Author Topic: What is this font?  (Read 9737 times)
What is this font?
« on: November 17, 2014, 07:58:58 AM »
I'm cnc milling out a new take up spool for my wire eroder, and as the original had the Fanuc logo emblazoned on it I thought I'd try and engrave a replica.
I was going to try and convert this image to an outline as a dxf but it's defeating me - if I can find the font I could just type it in !!
Offline Swarfing
Re: What is this font?
« Reply #1 on: November 17, 2014, 08:35:53 AM »
Andy 'Liberation Serif' looks exactly the same except the 'F' which you could tweak?
Once in hole stop digging.
« Reply #2 on: November 17, 2014, 10:37:10 AM »
Andrew,
I did a bit of coarse manipulation with the image to turn it into a black font on a white background and submitted it to two online font finders.
There wasn't a good match for all characters. The C seems unique.
I suspect it's a FANUC special.
« Reply #3 on: November 17, 2014, 12:16:19 PM »
Gosh Phil, I never knew that such things exist! Thanks for trying. Yes I expect that is is a logo that they paid a fortune to have designed. Amusingly that form of the logo doesn't seem to feature on any other Fanuc kit where the lettering is much more plain.
« Reply #4 on: November 17, 2014, 01:58:42 PM »
Hi Andrew,
Does the attached look OK? I imported your jpeg into Autocad and did a quick trace over. The curves are arcs and not splines so I could make each character into a polyline.
The characters are 10mm high so you could scale them to whatever height you like.
The zip file contains the dxf - I seemingly can't attach a dxf directly.
[Edit: Replaced zip file - a rogue line was removed.]
« Last Edit: November 18, 2014, 03:52:13 AM by philf »
« Reply #5 on: November 17, 2014, 02:06:13 PM »
 :thumbup: Phil you are an absolute hero - very many thanks that's superb  :thumbup:
