Author Topic: tool post spanner  (Read 17878 times)
tool post spanner
« on: December 06, 2014, 06:04:19 PM »
hi all i got a new toolpost for the compact 8 itsa Bison.T00.B ther is a nuther one with the same number but it ends with the leter M the leters stands for wat model lathe they will fit IE . B is for boxford and .M is for miford bothe use the same sise tool holder so bothe are the same sise exsept in hight the miford one is 10mm smaler in hight they fiton to the lathes by the same way so my toolpost came with a bolt to fit it strate on to a boxford top slide i did not want to mack a bush and fit it on to the bolt sticking out of my top slide so i modifide the bolt that came with it this ment  de hardening it drilling and taping m8  ther re hardening it made a new bolt for it to fit on to on my top slide sos no pics of that bit so i naw had to mack a spanner to fit the 19mm nut had a rumige fawnd a 19mm 3/4 drive socet then had a bit of a think as to fit it with a handel i had a 3/4 sqher drive that gose in to a cordles drill so made this fit the socet IE so it sat flush on the top and on the inside then i cheted i don't have a tig welder at home but i do at work so welded the lenth of stanles steel 10mm od with stanles rods a bit of filing and a bit of sanding and its dun right pics
Re: tool post spanner
« Reply #1 on: December 06, 2014, 06:59:05 PM »
Nicely done!
« Reply #2 on: December 06, 2014, 08:06:32 PM »
I agree. Well done and looks good too.  :med: :wave:
« Reply #3 on: December 06, 2014, 08:20:30 PM »
I like it!  Need to make something like that.
Only thing I don't like is the idea of chrome fumes from welding a chrome plated socket. Chrome is much worse than zinc even.
« Reply #4 on: December 07, 2014, 03:10:34 AM »
Nicely done  :thumbup:
I need to do exactly the same but on a larger scale for my Colchester Master
« Reply #5 on: December 07, 2014, 05:19:59 PM »
hi thanks for the coments ther was no chrome on the socket its stanles steel thats why i made the handel out of stanles i cud of just filed a sqher on the end of the bar and bent it over but that wood of bin to esey
« Reply #6 on: December 07, 2014, 06:03:21 PM »
ahhhh, stainless socket. Nice.
« Reply #7 on: December 07, 2014, 06:31:25 PM »
Nice Bob
Did You weld that at work
« Reply #8 on: December 07, 2014, 06:41:18 PM »
Bob , nice job , if you manage to snap that you want your butt kicked boy  :lol:
 Cheers Mick
« Reply #9 on: December 08, 2014, 12:02:57 AM »
Very nice!  :bow:
Offline dawesy
« Reply #10 on: December 08, 2014, 03:59:18 AM »
Very nice. I'll have to look at something similar for my tailstock :)
Lee.
« Reply #11 on: December 08, 2014, 03:47:23 PM »
Nicely done is it removable.
Used to p me off even with a spanner by the side. Needless to say scrapped my old ML7 15 yrs ago but was the best thing ever did. Last lathe I scrapped 5 year ago done similar now use on rear tool post. Its easier to drill and tap round to suit the thread, looks neater too with a screwed in bar.
Its also first thing I did on current lathe, along with replacement similar handles for tail stock locking, screwcut, cross and carriage. You'l wonder why you never did this ages ago.
« Reply #12 on: December 08, 2014, 05:44:24 PM »
yep john weld it at work jonny in wat way do you meen in removable its a multy spline socet so can go on to the nut in any posishon
