Author Topic: Coke Forge Build  (Read 311608 times)
Coke Forge Build
« on: February 15, 2015, 05:26:50 AM »
Hi Chaps  :wave:
Just thought I would show you lot what I have been up to ,I decided after about 20 years of collecting blacksmithing tools that it was about time I made a start on building a forge  :dremel:
Some of the gear I have collected over the years .
http://i1066.photobucket.com/albums/u410/RobWilson100/Workshop%20stuff/P1070955_zps72d67222.jpgCoke Forge Build
The forge will be located in this corner of the workshop (plate and sheet material will be relocated ) when built .
http://i1066.photobucket.com/albums/u410/RobWilson100/Workshop%20stuff/P1070957_zpsa44acd65.jpgCoke Forge Build
The forge stand was made from some scrap I recycled from work , it was an old batter change over station .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1070964_zps61e93368.jpgCoke Forge Build
This was cut up and welded to make the stand .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1070968_zpsbb6ccc9b.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1070975_zpscf1b3bec.jpgCoke Forge Build
Then the hearth was made up from a bit 3/8 plate .600MM X 600MM is as large a hearth as I can fit in space available .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1070959_zpsd8f879e4.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1070962_zps583a5de4.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1070979_zps212a36ab.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1070980_zpsf0a48f16.jpgCoke Forge Build
Next up the Fire pot , this was made up of 1/2" plate .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1070992_zps9ad8fa73.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1070998_zpsc22df00d.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1070999_zpsa7173771.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080006_zpsf2e5ef97.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080019_zpsdd567a4b.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080036_zps5c2843be.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080040_zpsb8832bee.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080043_zps94ca5bc1.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080074_zpsc59ba6cf.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080076_zps674c4f37.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080080_zpsfa9c91ea.jpgCoke Forge Build
Re: Coke Forge Build
« Reply #1 on: February 15, 2015, 05:34:14 AM »
Nice job there Rob, up to your usual standard....  :bow:  :dremel:
What you using for a blower? Your lass's old hair drier ....?lol :lol:
 Think I might have some part used BBQ charcoal you can have..too... :loco:
« Reply #2 on: February 15, 2015, 05:54:32 AM »
 :lol: :lol: Nope I was hoping  to borrow your hair dryer  John  :poke:
Blower Design  (PREVIEW )  :)
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/blower2_zps046c35d2.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/blower1_zps930e23e8.jpgCoke Forge Build
Rob  :dremel:
« Reply #3 on: February 15, 2015, 06:26:51 AM »
A bit flimsy isn't it Rob - only 1/2" plate for the fire box  :lol:
Offline Arbalist
« Reply #4 on: February 15, 2015, 07:01:59 AM »
Half inch plate plate is fairly common on builds over on IForgeIron, some folks prefer 5/8" though!  :D
« Reply #5 on: February 15, 2015, 07:21:09 AM »
Did you make yours in 5/8" plate ?   any photos    :poke:
« Reply #6 on: February 15, 2015, 08:14:33 AM »
Next up , the fire pot needs to be fit to the hearth  :dremel:
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080090_zpsaeb9fe45.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080095_zpsd3c91df5.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080096_zps2db919c9.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080107_zps5baaaffb.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080111_zpsec6e0900.jpgCoke Forge Build
I designed the fixings so that the fire pot could float , to allow for expansion/contraction .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080114_zps04b3c40d.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080119_zps4a8a8c02.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080122_zpsd06247db.jpgCoke Forge Build
« Reply #7 on: February 15, 2015, 08:17:50 AM »
Tremendous stuff Rob,glad to see you back posting projects up here. :thumbup:......OZ.
« Reply #8 on: February 15, 2015, 08:58:35 AM »
Hi there OZ  and thanks  :beer:
Next up the blower , I was going to use this motor as I had it on the shelf .(and me being a cheep skate )  :)
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080127_zps9257b716.jpgCoke Forge Build
But down to overwhelming pressure form other interweb users who will remain nameless ( he keeps sheep in East Sussex )  :) ,this being the wrong motor for the job , he being correct of course  :bang:
I splashed out and bought a new motor .  :med:
Blower case is made from a sheet of 1.5mm semi stainless (sounds like bollocks to me ) but that what i was told it was , any way I got a load from a car exhaust factory .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080153_zps55af0986.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080155_zps1bfdb3ce.jpgCoke Forge Build
Machined up a few inserts
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080158_zps9ec6115a.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080163_zpsded21060.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080164_zps482e2cb5.jpgCoke Forge Build
 http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080170_zps3037c0ad.jpgCoke Forge Build
 The strip was then rolled in my CNC rollers
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080173_zpsddd24182.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080175_zps9b80ada0.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080181_zps5026f801.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080190_zps1392d3a5.jpgCoke Forge Build
Next up I poked a hole in each side .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080194_zpsf863d78b.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080202_zpsc355f9cd.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080205_zps1a6827ec.jpgCoke Forge Build
The way I have designed the fan casing I can have the output in any orientation I desire .
« Last Edit: February 15, 2015, 09:25:02 AM by RobWilson »
Offline CrazyModder
« Reply #9 on: February 15, 2015, 09:21:40 AM »
Very awesome job, my mate.  :drool:
This is one reason I hate living in a, while large enough, yet still rented house. I can't just go ahead and convert a corner of the garage into a "dirty" place.   :bang:
« Reply #10 on: February 15, 2015, 10:13:15 AM »
 CNC rollers? around the twist brand,by any chance? :lol: :lol:
« Reply #11 on: February 15, 2015, 11:19:33 AM »
Rob,
Where are you getting you coke from ?  It's never seen around these parts nowadays. It used to be the fuel of choice from out local town gas plant.  But that is long gone.
« Reply #12 on: February 15, 2015, 11:42:23 AM »
Thank Crazy  :beer: , keep the faith and pray to the god off tools ,you will get your shop one day  :med:
 :lol: :lol: :lol: aye tis round the bend  :loco: :lol: :lol:
Rob,
Hi Dave , Plenty of places round  Newcastle,Hartlepool and Teesside still stock solid fuel  , so its fairly easy to get , If my Cupola works like it should I may buy it by the ton ,get it delivered/stored at work .
Offline prallplatte
« Reply #13 on: February 15, 2015, 12:43:07 PM »
Heavy industries, that rocks! :bugeye:
Regards - Kurt
...watch my channel:
http://www.youtube.com/user/prallplatte
« Reply #14 on: February 15, 2015, 01:47:39 PM »
Hi Rob
Glad to see you back posting again. I see that you have been taking good care of the camera.
Looking forward to watching many more projects.  :D :D
« Reply #15 on: February 15, 2015, 03:11:30 PM »
Pure art.
« Reply #16 on: February 15, 2015, 03:17:03 PM »
It's great to see you doing, and explaining, what you do best,  Rob!
Keep it up, mate......  :thumbup:
« Reply #17 on: February 15, 2015, 04:41:51 PM »
Quote from: RobWilson
Plenty of places round  Newcastle still stock solid fuel
So you still gettin' it off the beach then Rob?...... :D
« Reply #18 on: February 15, 2015, 04:47:40 PM »
Thanks Kurt , Don , Steve and David  :beer:
A wee bit more , the intake and motor mount   :dremel: a bit more layout work .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080226_zps7998410f.jpgCoke Forge Build
Roughly cut to shape .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080230_zpsf9876230.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080236_zps0bb07649.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080239_zps348d0b88.jpgCoke Forge Build
Then slapped onto the lathe for a bit machining .
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080248_zps0c44f37b.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080250_zpsf62742dd.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080252_zps37421ced.jpgCoke Forge Build
Then much the same for the fan ,
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080269_zpsa6564f76.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080367_zps50a00d46.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080372_zpsb7ef0fb8.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/P1080374_zpsa68798d2.jpgCoke Forge Build
Thanks again Lads  :beer:
« Reply #19 on: February 15, 2015, 04:50:15 PM »
Mm... More nice work Rob, but how did you weld up the fan rotor? Is that MIG or you using a spot welder?
Ah..looking at the pics, looks like MIG....
« Reply #20 on: February 15, 2015, 04:50:49 PM »
Well as it happens John   :)
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/20140825_142932_zps3e75e149.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/20140825_142921_zps3cd2d95d.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/20140825_142122_zps0ce607c1.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/20140825_142908_zpsb060bd82.jpgCoke Forge Build
http://i1066.photobucket.com/albums/u410/RobWilson100/Forge/20140825_144416_zps0adfaa31.jpgCoke Forge Build
There be plenty of coal lying on the beach  :thumbup:
« Reply #21 on: February 15, 2015, 04:52:44 PM »
Yer just plug welded with the MIG John  :zap:
« Reply #22 on: February 15, 2015, 05:33:08 PM »
Hi Rob , Good to see you posting again , the lighter nights and hopefully better weather are on the way so you will be able to get on with the forge, it will be one hell of a bit of kit once its running...............looks like you have plenty tongs to keep you going anyway  :thumbup:
  Cheers Mick
Offline S. Heslop
« Reply #23 on: February 16, 2015, 09:14:00 AM »
I'm glad you're back to make me feel inadequate once again. Amazing stuff!
« Reply #24 on: February 16, 2015, 05:13:06 PM »
  Cheers Mick
Hi Mick , aye hopefully when it warms up I can get back into my stride and really abuse some steel  :dremel:
Your welcome  Simon  :lol: :lol:  , I hope you haven't given up on your armour work  :poke:
