Author Topic: Mini tube bender  (Read 12171 times)
Offline mechman48
Mini tube bender
« on: January 19, 2015, 06:46:16 AM »
Hi  :wave:
Finished my version of a mini tube bender to a design by G.Britnell. It works ok but it may need tweaking as it does not quite complete a 180* bend. I may have missed something reading the drawing measurements as some measurements don't seem to tally up... not to worry,  :scratch:  .. it does what it was designed to do  so it's finished.. but not, if you get my drift, need to review at a later date, so what next..  :scratch:
The two bent pieces of brass are top.. 4mm rod... the lower 3mm o.d. tube, this has curved quite nicely with out any kinks or sharp nicks. Have made a couple of bushes for other sizes, 3.2mm..4.5mm.
George.
George.
Offline steampunkpete
Re: Mini tube bender
« Reply #1 on: January 19, 2015, 07:27:50 AM »
Nicely done!
I think it is the subtleties of shape in parts like the handles that make the difference between a functional piece of kit and something rather more delicious.  :clap: :thumbup:
« Reply #2 on: January 19, 2015, 09:53:52 AM »
Wow, that's really nice Mechman!  :thumbup: :thumbup: :clap:
Offline Arbalist
« Reply #3 on: January 19, 2015, 11:03:45 AM »
Very nice work. The shape you've used on that handle is perfect. Is it your own design or from plans?
Offline mechman48
« Reply #4 on: January 19, 2015, 11:46:33 AM »
Thanks for the comments guys  :headbang: the original design is from another forum by a G.Britnell ( US IIR ) but some of the measurements on the plan didn't / don't quite tally up, maybe I missed something obvious..as one does   :palm: so I used poetic license so to speak  :smart: I used 3mm & 4mm threads where it quotes #6 x 32 or #10x40 which are US sizes AFAIK (ANF/ANC is nearest I could compare with ?? or poss' ME sizes would do) couldn't relate UK - European sizes to suit. Some of the dimensions were confusing to this old grey matter i.e. 0.219", 0.440" etc or .. 'dia as req'd'... the handle taper isn't specified so I used a 1* (& it looked ok)...   so an accumulation of errors is quite possible, any way if any one wants to have a go... & it is cute after all  :dremel:
http://bbs.homeshopmachinist.net/threads/29136-Miniature-tubing-bender
Thanks & credit to G.Britnell for the idea.
George.
George.
