Author Topic: Another bender - believe it or not  (Read 33278 times)
Offline jcs0001
« on: October 05, 2015, 07:59:38 PM »
While perusing my bundle of shopnotes magazine (I'm not affiliated with them at all) I noticed a non hydraulic bender for bending heavier steel rod and flat bar - compared to the bender that I posted here recently.
A couple of months ago a friend, cleaning out his shop, gave me a hydraulic press frame along with a 12 ton hydraulic jack.  At the time I asked if anyone had any ideas of jigs or tools I could make to make it more useful.
Another feature of my shop is that I have the tools and can silver solder small items.  However I do not weld and thus must find other means to make things.
The shop notes design used a 5/8 in. threaded rod on each side of the die and form along with a long nut on each to create the pressure to bend steel items.  Since I have the press I decided to modify the plans to use my press.
The design is quite simple - it involves a solid block of hardwood top and bottom along with cutouts to accept a piece of 2 x 2 in. (3/16 in. thick) angle iron.  Thus the top angle with the point facing down is pushed into the bottom angle with the point also facing down.  The wood merley supports the angle.
I started with a large chunk of 2 in. purple heart.
http://i1192.photobucket.com/albums/aa327/jcs0001/IMG_0606.jpgAnother bender - believe it or not
It was cut to oversize and laminated as it wasn't thick enough.
First mistake was leaving the lower block in the sun with a bunch of clamps but not leaving it long enough.  As I was doing the final cutting to shape it began to delaminate.  The glue inside the joint was still relatively soft so I was able to add more glue and poke it well into the joint with a thin blade.  It was then clamped (again) and left overnight.
Two blocks glued up:
http://i1192.photobucket.com/albums/aa327/jcs0001/IMG_0607.jpgAnother bender - believe it or not
http://i1192.photobucket.com/albums/aa327/jcs0001/IMG_0608.jpgAnother bender - believe it or not
Second mistake - using purple heart.  I had forgotten how brittle it can be in a jointer.  The two blocks have some chipped out areas where the jointer did not cut smoothly.  I used a very small depth of cut and moved the wood slowly but it still chipped out.
Third mistake - I drilled the two 5/8 holes in each end of the upper block, then clamped it to the lower block and used the existing holes to guide the drill (in the drill press) to drill the holes in the bottom block.  Somehow or other the holes didn't match up necessitating drilling 3/4 in. holes in the upper block.
On a brighter note the local metal shop had angle iron in the size I needed.  I'm disappointed in the final appearance of the jig however it should not effect the ability to bend metal so in that respect it is a success.  It will be interesting to see how it holds up to the hydraulic press.
I did some metal work this afternoon and turned down a round of steel to fit into the short pipe I had made for the press some time ago.  This will be mounted to the top of the top block along with a piece of steel plate to better distribute force when pressing.
Top piece finished and drying in the sun:
http://i1192.photobucket.com/albums/aa327/jcs0001/IMG_0609.jpgAnother bender - believe it or not
I'll add a few photos of the finished product in use - likely tomorrow as I want the finish to dry overnight.
John.
Offline jcs0001
Re: Another bender - believe it or not
« Reply #1 on: October 05, 2015, 09:05:40 PM »
And a photo of the finished product.  Will add more photos of it in the press tomorrow:
http://i1192.photobucket.com/albums/aa327/jcs0001/IMG_0610.jpgAnother bender - believe it or not
John.
« Reply #2 on: October 05, 2015, 10:28:08 PM »
The key to presenting something you aren't completely satisfied with is in the photography... :-)
Looks great to me. That purple heart is a stunning colour!
Offline jcs0001
« Reply #3 on: October 06, 2015, 03:35:46 PM »
Sparky - I had considered taking a photo at about 100 m - figured that would hide the warts :D   However maybe someone else can learn from my mistakes and hopefully I have.
I bent some metal this morning.  The 1/8 x 3/4 in. bends very easily as expected and creating an accurate 90 degree bend is dead easy.  I had some trashed 3/4 x 1/4 in. material - it has concrete residue on both sides and cutting it with a hacksaw revealed that it is quite hard.  I was able to make a couple of 90 deg. bends in it but tried another piece and broke it twice.  Putting a bit of grease on both surfaces helped as it didn't break again.
The bender set up in the press.  I need to fine tune things but it worked for now:
http://i1192.photobucket.com/albums/aa327/jcs0001/IMG_0612.jpgAnother bender - believe it or not
A couple of items - 1/4 x 3/4 flatbar (on the left) and 1/8 x 3/4 flat bar.  The right hand piece first had the two right angle bends made in the press and then I used my other bender (see recent posting) to bend the curve.  It's just an experiment so I'm not sure of a use for it - maybe to hang up my wife's halloween broom :)  You will notice that the curved piece has an uneven curve - I first used a 4 in. form and then switched to 3 in. - thus it's a bit out.
http://i1192.photobucket.com/albums/aa327/jcs0001/IMG_0613.jpgAnother bender - believe it or not
John.
