Author Topic: Clarkson Tool Cutter Grinder Restoratioon  (Read 46950 times)
Offline ArnieB
« on: April 20, 2015, 09:36:28 AM »
Hello,  some while ago (2013) I started to put my workshop together to start building a 4" scale model of a Burrell Traction Engine.  The Harrison L6 Mk3 lathe came first, followed by a rare round ram Bridgeport.  Next came a Clarkson Tool Cutter Grinder, which I found on ebay at Worcester in need of some TLC.  I kept a before and after photo album of most of the refurbishment and I thought it may be of interest.  Not quite sure of how to go about this as it will be my first topic on any forum but here goes.
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/ebay-300113-270pounds-worcester-1_zps2cmiens2.jpgClarkson Tool Cutter Grinder Restoratioon
Its not pretty is it.  By the way it is set up I think is was used to to one specific operation It came with the minimum of attachments but did have the collection of collets imp/metric. Not sure about the paint should be grey but painted in a Mk2 colour green I.split it down into three lumps cut the wiring off, and back to base.
« Last Edit: April 21, 2015, 05:57:12 AM by ArnieB »
Offline ArnieB
Re: Clarkson Tool Cutter Grinder Restoratioon
« Reply #1 on: April 20, 2015, 10:15:46 AM »
I stripped and removed all parts bolts, screws component parts,
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/084%202_zpsoiyjahow.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/083%202_zpsbsexr278.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/082%202_zpshnpsgnfz.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/080%202_zpsgj9n9oqh.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/077%202_zpsijye4erc.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/073%202_zpsmkbe41ue.jpgClarkson Tool Cutter Grinder Restoratioon
As I split the base plate it revealed its true colour, the original grey.
Now came the hard part I removed all the dirt and grease and set about preparing the painted arears .  I've recently bought a soda blasting kit for my new project I only wish I'd got it earlier and used it for the Clarkson, would have saved a lot of time..
A new single phase motor was ordered,  I got a drive belt from ebay, a Mk2 belt guard from Machine Spares together with the attachment bolts and a new motor pulley to fit the new motor.
« Last Edit: April 21, 2015, 07:23:38 AM by ArnieB »
« Reply #2 on: April 20, 2015, 11:25:07 AM »
Arnie,
Great find.
I'm looking forward to seeing in all it's rebuilt glory.
« Reply #3 on: April 20, 2015, 12:41:06 PM »
A good start to the thread Arnie  :thumbup:
Looking forward to more instalments  :)
Offline ArnieB
« Reply #4 on: April 20, 2015, 12:58:17 PM »
 Right mowing done next episode;
     I used the proverbial wire brush mounted in my 4 inch grinder for most of the work, then electric sander , then wet and dry.  You may notice the cheat on the mounting base, but it was grey anyway.  Use of presicion dowels to locate the switch mounting plate.  I used the original switch plate and surfaced its face in the Brigeport to mount the new DOL starter.
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/118%202_zpsssu0bc9k.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/116%202_zpsumt0qn5h.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/115%202_zpstluczaee.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/114%202_zpscmtarwlp.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/113%202_zpswxipdfb4.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/112%202_zpstllkrwt6.jpgClarkson Tool Cutter Grinder Restoratioon
« Last Edit: April 21, 2015, 07:34:53 AM by ArnieB »
Offline ArnieB
« Reply #5 on: April 20, 2015, 01:15:31 PM »
I used Stationary Paints machine enamel.  I had some Harrison Lathe paint in the garage and as the colour match is the same as the Clarkson it was sprayed on.  I used two layers of grey primer, which I know technically I didn't need, then two layers of top coat. It is a high build enamel and went on with no runs or areas to retouch, I was chuffed. The motor arrived a lovely blue so that was sprayed as well.
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/117%202_zpswapdjnbh.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/142%202_zps4euxhvq0.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/143_zpsydtme9uh.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/141%202_zpsmf4tcfl1.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/140%202_zpsgotloyfy.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/138%202_zps6ftgzejz.jpgClarkson Tool Cutter Grinder Restoratioon
« Last Edit: April 21, 2015, 07:44:02 AM by ArnieB »
Offline ArnieB
« Reply #6 on: April 20, 2015, 01:22:24 PM »
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/111%202_zpspoe1ndt1.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/136%202_zps3ulpgvru.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/135%202_zpsornemxoy.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/134%202_zpsrdzu9z7b.jpgClarkson Tool Cutter Grinder Restoratioon
« Last Edit: April 21, 2015, 07:51:20 AM by ArnieB »
« Reply #7 on: April 20, 2015, 01:23:33 PM »
Looks great!  :thumbup: :clap: :clap: :clap:
Offline ArnieB
« Reply #8 on: April 20, 2015, 02:46:05 PM »
Thanks vtsteam it was hard work but I was pleased with the result.  I started assembling the parts, first drilling and tapping the belt guard attachment point. It was plain sailing, the motor fitted well and I was able to get correct belt tension. I rewired putting the wires through the pedestal leaving an outlet free for lighting  I had replaced the spindle bearings and it ran as good as  new.  I put a dial on the bed and got almost no runout, can't remember what exactly it was.  I managed to buy a Clarkson radius tool, and an as new 3 way 4" vice that still needs a purpose mount to the Clarkson.
 http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/20150217_113724%202_zpsycmimsba.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/20150217_113742%202_zps94gilk02.jpgClarkson Tool Cutter Grinder Restoratioon
http://i76.photobucket.com/albums/j5/ArnieB/CLARKSON/20150217_113801%202_zpspceloh4q.jpgClarkson Tool Cutter Grinder Restoratioon
As you can see been doing a bit of polishing.  I need to find a good light for it probably LED . Next will be a spindle stone guard with vacuum point and then find a pair of centres, I can't afford the price Machine Spares want, so I'll keep looking. I also have a height guage to put on.
Hope my post has been of interest  Arnie. ( I'll be back )
« Last Edit: April 21, 2015, 07:57:44 AM by ArnieB »
Offline Zadig
« Reply #9 on: April 20, 2015, 03:53:45 PM »
Looks good Arnie, even better second time around. I don't know how much you've used it yet on grinding tooling but mine needs bellows for the cross-slide desperately. The amount of grinding dust that ends up under the slide and on the screw is obscene. It means you can't use oil on your ways which is a pain. If you come across any bellows on your search, please let me know. The ones at ARC are just a little too wide unless anyone know of a decent kink to make them more suitable.
Offline ArnieB
« Reply #10 on: April 20, 2015, 04:16:42 PM »
Zadig Ebay item number:271815600670 I don't know if the Mk2 fit the Mk1 but Machine Soares Ebay site has these at the moment, that is if you've got deep pockets  .  Check out the price of the extension spindle !!!!!!!
Arnie
Offline Sid_Vicious
« Reply #11 on: April 20, 2015, 04:21:09 PM »
That machine is a beauty... About the led light a lot of people are very pleased with the "Jansjø" light from Ikea. Also mentioned in some treads here and on John Doubleboost's videos about his old lathe.
« Last Edit: April 20, 2015, 05:29:06 PM by Sid_Vicious »
Offline howsitwork?
« Reply #12 on: April 20, 2015, 04:47:36 PM »
Not sure about the bellows but lights- look at 12v angel eyes lights or the stalk version http://www.ebay.co.uk/itm/141278104751?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT.
These have a good write up ( waiting for  mine currently) and with a 12 power supply are "safe" if anything hits them
Keep up the project!
Offline Zadig
« Reply #13 on: April 21, 2015, 12:55:44 AM »
Thanks for the link Arnie, I've seen that listing before but I must have missed the bellows somehow. They are a bit pricey mind, but for some reason bellows tend to be from most places with the exception of ARC and the ones they sell. I don't know if I can stomach £150, but the machine is nigh on useless without them.
« Reply #14 on: April 21, 2015, 04:02:56 AM »
Hi there, Arnie,
I'm not seeing a lot of your photos - is it just me or does anyone else have the same problem?
Offline Zadig
« Reply #15 on: April 21, 2015, 04:33:45 AM »
Pete, Arnie is having problems with Photobucket. He's trying to get his head around it at the moment.
« Reply #16 on: April 21, 2015, 04:52:52 AM »
There's no pleasing some folk  :). I quite like the photos of the cute little kitten .....OZ.
Offline ArnieB
« Reply #17 on: April 21, 2015, 08:01:56 AM »
Sorry folks operator error I did say at the start this was my first post.
Thanks for your patience.
Arnie.
« Last Edit: April 21, 2015, 09:44:49 AM by ArnieB »
« Reply #18 on: April 21, 2015, 02:37:23 PM »
Thank you Zadig.   :thumbup:   :thumbup:   :thumbup:
Arnie, whatever you did, it worked!  I can see all your photos now.  The only problem now is   :drool:   :drool:   :drool:   :drool:   :drool:   :drool:
« Reply #19 on: April 21, 2015, 04:20:53 PM »
That certainly is a first class renovation;  well done.
Offline Fergus OMore
« Reply #20 on: April 21, 2015, 04:35:47 PM »
Agreed but why use it as buffing lathe? As far as I am aware, this was never part of the design.  My experience with a Mark 1 suggests that the design  minimises the grit problem- in normal use.
Regards
Norman
Offline Zadig
« Reply #21 on: April 21, 2015, 05:26:13 PM »
... My experience with a Mark 1 suggests that the design  minimises the grit problem- in normal use.
Regards
Norman
Kindly explain.
« Reply #22 on: April 21, 2015, 05:56:34 PM »
Hi Arnie, Welcome to the forum.
        You have done a cracking job of the Clarkson  :thumbup: :drool: :drool:, I have a MK 2 awaiting the same treatment, mine will also need the bellows too. I still need various attachments too but not often you see them go cheap these days  :palm:
  Cheers Mick
« Reply #23 on: April 21, 2015, 06:14:44 PM »
This is a project that interests me as I too have a MK1 Clarkson that I've made some tooling for!
« Reply #24 on: April 22, 2015, 01:57:00 AM »
 :clap: :clap: :clap: :clap: Cracking job  Arnie  :thumbup:
It looks like it makes a canny buffing machine  :palm:
And here be my sorry looking machine   :)
http://i1066.photobucket.com/albums/u410/RobWilson100/Clarkson%20TCG/P1060880_zps4quykgc0.jpgClarkson Tool Cutter Grinder Restoratioon
http://i1066.photobucket.com/albums/u410/RobWilson100/Clarkson%20TCG/P1060881_zps7kwo6ahj.jpgClarkson Tool Cutter Grinder Restoratioon
