Author Topic: press fits for furniture  (Read 13161 times)
Offline jcs0001
« on: November 10, 2015, 10:30:04 AM »
Not a new technique but perhaps new for furniture.
http://www.treehugger.com/eco-friendly-furniture/freeze-frozen-metal-furniture-not-welded-paul-cocksedge.html
It does result in a very unique piece.
John.
Offline JD
  • Gosport Hampshire UK
Re: press fits for furniture
« Reply #1 on: November 11, 2015, 04:37:28 PM »
John, Industry has been using this form of shrink fit for years.
In the past while replacing the starter ring gear on a flywheel (before I obtained a gas torch)I placed the put fly wheel in a freezer for about 24 hours then leaving the ring gear in boiling hot water prior to the fit the two came together nicely.
JD
« Reply #2 on: November 11, 2015, 04:54:51 PM »
Well of course cart wheels had their rims shrunk on hundreds of years ago. The wooden wheel rim would be water soaked, and the forged and hammer welded rim would be heated red hot in a circular pit fire. Rim was then pulled out, popped on the wheel, hammered into place and buckets of water tossed on to stop the wheel burning. Turn of the 19th / 20th  century there were even special rim heating gas burners running off towns gas available to blacksmiths and wheelwrights.
Nowt new in engineering  :lol:
