Author Topic: Roller for bending flat bar  (Read 7823 times)
Offline Chuck in E. TN
  • USAF Retired
« on: October 07, 2015, 02:17:07 PM »
 Somewhere I recall seeing a write up on making a flywheel rim or maybe a traction engine wheel from flat stock by rolling it into a circle. Can anyone point me to such a build? What is that type of roller called?  Any plans for such floating around?
 [font=]Chuck[/font]
Chuck in E. TN
Offline Lew_Merrick_PE
Re: Roller for bending flat bar
« Reply #1 on: October 07, 2015, 04:11:08 PM »
The tool you are looking for is called (depending on your area) either a Slip Form Roll or a 3-Roller Slip Form.  The initial step is to form a spiral slightly smaller in diameter than you intend to end up with, trim it to the appropriate length, and weld the ends together.  The welded area will need to be ground or filed smooth.  [Sometimes you can make minor corrections by loading the result into the Slip Form Roll and re-forming it slightly.]
Many decades ago, such work for flywheels was common in the shop in which I served my apprenticeship.  [I only did it a few times.]
« Reply #2 on: October 08, 2015, 03:37:26 AM »
I think I saw somewhere someone using a modified bead roller to make that kind of rim for model engine.
Offline JD
  • Gosport Hampshire UK
« Reply #3 on: October 08, 2015, 03:00:54 PM »
Have a look at Youtube and search for "Myfordboy" in amongst his many videos he shows how he constructs his flat bar bender, another clip shows him using said machine I believe for forming tyres for a pair of fly wheels later to be lead filled.
JD
If you cant fix it hit it with a bigger hammer
  • USAF Retired
« Reply #4 on: October 08, 2015, 03:04:22 PM »
Thanks for all the replies, folks.
Chuck
Chuck in E. TN
