Author Topic: Making a sand mold without a pattern  (Read 28025 times)
Offline ironman
« on: September 08, 2015, 08:49:42 PM »
Here is a video showing how I made the mold when ductile iron was melted.
Re: Making a sand mold without a pattern
« Reply #1 on: September 08, 2015, 09:31:12 PM »
Now there's a method of casting I hadn't seen before! Excellent, and informative.
Ironman are you still using cement and sand mix for your core sand, or is it something else?
Offline ironman
« Reply #2 on: September 08, 2015, 09:55:31 PM »
No I found that cement sand cores are hard to dig out in tight pockets so I use more expensive binders (Fiberglass resin) I still think that cement sand is the cheapest core sand around.
« Reply #3 on: September 08, 2015, 11:01:14 PM »
Oh, fiberglass resin.....is it the common fiberglass polyester laminating resin, and hardener, or is it a special core sand resin made for the purpose?
The cores look very sharp and strong.
Offline mexican jon
« Reply #4 on: September 09, 2015, 01:26:18 AM »
Thanks for that  :thumbup: very interesting watch  :clap:
« Reply #5 on: September 09, 2015, 02:49:29 AM »
Thank you for a very interesting informative demonstration!
Offline ironman
« Reply #6 on: September 09, 2015, 03:03:49 AM »
The shop where got it from sells all kinds of resins for molding and fiber glassing, not foundry molds. When I told him I was going to use it for foundry cores he said I was crazy, he does not know me very well.
« Reply #7 on: September 09, 2015, 10:04:17 AM »
Very nice thanks for showing! I always look forward to your video's!
« Reply #8 on: September 09, 2015, 11:00:28 AM »
 :lol:
It's a poor synonym for innovative indeed!
Offline joshagrady
« Reply #9 on: September 09, 2015, 12:27:31 PM »
Nice looking casting.
I assume that the advantage to using cores rather than a pattern is to avoid draft angles?  Or is it just faster?
Thanks for posting.
« Reply #10 on: September 09, 2015, 08:51:31 PM »
In this case it's the multi piece core-box that avoids the need for draft. Casting in a core doesn't necessarily avoid draft. This whole molding session taken together for the particular purpose is very cool.  :clap:
« Reply #11 on: September 10, 2015, 06:48:40 AM »
Thanks for posting.
Not only does it avoid draft, but the core boxes are much easier to make than a patern!
Regards, Matthew.
