Author Topic: My 1930 Edgwick mark one lathe  (Read 9368 times)
Offline Edgwick one
  • Love old machinery and getting my hands dirty
« on: July 14, 2015, 01:12:19 AM »
Here she is the 1930 Edgwick serial number D26
Re: My 1930 Edgwick mark one lathe
« Reply #1 on: July 14, 2015, 08:20:52 AM »
David ,
your speed change is different to mine and it has a different brass plate!
http://i917.photobucket.com/albums/ad16/mattinker/Mobile%20Uploads/P1030718_zps97raix9q.jpgMy 1930 Edgwick mark one lathe
Your thread dial is as ilegible as mine!
« Reply #2 on: July 14, 2015, 09:21:44 AM »
Early Edgwicks had the clutch lever top-LHS of the headstock (you can see the end of the shaft on your headstock); on later ones they moved it to the bottom RHS (a much more sensible location) using levers & bosses on the back of the lathe.
I believe the gear selectors are actually the same inside; just with a different style boss.
Offline Edgwick one
« Reply #3 on: July 18, 2015, 05:27:51 AM »
Sorry about the picture quality I will try to get some better pictures and bigger to
Offline Edgwick one
« Reply #4 on: July 18, 2015, 05:37:27 AM »
Oil for headstock gearbox someone has suggested using Shell Tellus which is Hydraulic oil.     I would of thought there was a proper oil perhaps a diff oil or gearbox oil would be better
