Author Topic: making threads ?  (Read 6026 times)
Offline polecat
making threads ?
« on: April 17, 2015, 07:34:09 AM »
as a side issue to an earlier thread is there a book / chart that i can look at that tells you the sizes you have to machine to put a thread on or into pipes particulary into pipes/ tubes
new to this not engineering trained i'm only an engraver by trade so this is new i have used taps n dies but that is cheating
thanks polecat
Re: making threads ?
« Reply #1 on: April 17, 2015, 11:30:36 AM »
If you download the Exel file from here you can sort the columns.
External threads are just about nominal size or thereabouts, internal depends on the pitch, thread angle, and % of thread depth to derive the appropriate tapping drill / bore.
There are loads of   books / charts to download, you just need to search for the species of thread.
Edit   .... I'll try putting the link in  .... pillock  :bang:
http://www.watchman.dsl.pipex.com/thread.html
Offline polecat
« Reply #2 on: April 17, 2015, 02:09:52 PM »
thank you for that bluechip
polecat
