Author Topic: Angle drilling a hole in brass  (Read 11174 times)
Offline Edgwick one
  • Love old machinery and getting my hands dirty
« on: October 20, 2015, 01:23:09 AM »
How does one drill a hole on a angle in a piece stock ( Brass ) using drill press or milling machine
Offline NeoTech
    • Roughedge Hobbyworks
Re: Angle drilling a hole in brass
« Reply #1 on: October 20, 2015, 03:42:45 AM »
One uses a sineplate that you cn clamp stuff to..
like those double angle ones with a lot of holes ontop of. =)
Offline NeoTech
« Reply #2 on: October 20, 2015, 03:43:47 AM »
Offline NeoTech
« Reply #3 on: October 20, 2015, 03:45:21 AM »
This is something that could work as well if you dont need complex angles.
« Reply #4 on: October 20, 2015, 04:56:11 AM »
Bigest problem is having the drill skid of off the angles face.
Use an end mill first to get a flat spot for the drill.
« Reply #5 on: October 20, 2015, 04:35:40 PM »
Deja-vu, anyone?
http://madmodder.net/index.php/topic,11043.msg128265/topicseen.html#new
As I mentioned in the thread above, the method you chose is highly dependent on the level of accuracy you need.  The fact that it's brass is inconsequential.  Have a look at the thread linked above and if that doesn't give you enough ideas then post a lot more detail on what you're trying to accomplish.
Offline NeoTech
« Reply #6 on: October 22, 2015, 02:51:57 AM »
haha apparently, i havent read that thread yet.
I usually never drill a angled hole at all, i just put a 2 flute or single flut mill in my drill press instead.. and run it down until i got a proper flat surface to start my drill at.
But i only been doing propane burners, those swirly bits in the burner head.
