Author Topic: Drawing needed  (Read 12828 times)
Offline allanwinks
Drawing needed
« on: December 06, 2014, 03:05:22 PM »
Hi Guys
Can anyone help me with drawings for a Sykes type hydraulic puller please.
Re: Drawing needed
« Reply #1 on: December 06, 2014, 03:14:58 PM »
Hello and welcome.
I'm guessing you don't have many tool hire shop in Trondra  :lol:
Offline allanwinks
Re: Drawing needed
« Reply #2 on: December 06, 2014, 04:55:24 PM »
H Andrew
No we dont have any shops on Trondra :bugeye:
I doubt any would be too keen on me dismantling a hydraulic unit either :jaw:
Re: Drawing needed
« Reply #3 on: December 06, 2014, 06:44:25 PM »
I would also be really interested to see some dimensions and drawings of the hydraulic head unit on these puller types......OZ.
Edit to add: Sykes hydraulic pullers use grease as the hydraulic medium.
Link to Sykes pdf: http://sykes-pickavant.com/downloads/HYDRAULIC%20PULLERS.pdf
Re: Drawing needed
« Reply #4 on: December 07, 2014, 01:07:37 PM »
Hi allanwinks,
I have one of these pullers, but am reluctant to dismantle it as its a pain to bleed the air out of
I would buy a repair kit that contains the plastic seals, spring and grease in the link given
that will give you the  stepped cylinder sizes,
the jacking screw has a hardened piston between it and the cup seal
the pushing plunger and spring are retained by a threaded collar
the pusher piston is top hat shaped and the spring goes over the smaller end and is held in place by the collar
the pusher is about 15m diamater where it comes through the collar, the large end fits the bigger end of the cylinder
Those jacks have a limited amount of travel and you need to back off the screw and wind the body further through the collar when pulling a bearing or whatever over a longish distance
HTH
Offline allanwinks
Re: Drawing needed
« Reply #5 on: January 17, 2015, 12:53:18 PM »
Hi John
Thanks for your reply.
A|lan
