Author Topic: Locking a screw thread?  (Read 9399 times)
« on: February 03, 2015, 02:53:06 AM »
I am building my cnc router table to use roller chain drive for the long axis and there is a need to anchor screwed bicycle sprockets to shafts.
The thread is 1.37" 24tpi.  The shaft will reverse in operation and I really, really, do not want these sprockets to come unscrewed,  what suggestions can I have please?
Thanks
Offline NeoTech
    • Roughedge Hobbyworks
Re: Locking a screw thread?
« Reply #1 on: February 03, 2015, 03:27:11 AM »
Make a collet with set screws that goes in to the thread, or try to create two jam nuts?
« Reply #2 on: February 03, 2015, 03:52:04 AM »
Bore the thread off, and either weld or loctite a suitable hub for your shaft
« Reply #3 on: February 03, 2015, 03:59:17 AM »
For a fixed wheel sprocket there used to be a locking ring available , if not turn down another sprocket as a lock ring .
« Reply #4 on: February 03, 2015, 04:12:13 AM »
In my experience it's a waste of time trying to bore the thread off or trying to turn another sprocket down.  They're very hard.
Make a plain unthreaded close fitting hub and weld the sprocket on.  Take your choice of how to fix the hub.
« Last Edit: February 03, 2015, 06:33:29 AM by RussellT »
« Reply #5 on: February 03, 2015, 05:12:29 AM »
Jeff,
You can still buy the fixed wheel locking rings but they have a left handed thread. The locking thread is smaller than the 1.37".
Offline steampunkpete
« Reply #6 on: February 03, 2015, 06:12:29 AM »
There is a standard that covers locking threaded components used in certain safety applications - that is where the threaded component becoming loose or detached would cause a hazard.
The standard does not preclude bespoke solutions, but there are a number of pre-approved locking methods. With one exception, the methods are characterised by being both positive and visually inspectable.  Castellated nuts + split pins and wire-locking come to mind from memory. A single fixing relying on a thread locking compound is not accepted, being considered too unreliable for safety purposes as well as not being inspectable.
I'm assuming that the sprocket is held onto the shaft by a screwed collar (I'm not familiar with bicycles - a photo with the post would be good).  Taking the safety standard as a lead, personally I would go for wire locking the collar to the shaft or a split-pin through the shaft.
Alternatively, a pin through the sprocket into the shaft flange behind the sprocket - again difficult without seeing whether there is such a flange.
Does this thing need to come apart again - for repair or maintenance? If not can it be brazed?
Come to think of it:  :worthless:
« Reply #7 on: February 03, 2015, 09:06:57 AM »
Carbide tool would have no problem whatsoever. (If the sprocket is fully hard (ie untempered) it would soon crack in use)
« Reply #8 on: February 03, 2015, 02:01:34 PM »
Thanks for the comments.
Yes, I will be making a hub for each sprocket.  There are three to do and having bought then new from the local cycle shop I am taking very good care of them! :coffee:
I think I will put extra thread on the hubs then screw on the sprocket followed by a lock ring followed by a dab from my welder then if I have to take a sprocket off the hub I can grind the weld off.
