Author Topic: Electronic Leadscrew for the New Lathe  (Read 365389 times)
Re: Electronic Leadscrew for the New Lathe
« Reply #150 on: December 30, 2020, 02:30:12 AM »
Are you incorporating backlash compensation Steve?
« Reply #151 on: December 30, 2020, 10:15:50 AM »
I've thought about backlash as a topic,Andrew, but concluded in this hybrid system (an electronic leadscrew) vs full CNC automation, it is not a concern. The reason is the same as it is with a dial on a screw handle. I will manually be backing to a start position that is past the point that backlash will be taken up when the stepper starts to drive the leadscrew in the cut direction again.
Similarly in an ordinary screw cutting change gear lathe, there will be backlash in gears, leadscrew and halfnut, and even the threading dial drive. But because you start the cut in a position prior to contact, backlash is taken up by the time the cut begins.
I've taken an incremental rather than an absolute positional approach to the software, so far at least. When you are dealing with positional coordinate system, backlash becomes important. Conventional CNC is positional.
« Reply #152 on: December 30, 2020, 10:39:09 AM »
My CNC mill, wire eroder and lathe have pitch error correction tables that map the ball screws along their length. I can't believe there's much error, certainly not enough to bother with for my sorts of projects.
My first CNC conversion (literally more than two decades ago !) to a Taiwanese Mill /Drill was practically unusable for profiling until I embodied backlash compensation. My first motivation to CNC it was the pain of filing out the D shaped 25 way connector mounting holes for various projects ! Programmed in assembler  :thumbup:
« Reply #153 on: December 30, 2020, 10:58:59 AM »
Andrew, cool!  :beer:
I was just thinkin, people must be getting tired here of just talk and no pics, but so far it's kind of uninspiring to look at. Nevertheless, somethin is usually better'n  nothin so ........here's my current mess:
Clockwise from upper left, encoder, stepper motor, step driver, power supply, breadboard, Arduino.
« Reply #154 on: December 30, 2020, 03:55:48 PM »
Setting up an array for the various likely pitches so I can choose them with switches. Since there are 6 switches, that gives me 64 possible pitches.
I've been looking at what the common ones are, to populate the array and have come up with:
Inch: 80 72 64 56 48 40 36 32 28 27 24 20 18 16 14 13 12 11 11.5 10 9 8 7 6 5 4 tpi
Metric: .3 .4 .45 .5 .6 .7 .8 1.0 1.25 1.5 1.75 2.0 2.5 3.0 3.5 4.0
Feed Speeds (tpi equiv): 100 150 200
This is 45 total entries, so will fit in the array size available, with room for additions.
I should say that the Metric pitches and the 11.5 Inch pitch are for future work, as everything else will program now with integer math throughout. I have a good idea how to do the others also with integer math, using something like the DDA algorithm but it's more involved.
Integer math keeps the speed of processing up in FORTH and on the Arduino.
« Last Edit: December 31, 2020, 02:26:28 PM by vtsteam »
« Reply #155 on: January 01, 2021, 04:32:08 PM »
I connected an 8 pin DIP switch to the Arduino. The switches now correctly select any of the programmed inch pitches above, and the encoder turns the stepper motor at the selected pitch ratio. Encoder direction is mirrored by the stepper. It's basically ready to test on the lathe.
« Reply #156 on: February 15, 2026, 04:43:39 PM »
Well this has been a very, very, very long time coming, but I just cut my first thread on the homemade lathe with this ELS project!  :ddb: :ddb: :ddb: :ddb: :ddb: :ddb:
It's a 3/8 -16" thread, cut using an ordinary 60 degree insert, not a true thread cutting type, but workable for a test. During the last week and a half or so, I've been working full time on the project to first reverse engineer what I'd done already, and second work out many mechanical problems and bugs I hadn't realized were still there. There was a LOT more to do than I'd thought four years ago when I last looked at it. But this time around I was determined to finish it. I finally got everything de-bugged and working well enough to get out into the still very cold tiny shop, and actually hook it up to the lathe for a real world test.
It cut with flying colors! I'm so happy to have finally finished this. And in some sense, the lathe, since it was always intended to have this capability. Left to do is mounting it to the lathe permanently instead of spread out piecemeal on the bench, and making up a new brass plaque thread table. The older one I had made is now incorrect because of software changes.
Looking forward to completing and using the ELS now on my lathe!
« Reply #157 on: February 15, 2026, 07:16:43 PM »
Offline Country Bubba
  • LaGrange, GA USA
« Reply #158 on: February 16, 2026, 06:37:31 AM »
Fantastic, always love it when a project is a success! :mmr:
Art
Country Bubba
« Reply #159 on: February 16, 2026, 10:54:24 AM »
Hi Tom and Country Bubba, thank! Much appreciated!  :wave:  :beer: :beer:
Now I want to make it look good, the way I pictured it. Starting on that today. Might just re-paint the lathe, too, if it's warm enough. Pre-Spring spruce up.  :dremel:
« Reply #160 on: February 17, 2026, 03:12:40 PM »
Here's a pic of the guts of my electronic lead screw -- more appropriately it should be called an electronic change gear -- since that was the original intention. The original design used an Arduino Uno R3, but now Arduino Nanos are easily available and a fraction of the size. I didn't want the Uno's onboard connectors for this project, and soldering directly to the Nano board was preferable in every way to pinned wiring.
The little control computer now is practically lost inside the "gearbox" I'd made -- originally I'd planned to put the stepper driver in there as well. But it would be a mess with all of the present switches, control board, and wiring together. Also not great for avoidance of interference. The control board only needs three wires to the driver, so for all those reasons I decided to box the driver up separately with the 24v motor power supply. Seems a more logical packaging anyway.
I'll be neatening and fastening the Nano and wiring down shortly, but have left it loose for the time being to make it easier to connect my laptop to its mini USB port via cable with my ham hands. I need to do that if I alter the program -- and I can think of a few changes I'd still like to make. Pencil indicates the scale of the present control computer... and its rat's nest.  :zap:
« Reply #161 on: February 22, 2026, 08:13:24 PM »
Discovered a little problem today with the Arduino Nano. One of the switches that set the thread pitch wasn't actually working. The six switches I have are labeled A through F. The F switch was the problematic one. I hadn't noticed this earlier since it is mainly used for the last threads in my lookup table -- the coarsest metric threads, and I hadn't tested those yet.
The way things are supposed to work -- pushing any switch to "on" basically grounds it's connected pin in the Arduino. Specifically, my switch F grounds pin D13 on the little computer. But my program wasn't seeing that happening when I flipped the switch.
After doing some electrical testing and not finding anything wrong with the wiring, or the switch, I searched the web for "Pin D13", and sure enough, there were several user issues about a Nano's pin D13 as problematic for input!  Apparently, this a known  issue.  :bang:
The reason, it turns out, is that on the nano this pin is attached to a resistor in series with a LED that is connected to ground. The function of that LED is so people can program these boards to run simple programs that flash it as a demonstration -- in fact the most basic program almost everyone starts with when they get one of these boards is called "Blinky" and it blinks that LED.
To do this the Blinky program converts Pin D13 into an output pin. This pin can either be programmed as an input or an output type. I am using it as an input. Unfortunately, the connection to a resistor and LED and then to ground makes it unresponsive as an input, though supposedly you can add a pullup resistor to +5V and get it to work that way. Recommended is a fairly small resistor since the LED is sinking a lot of current (relatively). But no actual value is given.
I tried a 10K and when that din't work, a 4.7K pullup but nothing changed. Finally I got mad at this road blocking #&%! circuitry and applied my soldering iron to the LED's series resistor -- a tiny surface mount speck, and just flicked it off of the board!   :zap:
SUCCESS! Testing again, switch F now works, and I can select all of the metric pitches that I've programmed in.  :thumbup:
  • LaGrange, GA USA
« Reply #162 on: February 23, 2026, 06:22:34 AM »
Thank you for this information. I have not heard that before and have some projects coming up using the nano.  Will have to keep this in mind!
Art
Country Bubba
« Reply #163 on: February 23, 2026, 09:55:05 AM »
Thanks Art! :beer:
What kind of projects do you have in mind?
  • LaGrange, GA USA
« Reply #164 on: February 24, 2026, 06:56:08 AM »
On the top of the list is to make an electric coil winder. I want to make several coils for another project down the road and it will need several cols of possibly hundreds of turns and produce reasonably consistent magnetic results. That project will possibly require other nano projects to be determined as I go along.
As another hobby is 3D printing, it allows me to go off into the weeds of possibilities and who knows where I will end up? :doh: :Doh:
Anything to keep my mind active as the body can't do what we used to 40-50 years ago.
Art
Country Bubba
Offline beeshed
« Reply #165 on: February 24, 2026, 04:12:49 PM »
Congratulations - had to go back a few years to catch up. Are you still using Forth? Must be the last person to use it. Look up Jupiter Ace from 1981 - the only computer made with Forth rather than Basic as its native language.
« Reply #166 on: February 24, 2026, 06:33:39 PM »
Well Art, sounds interesting -- I hope you'll keep us posted on those projects!  :beer:
« Reply #167 on: February 24, 2026, 06:48:51 PM »
Hi beeshed, thanks kindly!  :beer:
Yup still using FORTH. For me it's particularly well suited as a control language in an embedded system -- which is how it started out, controlling radio telescopes. Invented by Charles Moore. As far as I know, I'm not the only one still using it:
https://www.forth.com/resources/forth-apps/
But if I am, I'm glad to be keeping it alive!  :lol:
My mind just works that way for programming. I like the fact that FORTH let's you make up your own language, and I like the fact that it is very compact and very fast (necessary for this application), and I like the fact that it is both an interpreter and compiler, making debugging and trying changes super easy. And I like the fact that you can write in assembler in it if you really need fast and compact operations.
I wouldn't want to write a word processor in it, or a video editor, but for control programs, I can't think of anything that I'd rather use. Arduino's native Wiring language, was hundreds of times slower -- in fact impractical for this usage.
Viva FORTH!
« Reply #168 on: March 06, 2026, 11:48:26 AM »
It took a long time and a lot of tries to sort out, but I finally was able to etch a brass thread table for the ELS.
It was then painted to fill in the hollows.
And mounted on the body of the change box housing I had made, which was in turn mounted on the lathe. Very happy with the result!  :dremel:
