Author Topic: 7x12 clarke cl300m lathe - changing tool post making milling machine!  (Read 65999 times)
Hi Guys
I`m new on here - will post another thread in the "introductions" sub-forum shortly. I am 25 y/o and have always been interested in metalwork - about 5 years ago I owned a Unimat 3 with milling attachment which was an excellent machine but I had to sell a couple of years ago to fund my wedding. I have since got a house, daughter.... and when I came to look at buying one back on ebay - the price shocked me for what it is! They seem to have increased in further in price so I decided to plunge for a second-hand Asian-made lathe - UK branded the Clarke cl300m.
I have been using it for the last few weeks but I am really missing a milling machine. I use to use the Milling attachment on the Unimat 3 quite often and it was an excellent addition for the small cost. Not very rigid but dd the job. It was also good for space, my work area is not large so an additional milling machine takes up even more room!
Has anyone created or Modified a 7x12 to include a milling machine or attachment? I have seen this on the gadget builder website:
http://www.gadgetbuilder.com/PostMiller.jpg
QUOTE from site:
"I added a Phase II AXA 100 QCTP. This toolpost looks huge on the minilathe and it makes a huge difference to the way the lathe operates: easy tool height adjustment, less tool chatter, a nice boring bar holder, and a simple mount for the cutoff tool. In addition, it's easy to add a vise to do simple milling: bolt a 3 inch length of 1/2 inch bar to a small vise, then mount the bar in the tool holder. The height is crudely adjustable using the tool height adjustment of the toolpost. An advantage to this setup is that it takes only seconds to shift from lathe to milling operations. The downside to the new toolpost (and there's always a downside) is that it restricts the size of items which can be turned due to its sheer size; I added the modified compound rest from LMS to help accommodate this and eventually modified the cross slide to allow more range.""
Does anyone think this is a good route to go down - the new tool post alone costs $150 from the USA but does anyone know a similar UK product?
Can any suggest an alternative cheap mini mill to look out for if you think it isn`t worth going down this route.
Thanks for any help.
Hi Chris and welcome to the forum  :thumbup:
I have a similar, but much smaller, toolpost on my 7x12..
Not sure how it would cope with milling as I don't have the need to try it, probably be fine
As a toolpost I wouldn't want to be without it now....got mine from LMS in the US,
http://madmodder.net/index.php?topic=1001.15
Hi Chris Welcome aboard  :wave:
Is that Clarke 300 a 3 in 1 machine if so I used one for about 5 years i found the milling head OK I did some great work on it but it had  limitations, I,ve recently bought a Seige mill and converted my 3 in 1 to just a 1 in 1 if that makes sence, in hind sight I wish I'd gone the lathe with a mill route. I think the add on attachements to enable you to mill on a lathe are OK but they have their limitations but if your stuck for space/cash you can still produce good work off them, after all our grandfathers didn't have the kit available to them that we have today and they did some magic work.
Have fun
and lets see some pics of your projects  :worthless:
Hi Chris, welcome to our little group.
As far as I know, your lathe comes under the same generic category as the Seig 3, shown here.
http://www.arceurotrade.co.uk/Catalogue/Machines-Accessories/Lathes/Model-C3-Mini-Lathe
If you go down the page a little, it shows  some 'extras' you can get to fit this lathe.
The first one you will come across which you should be interested in is the vertical slide (C3 Milling Attachment). This little bit of kit does what you showed in your link, but a lot better.
I would just like to add, a vertical slide will never replace a proper mill, but it does allow you to get the same sort of results, but at a reduced speed.
The other is the quick change toolpost, which is very reasonably priced and comes with 3 holders already, with the option to buy more when they come back in stock.
Both these bits together will come to about the same price as the QCTP from LMS, by the time you add very bad exchange rate at the moment, shipping and import duty.
http://littlemachineshop.com/products/product_view.php?ProductID=2461&category=-419988835
Hope this helps.
« Last Edit: April 15, 2009, 06:36:18 AM by bogstandard »
bogstandard - thank you so much for the link - I didn`t expect anyone in the UK to supply us with these "extra" extras! They even do the ball turner..!
Just to clarify then, with the vertical slide-milling attachment, you are basically using your lathe head stock as the milling machine and milling horizonally rather than normal vertical?
On an additional note, C3 Quick Change Tool Post Set - is that the tool post? How will it compare to the QCTP in my original post?
Stew - no the clarke 300 is not a 3 in 1 - just a stand alone 7x12 asian made mini-lathe. I don`t really have room or the money for a mill and that is why I am thinking that this route of the Milling Attachment - vertical slide that bogstandard posted may be a route worth going down!
« Last Edit: April 15, 2009, 06:54:28 AM by craynerd »
Chris,
You are spot on, imagine standing the lathe on end with the tailstock at the bottom. The vertical slide will give you the Y axis (fwds/back), and the lathe crosslide the X axis (side to side). For depth of cut, you move forwards with your saddle (like raising the table up to meet the cutter). For fine movement of the saddle, you might need to rig up a dial gauge to give you an accurate reading and a good saddle lock as I did in my post on fixing Darrens lathe.
http://madmodder.net/index.php?topic=627.msg5085#msg5085
That is the whole lot to give you what is required, a means of permanently setting the tool height in the holder and a way of changing tools quickly. Every type is a much of a muchness, different designs, but they all work to give the same end result.
The way they showed the milling being done in the first article you showed was, to put it bluntly, a load of crap. OK to put an odd slot in something to get yourself out of the s**t, but not a method for continual milling on the lathe like a vertical slide gives you.
Hope this helps.
Vertical slides are certainly a good route to mill in a lathe I used one on my 3 in 1 to give me better milling options.
The one I used was for a Myford lathe, that I fitted to my machine this is it in use
http://i431.photobucket.com/albums/qq32/sbwhart/IMG_1627.jpg7x12 clarke cl300m lathe - changing tool post making milling machine!
http://i431.photobucket.com/albums/qq32/sbwhart/IMG_1575.jpg7x12 clarke cl300m lathe - changing tool post making milling machine!
http://i431.photobucket.com/albums/qq32/sbwhart/IMG_1265.jpg7x12 clarke cl300m lathe - changing tool post making milling machine!
Hope this helps
Thanks for your input - the attachment has done a nice job of that piece.
I am really in two minds here what to do. I am scrapping around for money (as are most) and so really don`t have a lot to spend - immediately anyway. The vertical slide is £90, but will it really do a good enough job and be stable enough to use as a mill for my small projects which invariably will get bigger as I get better and start to demand more? Will my lathe be strong enough to use the vertical slide effectively? - Is the Myford lathe shown above not a bigger lathe and can therefore cope with milling better. Also, from what I have read, there is no substitute for a milling chuck or tools work free. Would I have to purchase one of these for the "lathe conversion" and if so this is adding to the cost.
In my head, it all leads me to the idea that I want a stand alone mill but they seem much more costly than lathes. I picked my lathe up for £165 on fleabay but there doesn`t seem any mills out there for even double this!
I have been looking at the Chester Champion, Axminster or Warco ZX15....perhaps a second hand bridgeport? I can`t even find most of these at the moment on ebay second hand - what price do they normally go for? Also, I can`t accommodate for anything too big - I believe some require a 1meter square floor space!!
I appreciate that this thread was started with me asking for alternatives to buying a mill, but I think as the answers have come back it has redirected my thoughts.
Appreciate any feedback - I know this is now turning into a "which mill?" thread!
« Last Edit: April 15, 2009, 06:55:17 PM by craynerd »
Chris,
Before delving too deep into the subject of mills, wait until you can turn a bit, and then you will know if your lathe can do it.
By diving in with both feet, you can end up hating it, when you hit your machining 'ignorance' and they start to eat expensive tooling. Get the lathe under your belt first, then make a decision if you can afford to go the way of the mill a little later. Then you would have the choice of going for a vertical slide setup, or a small mill.
If you pick up a mill for say £400, it might cost you at least half that much again to basically tool it up, and that would only be fairly basic setup with a half decent set of tooling.
Take it steady, and sleep on it. Think of the consequences if you get it wrong. Your bits could end back up on eblay if you get disillusioned.
You right, John. I will sit on my hands and learn this thread cutting with multiple leads first.  :jaw: :scratch:
For that price I'd go get it myself.  :)
The Grizzly look a like over here in the states sells for $995 at the moment. I'd say at 10.50 it's a steal.
Bernd,
I think everyone in the UK would bid on it if it was gong to stay around that price, that will most probably go for over 300 squid on a bad vendor day, 400 on a good day.
John S recently sold his mini lathe on eblay, and got a lot more for it than he paid new. It did have a few extras, but not enough to justify the price paid.
I got my Miller on Ebay for £200
Took me a while, like 2 yrs of watching and waiting.....but it was sure worth it  :thumbup:
You just got to set yourself a price and keep bidding to that price till you get one....you will.... :)
I knew that the minute I looked at how much time was left. I'm sure it'll get up there in price.
Jason, keep us posted as to what it went for in the end.
Chris, for what its worth:
I dont think there is anyone on MadModders with less 'shop experience than me, but I have a lathe and after making a couple of buckets of swarf I began looking for ways to make other than 'round stuff'.  So I looked at a vertical slide for milling and came here for advice, then I went to my favourite tool and machine supplier and looked for something better.  He showed me a 'mill drill' which I came back here for advice, then I went back to the supplier looking for a 'real' mill.  Then I had a talk to the financial controller (Her Indoors), then I cancelled the whole idea, postponed more than cancelled I suppose!
Meanwhile, I have a little shaper which is better than nothing for making flat stuff.
John Hill - what put you off the vertical slide?
Problem with ebay is not only the right price but also location - due to the size and having to collect. I was lucky with the lathe that he was about 10 miles away!
I also have the problem that I don`t really know which mill would be suitable. I had seen the Clarke 300 lathe previous and considered it, so was happy to buy. With the mills - I haven`t seen that many and they look to go for much more!
What are the quality mini-mills I should be looking out for? Like I said earlier - nothing too big but then again, something functional!
ja2on
I am saving for a x3 but it will take me forever.if a mini mill comes up at the right price and distance I will go for that
I am aware of the new price of these mills so I expect it will go for more than I want to pay that's what usually happens
I will let you know what it goes for
Chris, things that dissuaded me from the vertical slide:
1. My lathe has no 'T' slots or other means of attaching and having not yet knocked much paint off the new lathe I was reluctant to start drilling and tapping holes all over the cross slide!
2. Very few if any vertical slides on the market in New Zealand, new or used.
3. Importing a slide would have been expensive and equating to about 10 or 20% of the price of the lathe!
4. It seemed a little awkward having to dismantle and re-mantle** when going between milling and turning.
5. I can affort a mill, but just not yet!
6. I have my dinky little shaper for small jobs meantime.
**New word? (all rights reserved)
Thanks, John
and bye the way, with fear of looking like a ****, I think you were looking for "assemble" or reassemble. All rights most definitely reserved to John Hill for "re-mantle"
ja2on
sieg have a new mini mill (super X2)in their catalogue
http://bbs.51sieg.com/ug/2009%20catalog.pdf
brushless motor and belt drive as standard
http://i27.photobucket.com/albums/c176/j450n_/193_P_1232316070508.jpg7x12 clarke cl300m lathe - changing tool post making milling machine!
oh no I'm getting tool envy
I've tried milling on my industrial lathe, it's a nice and sold one...!!
I clamped the work directly to the topslide and although it worked well enough I found it to be nowhere as rigid as my mill/drill. There are just too many parts to chatter about. BTW on this lathe the crosslide clamps directly to the bed so no movement there like on most other lathes.
I don't think I'd ever be tempted to try milling on my 7x12, but then I'm fortunate enough not to need too. But I understand why you might, I was there myself not so long ago.
ja2on
Bernd the mini mill is up to £226.09 with 22 hours to go  :bugeye:
it's almost to dear for me now for a two year old mill that might have unknown problems.
plus I checked my milling machine piggy bank and can almost afford a x3  :ddb:
http://cgi.ebay.co.uk/Mini-milling-machine_W0QQitemZ280334650919QQcmdZViewItemQQptZUK_Home_Garden_PowerTools_SM?hash=item280334650919&_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A10|39%3A1|240%3A1318
so guys competition time (there is no prize ::) )
guess the final price
Jason,
I would guesstimate about 330 squid but it could go a lot higher. The machining season is upon us and it just depends how many idiots are knocking about.
Would it be worth saving your pennies a little longer and go for the updated X3?
I haven't really looked at what the main differences are, but it might be worth checking out, just to see if it justifies the longer wait.
It is a real major purchase that will last you for many years, and if you decide you really wanted the later machine, you could be kicking yourself for a long time. I was going for the Chester 626, then a windfall came my way, and I got the 836. Looking at it now, if I had gone for the 626, I would now be regretting it, and saving up again to get the one I have ended up with.
If the extras don't justify the higher price, then you can still go back to your original choice.
ja2on
I will be going with an X3 I was just tempted by the X2 as it was close but I have seen the light  :med:
When you say upgraded X3 are you referring to the super X3 ?
there lies my next problem as it is the super X3 I fancy but axminster don't list a R8 machine
and arc euro don't have the super model.
Jason
