Author Topic: The Eddgwick arrived!  (Read 77282 times)
« on: June 12, 2015, 01:28:32 PM »
It arrived yesterday, intact! I was more than a little anxious. Shipping by road a machine that isn't crated is bad enough, but without being there to see it loaded, is worse. The driver showed up yesterday without warning, I'd asked that he telephone me half an hour before arriving. So a bit caught short, I jump started the neighbours fork lift that hasn't been used in two years. Off I went, I hadn't brought the strop that I'd planned to use if there was a problem with the pallet. Transit had not been kind to the pallet, it looked doubtful and was! I had to get the lathe unloaded quickly as buses were having problems getting by. I got it out and onto the ground. I then spent some time getting the forks out from under the disintegrated pallet without it falling over, a couple of hours later, hanging from a strop it was in my workshop. Exhausted, I left it until today to have a look at it. There were quite a few things with it that I didn't expect.
http://i917.photobucket.com/albums/ad16/mattinker/P1030602_zpso8mwfo5l.jpgThe Eddgwick arrived!
Mostly Imperial reamers.
http://i917.photobucket.com/albums/ad16/mattinker/P1030603_zpsegcxboy1.jpgThe Eddgwick arrived!
A usable selection of high-speed steel and carbide tooling.
http://i917.photobucket.com/albums/ad16/mattinker/P1030604_zpstulfdgsa.jpgThe Eddgwick arrived!
The milling cutters and slitting saws should come in handy.
http://i917.photobucket.com/albums/ad16/mattinker/P1030605_zpsctxfatuu.jpgThe Eddgwick arrived!
The fixed steady is original and fits.
http://i917.photobucket.com/albums/ad16/mattinker/P1030606_zps3lmnz5mf.jpgThe Eddgwick arrived!
The four jaw and the face plate were a surprise, they are both screw fitting and don't fit the bolt up chuck mount!
http://i917.photobucket.com/albums/ad16/mattinker/P1030607_zpsti2azxwk.jpgThe Eddgwick arrived!
I thought of John Mills carefully oiling chuck mounting threads when I saw this!
The previous owner said he'd had the lathe for twelve years, he'd obviously never use anything but the three jaw chuck!
I put a plug on it today and ran it, everything worked. Didn't make any chips, but that'll be soon!
Adev, if you found out anything more on the specifications for the oil I'd love to hear from you.
More later, regards, Matthew
Re: The Eddgwick arrived!
« Reply #1 on: June 12, 2015, 01:33:21 PM »
Matthew that's excellent that it's arrived safely - I now look forwards to the ongoing story of it rising Phoenix like from it's neglected state. :thumbup:
« Reply #2 on: June 12, 2015, 01:51:36 PM »
 :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :beer:
« Reply #3 on: June 12, 2015, 02:06:13 PM »
Great ending to the story....
I hope you and your new machine have a happy relationship :clap:
« Reply #4 on: June 12, 2015, 02:21:54 PM »
Good news Matt. and a cracking lathe to boot! Hope you are feeling better!
« Reply #5 on: June 12, 2015, 03:49:24 PM »
Thanks Guys, I'm still wiped-out!
I just went a little mad and ordered my compromise DRO, it's not as expensive as a full blown DRO, but as I work in metric a lot this suits me.
http://www.ebay.com/itm/Igaging-3-Piece-set-6-12-36-Digital-Readout-Read-Out-DRO-w-Remote-display-/131049270885?
It's not the cheapest one on the market, but it's the cheapest I've found that will ship to France! I have an idea for making up for the 7" inches in length for the very rare occasion when I might need more than 35".
Regards, mùatthew
« Reply #6 on: June 12, 2015, 04:14:57 PM »
Arc Eurotrade sell the very same scales,.....,
Should have said, you were buying......could have bought them here and sent out to you.... :doh:
« Reply #7 on: June 12, 2015, 04:28:22 PM »
It would have been better, I could have got the longer scales, but the three scales come out at about the same price when calculating the exchange rate and shipping! Never mind, it's too late now!
« Reply #8 on: June 12, 2015, 04:30:57 PM »
Matt,
Pm sent .....
« Reply #9 on: June 13, 2015, 03:06:11 AM »
Those scales turn into ramdom number generators iff they get coolant inside , I must make a cover for mine .
« Reply #10 on: June 13, 2015, 03:17:12 AM »
Nice one Matthew  :clap: :thumbup:
It's good to see the lathe fined a new home  and given a new lease of life :dremel:
« Reply #11 on: June 13, 2015, 05:23:29 AM »
Hi there, Matthew,
Have I missed the first part of this story?   :scratch:   :scratch:   :scratch:
Online RussellT
« Reply #12 on: June 13, 2015, 05:37:42 AM »
The lathe looks OK - a bit better in your photos than the original listing.  I'm curious to know - what's the verdict on the cross slide hand wheel?
Is it safe to assume that transport cost more than the lathe?
« Reply #13 on: June 13, 2015, 07:43:50 AM »
Hi there, Matthew,
Yep! It started out as:-
http://madmodder.net/index.php/topic,10710.msg124393.html#msg124393
« Reply #14 on: June 13, 2015, 07:53:53 AM »
Thanks for the heads up, I suspected as much, I've had that experience with calipers! They're a compromise!
Regards, Matthew.
« Reply #15 on: June 13, 2015, 07:55:23 AM »
Thanks Rob!!
« Reply #16 on: June 13, 2015, 08:06:22 AM »
The verdict isn't completely out on the cross-slide. I haven't dismantled it yet, but as far as I can see, it needs a touch of straightening and either welding a stub on the end or building up with weld and machining. The hand-wheel is in good shape and the broken stub has already been removed.
You safely assumed right! I got a good deal on the Transport, but it was still more expensive than the lathe at €348 including VAT the lathe was €212 at the current exchange rate. I'm pleased, that's less than a similar lathe here without transport!
Regards, Matthew.
« Reply #17 on: June 13, 2015, 08:14:14 AM »
Some thoughts,
As the lathe has no reverse, it would be extremely difficult to cut metric threads as is. I have everything I need to set up a reversing switch, so it's a question of time.
The suds pump is missing so it looks like it's going to be an indoor fountain pump!
The bed wear is quite high, I haven't measured it yet, but I'm having thoughts about making a grinding jig to regrind them.
Any thoughts would be welcome! Regards, Matthew
« Reply #18 on: June 14, 2015, 05:07:19 AM »
Hi Matt,
Great to see the old girl made it! Looking forward to seeing some chips made...
Making a screw adapter to take the backplate shouldn't be too taxing? If you can cut a piece of steel to fit the bolt-up flange, then simply machine a nose with some threads on it, and you're good to go. I was lucky, I got a proper Edgwick backplate that bolts straight on. I've only used it once, though, now I've got a 3-jaw that fits & is reasonably accurate, I mostly use that.
Regarding metric screwcutting - the gearbox will handle that, and the screw cutting dial that should be fitted will work properly, so you don't need a reverse. Just disconnect the half nut, run back to the start, and use the dial to re-engage. Or just use dies like I do  :beer:
Oil - Any decent hydraulic oil should do. I use this stuff: http://www.lubetechshop.co.uk/product_info.php?cPath=25_40&products_id=86 I use that on the ways & tailstock as well, although having more recently bought some proper slideway oil, I'll probably switch to that for the bed/tailstock.
« Reply #19 on: June 14, 2015, 08:32:47 AM »
Hi Matt,
Thanks AdeV,
As you say, making adapter plates shouldn't be to challenging! They are pretty certainly Whitworth, which the gearbox will handle fine!  I'm not sure that I agree about the dial to re-engage metric threads! A metric lead screw has a different type of thread dial, this is because they are not fractional, from what I can gather, three gears are required instead of one to make a metric thread dial work. As this is a 4TPI lead-screw, geared to produce metric threads, the ration may not be repeatable! There is a brass plate on the carriage, photo below, pretty badly damaged, the last two lines read,
 "For any "illegible odd?" Whitworth pitches and all metric threads, keep guide screw nut engaged and return saddle by reversing feed clutch."
http://i917.photobucket.com/albums/ad16/mattinker/Mobile%20Uploads/P1030615_zpskyhbdcs1.jpgThe Eddgwick arrived!
I hadn't deciphered the plate when I wrote about reversing. Do you have the plate? Is it legible? It would be nice to be able to know which marks on the thread dial correspond with what!
Thanks for the info about the oil, I'm new to this kind of gearbox.
« Reply #20 on: June 14, 2015, 09:43:54 AM »
You can use that method for all screwcutting which would make the dial redundant unless you want to start making multi-start threads.
« Reply #21 on: June 14, 2015, 10:11:02 AM »
Yes, I have that plate on mine - unfortunately, although complete, it's so badly bashed about that I can't read it. I'll get my camera with macro lens on it later, hopefully with a suitably big & clear picture I can make out the missing bits. My mobile phone camera just isn't good enough.
« Reply #22 on: June 14, 2015, 10:22:39 AM »
I've made out essentially invisible writing on unreadable tractor tags like that by shooting with a decent camera, and then cranking up the magnification, contrast and/or brightness values in a photo editor. You'd be amazed what it can show up.  :thumbup:
« Reply #23 on: June 14, 2015, 10:34:11 AM »
Well, I just did a little experiment - and you're dead right, the screw cutting dial does not work for metric threads...
I'll just stick with Whitworth... :)
IIRC, from watching an American lathe tutorial, even TPIs can start on any number or half number & will thread correctly. Odd numbers I think have to go on the whole number only. But, I could be wrong, it's been a long time since I watched that video.
lordedmond
« Reply #24 on: June 14, 2015, 11:01:46 AM »
This may be of help assuming your gearbox can produce the metric pitch
It shows that you can disengage the half nuts
Stuart
« Last Edit: June 14, 2015, 12:58:46 PM by dsquire »
