer.
The pulley was mounted on a mandrel and all the surfaces turned to final size.  The shoulder left to locate the spokes was also removed.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00111.jpgA generator for Elmer.
Fitted on the engine.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00112.jpgA generator for Elmer.
Made a temporary drive belt from insulating tape to test the combination.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00113.jpgA generator for Elmer.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00114.jpgA generator for Elmer.
Next will be a base to mount it all.
Cheers.
Abraham
« Reply #31 on: February 07, 2016, 10:04:32 AM »
 This is looking better every time I see it.
Well done, Abraham.
Offline modeldozer
  • Valencia, Spain
« Reply #32 on: February 07, 2016, 03:57:54 PM »
Hi Dave,  thank you for the kind words.
Cheers.
Abraham
Offline modeldozer
  • Valencia, Spain
« Reply #33 on: February 21, 2016, 09:13:41 AM »
Hi all,
Decided to extend the floor of the engine under the generator. A template was used to cut a piece of 6 mm plate.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00115.jpgA generator for Elmer.
This was milled square and to size.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00116.jpgA generator for Elmer.
Tile grooves were milled to match the engine floor.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00117.jpgA generator for Elmer.
Slots were milled to mount the generator and give some adjustment to tension the drive belt.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00118.jpgA generator for Elmer.
The part was flipped over and holes drilled and tapped around the outside for mounting to a base.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00119.jpgA generator for Elmer.
A base was cut from chipboard, milled to size and holes and slots drilled.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00120.jpgA generator for Elmer.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00121.jpgA generator for Elmer.
The engine and generator were fixed to the base.  A drive belt was made from some cloth harnessing tape.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00122.jpgA generator for Elmer.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00123.jpgA generator for Elmer.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00124.jpgA generator for Elmer.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/Generator/Image00125.jpgA generator for Elmer.
The base still needs finishing, still looking for some decent wood to do it.
A short video of it running.
Cheers.
Abraham
« Reply #34 on: February 21, 2016, 10:40:20 AM »
Abraham, looks good..... :bow:
Do we have electricity yet?  :zap:
Offline modeldozer
  • Valencia, Spain
« Reply #35 on: February 21, 2016, 01:52:14 PM »
Hi John,
     Tank you for the kind words.  If you look at the lower right hand of the video the light bulb is powered from the generator, I have to use an external dc source to excite the fields.
Cheers.
Abraham
« Reply #36 on: February 21, 2016, 03:51:24 PM »
Abraham,
looks very good indeed.
Couldn't you switch from external excitation to self excitation once the generator is running ?
Dave,
« Reply #37 on: February 21, 2016, 04:06:46 PM »
Abraham,
Dave,
I had thought of that, but given he is reading around 5v on the dvm, I dont think it will be enough.....
Given that the field coils are wound for 220v....less turns with thicker wire might work...
Abraham, how fast is the rotor turning? how much voltage are you applying to the field coils?
Offline modeldozer
  • Valencia, Spain
« Reply #38 on: February 22, 2016, 05:11:17 AM »
Hi Dave and John,
Like John said, it does not generate enough power to self excite, have even tried adding some small magnets.  My only other thought is, if i can find suitable magnets, to replace the fields.  Experimented a bit with the voltage and current and in the video was using 5V at around 2A.  At 12V the current goes up to around 3.5A but the coils start to get hot. The field coils have a resistance of 2ohm.  The rotor was turning at 1800 RPM.
Any advice is greatly appreciated.
Cheers.
Abraham
« Reply #39 on: February 22, 2016, 07:29:36 AM »
I'm no guru, but it would appear that the dc resistance of the field is too low.
Ordinarily the current through the coils would be alternating due to the commutating action of the rotor commutator.....
Rewinding the rotor with thinner gauge wire and more turns would probably improve things whereby you could externally excite it.....conversely, rewinding the rotor with thicker wire and less turns will increase the output, Hmmmm that doesnt sound right that bit....
I 'd try the field first, keep the rotor as is run it at the same speed....
« Last Edit: February 22, 2016, 09:58:18 AM by John Rudd »
Offline modeldozer
  • Valencia, Spain
« Reply #40 on: February 22, 2016, 08:06:30 AM »
Hi John,
Thank you for the information, might have a go at rewinding the fields.
Cheers.
Abraham
« Reply #41 on: February 22, 2016, 10:01:25 AM »
Just a thought, howxhave you connected the field coils?
Originally, the coil ends would have been connected via the brushes and the other ends would have been your supply......so have you just joined the brush ends?
2 ohms seems low....., :scratch:
Offline modeldozer
  • Valencia, Spain
« Reply #42 on: February 22, 2016, 04:18:13 PM »
Both fiels and the armature were in series.  For the generator I have the fields in series and the armature separate.  The fields are wound with fairly thick wire and do not seem to have a lot of turns.
Abraham
« Reply #43 on: February 22, 2016, 04:54:13 PM »
Abraham
So you need more turns, if the formers are such that you cant accomodate, then reduce the wire gauge...field strength is down to ampere-turns...you may need to experiment a little to achieve a decent output voltage...
Offline modeldozer
  • Valencia, Spain
« Reply #44 on: February 22, 2016, 05:17:12 PM »
Thank's John, will try to wind a coil on a seperate former for testing, the way the formers are on the fields meens they have to be hand wound turn by turn.
Offline SteveT
« Reply #45 on: February 25, 2016, 12:21:02 PM »
Just followed the build and I am very impressed, well done
Steven Tyrer
lives in Cardiff South Wales
Offline modeldozer
  • Valencia, Spain
« Reply #46 on: February 25, 2016, 04:28:10 PM »
Hi Steve,
     Thank you for looking in and the kind words.
Abraham
