Author Topic: Coke Forge Build  (Read 311738 times)
Re: Coke Forge Build
« Reply #175 on: June 01, 2015, 10:56:53 AM »
Pigs are impossible to catch and pick up when they are dry and clean, never mind wet and oily  :bugeye:
Maybe its time you got some handles fit Andrew  :lol: :lol:
« Reply #176 on: June 01, 2015, 11:02:02 AM »
Thanks Abraham and  Steve  :beer:
Used the ramps today at work , just the job, actually the muts nuts ,,,,,,,,,,, so I will have them independently load tested tomorrow for insurance purposes    .
Hi Mick , yerh used the plasma ,,,,,,,,,,,,,it worked a charm , only one flaw ,,,,,,,,,,,,,,I keep setting things on fire with it  :lol:  , used it to cut through two 3mm sheets at the same time , no grinding (well if it was getting TIG welded I would ) just knock the bit slag off and stick it together   :dremel:
Cheers Rob
« Reply #177 on: June 01, 2015, 11:32:00 AM »
"Used the ramps today at work , just the job, actually the muts nuts"
It's all down hill from here on......OZ.  :) :)
« Reply #178 on: June 01, 2015, 12:06:02 PM »
Cheers Rob
How do they do that Rob, just roll a loaded vehicle up or is it more subtle than that - maybe a quash test in a press?
« Reply #179 on: June 01, 2015, 12:18:58 PM »
Hi Andrew
Just loaded up in a large press  :thumbup: I had 30 (real) tones on each one of them in my shop press , I only need 20 tone max on each .
« Reply #180 on: June 01, 2015, 12:41:54 PM »
Very nice Rob    :drool: :drool: :drool:
The plasma saves loads of time (and cutting discs) :doh: :doh: :doh: :doh:
« Reply #181 on: October 24, 2015, 01:59:35 PM »
Hi Chaps   :wave:
Decided to do a bit work on the forge today , welded some very old and rusty steel onto the stand for feet .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100460_zpsf51oe6oq.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100461_zpsbz5eppz3.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100465_zpshopfhzfq.jpgCoke Forge Build
and decided to cut a section of the hearth away  .
before .
 http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1070984_zpsccb571e6.jpgCoke Forge Build
after
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100473_zpsrainui0d.jpgCoke Forge Build
First time I have used the yard vice ,
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080945_zpstvjvoqbx.jpgCoke Forge Build
 much better grinding out side , needs two mods , it's about 2" to high and it needs somewhere to hand a grinder   :scratch:
« Reply #182 on: October 24, 2015, 09:51:03 PM »
Hey Rob! :wave:
I need one of them outdoor vices! :thumbup:
Offline Pete49
« Reply #183 on: October 24, 2015, 09:56:13 PM »
+1 for the yard vice. Looks like another project added to the list, though it might make the top of it.
« Reply #184 on: October 25, 2015, 10:01:07 AM »
Cheers Steve and Pete  :beer:
A yard vice is a must  :dremel:
Got a tad more done today ,was going great guns up until I pulled a muscle in my back  :( , so I will post this for now   , first job this morning was to cut down the yard vice stand
by 2" and add two bits of flat bar so that I can hang gear from them .
 http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100476_zps51vjxl3x.jpgCoke Forge Build
 http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100483_zpsgszinhzc.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100479_zpsnjk9v4bb.jpgCoke Forge Build
Then another job I have been meaning to do is add a hook to the 8" grinder , this was made from a bolt .
 http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100488_zps9mhawys2.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100489_zps0i23w8um.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100490_zpssf4g9hzr.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100492_zpswzzl3jef.jpgCoke Forge Build
That done I could get back on with the forge , I am using up my old rusty stock on this project , this was cleaned up with the above grinder .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100494_zpshqkakl1i.jpgCoke Forge Build
and cut and welded into this .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100495_zpsrrjetyya.jpgCoke Forge Build
this being to support the hood and back panel .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100500_zps6wqmbw5d.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100502_zpsalwo3xyq.jpgCoke Forge Build
deciding whether to bolt or weld it to the hearth .
cheers Rob
« Reply #185 on: October 25, 2015, 02:44:57 PM »
Tidy work as always there Rob! Shame you cut that vice down by 2" - I reckon I'm about 2" taller than you, it'd have fit me perfectly!  :lol:
« Reply #186 on: October 25, 2015, 02:54:56 PM »
I like it! :thumbup:
Rob, does yer back get to vote on bolted vs welded?  :poke:
« Reply #187 on: October 25, 2015, 05:03:57 PM »
as per rob brill
Offline Joe d
« Reply #188 on: October 25, 2015, 05:51:02 PM »
Looks good, Rob  :thumbup:
What projects have you got lined up to make with it?
Joe
« Reply #189 on: October 28, 2015, 11:24:44 AM »
Aye its nearly  about the right size for you Ade ,,,,,,,,,,probably would need 2" adding  :lol:
 :lol: :lol: was planning  on welding my back Steve  :)
as per rob brill
 :beer: Cheers Bob  :beer:
Joe
The truth Joe ,,,,,,,,,,,,,,,,,I have no idea  :palm: ,,,,,,,,,,,,,maybe some tools and I was looking at some ye oldie locks in a museum that looked like they maybe interesting to have a go at .
But it will make a canny pie warmer when done  :lol:
« Last Edit: October 28, 2015, 11:55:16 AM by RobWilson »
Offline Joe d
« Reply #190 on: October 28, 2015, 12:47:34 PM »
Pork pies.... sausages... apple cider... I'm in! :thumbup:
Call me when they're ready!
Joe
Offline NeoTech
    • Roughedge Hobbyworks
« Reply #191 on: October 28, 2015, 09:45:20 PM »
So im starting to get curious what will come out of that thing down the road. =)
Offline joshagrady
« Reply #192 on: October 29, 2015, 05:39:49 AM »
Hi Chaps   :wave:
Even Rob's rusty steel is shiny.
Brilliant, as usual.
« Reply #193 on: November 01, 2015, 01:25:14 PM »
Cheers Lads  :beer:
Done a bit more work on the forge today , still pondering the hood so decided to make a work rest to support long pieces  .I did not want a floor stand , the floor is cluttered enough at time , I wanted something that will work in any position and stow away when not needed .
The Wilson rest  :)
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100511_zpsjc528ahf.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100515_zpsucy5hgfi.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100517_zpshdq5k4bs.jpgCoke Forge Build
The long tube will have a tee bar thing fitted to support the work and the other end will be welded to the leg of the forge .
« Reply #194 on: November 01, 2015, 06:47:38 PM »
you sure this isn't a bracket for an anglepoise or Ikea work light?
« Reply #195 on: November 02, 2015, 08:38:56 AM »
Wow. Nice looking work there Rob. I have to build my wife a forge... been studying this build!
« Reply #196 on: November 04, 2015, 03:43:22 PM »
Thanks Eric ,,,,,,,,,,,,,,,is yourlass still enjoying forging ?  :thumbup:
Got a wee bit more done tonight , fired up the hot snot gun for steel and a fixed the arm .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100533_zpsx2oat14y.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100535_zps2axfsle0.jpgCoke Forge Build
Made the tee bar and height adjuster doodad ,,,,,,,,,,,,,,,,,,,all for the closest materials at  hand .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100539_zpsg69th0iy.jpgCoke Forge Build
fits like so   :dremel:
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100541_zpsrfvodzng.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100543_zps7pfezpyx.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100542_zps6ycaure5.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100546_zpsyht5gxc4.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100545_zps6jtwt5hx.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1100547_zpsplfxrf38.jpgCoke Forge Build
The Wilson support arm   :loco:
Offline Joe d
« Reply #197 on: November 04, 2015, 05:33:03 PM »
That's pretty damned posh... the Council will be raising your rates  :)
Nice work (as always)
Joe
Offline rotorhead
« Reply #198 on: November 04, 2015, 06:11:32 PM »
Hi Rob,
Just come across this thread, kept me awake and engaged for quite a while.
Your workmanship is really artistic, but where's the bloody outtakes???
Do we have to wait till the end, like John makes us... :)
Sunny Scunny,
North Lincolnshire.
« Reply #199 on: November 06, 2015, 10:05:43 AM »
You lost me there Chris  :scratch:
Cheers Joe  :beer: , dont get me started on rates ,,,,,,,,,,,,, employed caucasian atheist  male  ,,,,,,,,,,,,,,,,,,,,,,,,,,that me shagged  :lol:
