Author Topic: Painting or powdercoating a gear  (Read 7240 times)
« on: September 25, 2015, 11:08:00 PM »
I am working on this quick project (waaaaay over due). it involves a gear that I either want to paint or powder coat. problem is, this gear has had a hard life in an engine in it's previous life. I believe it was a cam gear. Needless to say, it has been bathed in oil at high temps. I am not sure paint will stick. I saw a blog post where a guy powder coated a set of used brakes... after cleaning them, he heat soaked them in an oven for awhile.
Does this actually work? Recommendations on how I can give this ear some color?
Re: Painting or powdercoating a gear
« Reply #1 on: September 26, 2015, 03:52:21 AM »
Iff you get it hot enugh for the oil to burn it is no longer oil , and will clean off without chemicals .
« Reply #2 on: September 26, 2015, 04:01:48 AM »
If it is cast iron the oil will have penetrated deeply and will be a problem, however if it is steel, just a good clean with carb cleaner should do it.
