Author Topic: Button Acceleration  (Read 10910 times)
Button Acceleration
« on: March 16, 2015, 05:46:26 PM »
I am stumped by this bit of code design for an Arduino project:
I want the user to be able to set a large number ( say 0 to 1000 ).
The user interface uses two buttons "Up" and "Down" and a third to confirm the selection.
In order to allow large numbers the buttons need to modify the step size as they are held down.
So initially they step +/- 1
Hold down for (say 10 increments) the step size jumps to 10
Likewise over a hundred step size jumps to 100
On release the step size resets to 1.
Has any one got a code fragment or is their a library with this functionality?
Re: Button Acceleration
« Reply #1 on: March 17, 2015, 09:27:43 PM »
Here's an off-the-cuff attempt.... although it may not be perfect, it might be enough of a clue for you to run with.  Note: interpret this as pseudo-code.... probably looks a lot like C# since that's what I've been using most recently.
This works on the amount of time the button has been held, but you can apply the same logic based on the number of increments.  Myself, I'd find a time-based holding of the button to be more logical from a user interface perspective.
Code: [Select]
// globals
int increment;
int direction;
int setting = 0;
timer buttonTimer; // milliseconds timer
ButtonInterruptHandler()
    if (button == DOWNBUTTON)
        direction = -1; // counting down
    else if (button == UPBUTTON)
        direction = 1; // counting up
    buttonTimer.start; // start counting how long the button has been held
TimerTickInterruptHandler() // Note, this would need to be scaled down a bit using a counter to slow how often the setpoint is increased.  Otherwise it would go so fast you wouldn't even see it
    if (button == down) { // check that button is still down
        if (timer.value >= 1000) // button has been held for more than a second
            if (setting >= 1000) // set point is over 1000
                increment = 100; // ... so we're stepping up/down by 100
            else if (setting >= 100) // set point is over 100
                increment = 10; // ... so we're stepping up/down by 10
            else // set point is _under_ 100
                increment = 1; // ... so we're stepping up/down by 1
        else // button has not been held for more than a second
        setting = setting + (increment * direction);
    else // when we see the button back up, reset everything
        buttonTimer.stop;
        buttonTimer.reset;
« Last Edit: March 17, 2015, 10:19:21 PM by sparky961 »
« Reply #2 on: March 18, 2015, 05:21:15 AM »
Cheers Sparky, yes timing it seems a very good idea.
Thanks again
Will
